A common question we get asked is whether two AC/DC converters can be wired in series to provide a higher voltage output.
Mean Well power supplies have isolated outputs so they can be linked in series to achieve whatever voltage you require.
For example two of the above NDR-480-48 converters can be wired in series to provide 96V. It is recommended that the power supplies used have similar current ratings.
As seen below, it is also recommended a diode be put in parallel with each power supply to prevent reverse voltage if one starts before the other.
Image courtesy of Power Supplies Australia, please see their website for more information.
Here is a link to Mean Well power supplies we have available.
Power Supplies - External/Internal (Off-Board) | Industrial, DIN Rail Power Supplies | DigiKey
Applicable Part Numbers
| Digi-Key Part Numbers | ||
| 1866-2241-ND | 1866-2243-ND | 1866-DDR-480C-48-ND |
| 1866-2237-ND | 1866-5048-ND | 1866-4913-ND |
| 1866-1029-ND | 1866-1041-ND | 1866-2238-ND |
| 1866-2239-ND | 1866-2248-ND | 1866-2246-ND |
| 1866-1037-ND | 1866-1040-ND | 1866-5042-ND |
| 1866-1034-ND | 1866-1445-ND | 1866-2250-ND |
| 1866-1036-ND | 1866-1444-ND | 1866-1044-ND |
| 1866-2242-ND | 1866-5052-ND | 1866-1424-ND |
| 1866-5043-ND | 1866-2232-ND | 1866-1442-ND |
| 1866-5049-ND | 1866-5062-ND | 1866-5064-ND |
| 1866-5044-ND | 1866-5060-ND | 1866-4458-ND |
| 1866-5046-ND | 1866-WDR-60-5-ND | 1866-5577-ND |
| 1866-2249-ND | 1866-DDR-480D-48-ND | 1866-5036-ND |
| 1866-2251-ND | 1866-2240-ND | 1866-1087-ND |
| 1866-2247-ND | 1866-1028-ND | 1866-DDR-480B-12-ND |
| 1866-1039-ND | 1866-2245-ND | 1866-DDR-480B-48-ND |
| 1866-1038-ND | 1866-2230-ND | 1866-5047-ND |
| 1866-1042-ND | 1866-4912-ND | 1866-5054-ND |
| 1866-1045-ND | 1866-1007-ND | 1866-5066-ND |
| 1866-1043-ND | 1866-5051-ND | 1866-5058-ND |
| 1866-5053-ND | 1866-5056-ND | 1866-DDR-480D-24-ND |
| 1866-5059-ND | 1866-5057-ND | 1866-1416-ND |
| 1866-1440-ND | 1866-3526-ND | 1866-1423-ND |
| 1866-1443-ND | 1866-3525-ND | 1866-1417-ND |
| 1866-2233-ND | 1866-1441-ND | 1866-1446-ND |
| 1866-2234-ND | 1866-5063-ND | 1866-2231-ND |
| 1866-1428-ND | 1866-5065-ND | 1866-1429-ND |
| 1866-3519-ND | 1866-5067-ND | 1866-DLP-04R-ND |
| 1866-3517-ND | 1866-1430-ND | 1866-4459-ND |
| 1866-5061-ND | 1866-5030-ND | 1866-WDR-60-48-ND |
| 1866-4457-ND | 1866-5559-ND | 1866-KNX-20E-640-ND |
| 1866-1031-ND | 1866-5561-ND | 1866-1433-ND |
| 1866-1032-ND | 1866-4910-ND | 1866-KNX-40E-1280-ND |
| 1866-5578-ND | 1866-4460-ND | 1866-KNX-40E-1280D-ND |
| 1866-WDR-60-24-ND | 1866-1035-ND | 1866-1000-ND |
| 1866-WDR-60-12-ND | 1866-5045-ND | 1866-1001-ND |
| 1866-1426-ND | 1866-1425-ND | 1866-1002-ND |
| 1866-1427-ND | 1866-3524-ND | 1866-1003-ND |
| 1866-3520-ND | 1866-2235-ND | 1866-1004-ND |
| 1866-3521-ND | 1866-2229-ND | 1866-1005-ND |
| 1866-5028-ND | 1866-1431-ND | 1866-1006-ND |
| 1866-5027-ND | 1866-1033-ND | 1866-1008-ND |
| 1866-5029-ND | 1866-5579-ND | 1866-1009-ND |
| 1866-5034-ND | 1866-5562-ND | 1866-1010-ND |
| 1866-5033-ND | 1866-5005-ND | 1866-1011-ND |
| 1866-5031-ND | 1866-DDR-480C-12-ND | 1866-1012-ND |
| 1866-1078-ND | 1866-5050-ND | 1866-1013-ND |
| 1866-1079-ND | 1866-1422-ND | 1866-1418-ND |
| 1866-1088-ND | 1866-2236-ND | 1866-1419-ND |
| 1866-5584-ND | 1866-5035-ND | 1866-1014-ND |
| 1866-5560-ND | 1866-5037-ND | 1866-1420-ND |
| 1866-5558-ND | 1866-5585-ND | 1866-1015-ND |
| 1866-5563-ND | 1866-DDR-480D-12-ND | 1866-1016-ND |
| 1866-1081-ND | 1866-1421-ND | 1866-1017-ND |
| 1866-1082-ND | 1866-1089-ND | 1866-1018-ND |
| 1866-3523-ND | 1866-2244-ND | 1866-1021-ND |
| 1866-3522-ND | 1866-5055-ND | 1866-1432-ND |
| 1866-5004-ND | 1866-3518-ND | 1866-1022-ND |
| 1866-1090-ND | 1866-5576-ND | 1866-1023-ND |
| 1866-4911-ND | 1866-5026-ND | 1866-1434-ND |
| 1866-1084-ND | 1866-5032-ND | 1866-1024-ND |
| 1866-1083-ND | 1866-1080-ND | 1866-1435-ND |
| 1866-1086-ND | 1866-1085-ND | 1866-1025-ND |
| 1866-4461-ND | 1866-1091-ND | 1866-1436-ND |
| 1866-1030-ND | 1866-DDR-480B-24-ND | 1866-1437-ND |
| 1866-1027-ND | 1866-DDR-480C-24-ND | 1866-1438-ND |
| 1866-1026-ND | ||
| 1866-1439-ND |
| Manufacturer Part Numbers | ||
| HDR-15-5 | HDR-30-15 | DDR-480C-48 |
| HDR-15-12 | DDR-15L-5 | TDR-960-48 |
| MDR-10-24 | MDR-40-5 | HDR-15-15 |
| HDR-15-24 | HDR-60-15 | HDR-30-5 |
| MDR-20-5 | MDR-40-48 | DDR-15G-3.3 |
| MDR-20-12 | EDR-75-24 | HDR-60-48 |
| MDR-20-24 | EDR-75-12 | MDR-60-48 |
| HDR-30-12 | DDR-30G-5 | DRA-60-12 |
| DDR-15G-5 | HDR-100-15N | EDR-120-48 |
| DDR-15L-12 | DDR-60G-15 | DDR-60L-5 |
| DDR-15G-12 | DDR-60G-5 | SDR-75-24 |
| DDR-15G-24 | WDR-60-5 | HDR-150-15 |
| HDR-60-24 | DDR-480D-48 | DDR-120D-24 |
| HDR-60-5 | HDR-15-48 | WDR-120-12 |
| HDR-60-12 | MDR-10-15 | DDR-480B-12 |
| MDR-40-24 | HDR-30-48 | DDR-480B-48 |
| MDR-40-12 | HDR-100-12N | DDR-15L-3.3 |
| MDR-60-12 | TDR-960-24 | DDR-30G-15 |
| MDR-60-5 | DR-15-15 | DDR-60L-15 |
| MDR-60-24 | DDR-15L-24 | DDR-30L-15 |
| DDR-30G-12 | DDR-30L-5 | DDR-480D-24 |
| DDR-30L-24 | DDR-30L-12 | DR-4505 |
| EDR-120-12 | NDR-75-48 | DRA-40-24 |
| EDR-150-24 | NDR-75-24 | DR-4512 |
| HDR-100-24 | EDR-120-24 | EDR-75-48 |
| HDR-100-24N | DDR-60G-24 | HDR-100-15 |
| DRC-40A | DDR-60L-12 | DRC-40B |
| NDR-120-48 | DDR-60L-24 | DLP-04R |
| NDR-120-12 | DRC-60A | SDR-75-48 |
| DDR-60G-12 | DDR-120B-24 | WDR-60-48 |
| SDR-75-12 | DDR-240B-48 | KNX-20E-640 |
| MDR-100-12 | DDR-240C-48 | DRP-480-24 |
| MDR-100-24 | TDR-480-24 | KNX-40E-1280 |
| HDR-150-24 | SDR-960-24 | KNX-40E-1280D |
| WDR-60-24 | MDR-20-15 | DR-100-12 |
| WDR-60-12 | DDR-15G-15 | DR-100-15 |
| DRC-100A | DRA-60-24 | DR-100-24 |
| DRC-100B | NDR-75-12 | DR-120-12 |
| NDR-240-24 | HDR-100-48 | DR-120-24 |
| NDR-240-48 | HDR-100-12 | DR-120-48 |
| DDR-120A-48 | DRC-60B | DR-15-12 |
| DDR-120A-24 | MDR-100-48 | DR-15-24 |
| DDR-120B-12 | HDR-150-48 | DR-15-5 |
| DDR-120C-48 | DDR-240D-24 | DR-30-12 |
| DDR-120C-24 | WDR-480-48 | DR-30-15 |
| DDR-120B-48 | DDR-480C-12 | DR-30-24 |
| SDR-120-12 | DDR-15L-15 | DR-30-5 |
| SDR-120-24 | DRA-40-12 | DR-4515 |
| WDR-120-24 | HDR-100-48N | DR-4524 |
| TDR-240-24 | DDR-120D-12 | DR-60-12 |
| DDR-240C-24 | DDR-120D-48 | DR-60-15 |
| DDR-240B-24 | TDR-240-48 | DR-60-24 |
| DDR-240D-48 | DDR-480D-12 | DR-75-12 |
| SDR-240-24 | DR-60-5 | DR-75-24 |
| SDR-240-48 | WDR-120-48 | DR-75-48 |
| NDR-480-48 | HDR-30-24 | DRH-120-24 |
| NDR-480-24 | DDR-30G-24 | DRH-120-48 |
| WDR-240-48 | NDR-120-24 | DRP-240-24 |
| WDR-240-24 | HDR-150-12 | DRP-240-48 |
| TDR-480-48 | DDR-120A-12 | DRP-480-48 |
| SDR-480-48 | DDR-120C-12 | DRP-480S-24 |
| SDR-480-24 | SDR-120-48 | DRP-480S-48 |
| SDR-480P-48 | SDR-480P-24 | DRT-240-24 |
| SDR-960-48 | WDR-480-24 | DRT-240-48 |
| MDR-10-5 | DDR-480B-24 | DRT-480-24 |
| MDR-10-12 | DDR-480C-24 | DRT-480-48 |
| DRT-960-24 | ||
| DRT-960-48 |
For more information please review the following document:
Connecting Mean Well Power Supplies in Series | Power Supplies Australia (power-supplies-australia.com.au)
