Please help to check the specification of Tango23
Hi, could you help to recheck whether the specification of Part# TANGO23/0.5M/SMAM/S/RP/19 is including below point?
• IP67 Rated
• Tough Vandal Resistant Design
• Low Loss CLF100 Cable
Thank you!
Welcome to the DigiKey TechForum. It is made with a rubber seal gasket to resist water ingress and does have an IP67 rating with document found here . Tough vandal resistant design isn’t listed as a feature but it is for use in outdoor environments. It is supplied with low loss CLF100 cable.
