Connecting Power supplies in parallel
------Question for TDR-240-24 Please Put your question below------
Is it possible to connect TDR-240-24 PSUs in parallel? If not, please suggest an alternative PS, Mean well proffered.
I don’t believe that would be recommended. Instead, order a 20AMP version TDR-480-24
Hi,
I our application, we actually need the power supplies in parallel for redundancy. Any alternative options for that?
Thank you,
Then you need a supply with load sharing. These are the options we have similar to the first part
Industrial, DIN Rail Power Supplies | Electronic Components Distributor DigiKey
