Power Modules in Parallel
Is it alright to put power modules in parallel so they can withstand higher currents? Right now I am expecting to have a 12S-350A configuration and cannot find anything at that range which also has CAN. It is fine if any other circuitry is required.
@tomz0840
I would think that it could get you the higher total capacity for current.
However, I am not seeing accessories so far listed by that manufacturer that would indicate that is something that is normally done for that device.
I would recommend speaking with their support to see if they have more documentation that talks about connecting these together in that way.
Thank you. I will do that now.
