Power over Ethernet (PoE) power supplies provide power to devices using the data transmission lines in Cat. 5E or higher ethernet cables. We are often asked which protocol is used by a specific ethernet switch such as HES6G-4E-2SFP-VLW from Henrich Electronics Corporation. This information is not usually specifically called out in the datasheets.
According to the IEEE802.3af and IEEE802.3at standards there are three modes that are used. They are mode A, mode B, and 4-pair. Which mode you need will be determined by the device you are powering, not the power supply.
Mode A: Uses the same conductors for both data and power transmission, and has two different configurations MDI and MDI-X. However both configurations use the same wire pairs, just reversed in polarity. Mode A uses pins 1 and 2 for one side of the configuration (positive or negative) and uses pins 3 and 6 for the opposite connection.
Mode B: Separates power and data signals by using the spare pairs of wires. Pins 4 and 5 provide the positive voltage connection while pins 7 and 8 provide the negative voltage connection.
4-Pair: Delivers power on all four pairs of wires.
In the table below you can see the PoE parameters.
Image courtesy of Explanation of IEEE 802.3af Power over ethernet – Visiotech (visiotechsecurity.com) please see their website for more information.
To identify which mode your power supply uses please see the datasheets and look for the pin out. For example for our part above HES6G-4E-2SFP-VLW on page two of the datasheet we find:
This indicates that it is a mode B power supply.
Available PoE Power Supplies
Digi-Key Part Numbers | Manufacturer Part Numbers |
993-1370-ND | POE16R-560L6 |
993-POEA30U-1AT-5-R-ND | POEA30U-1AT-5-R |
PD-3501G/AC-US-ND | PD-3501G/AC-US |
TL1926-ND | NPOE-30W-1G |
993-1089-ND | POE45-120 |
993-POE60U-1BT-5-R-ND | POE60U-1BT-5-R |
2303-TP-POE-HP-48G-RC-ND | TP-POE-HP-48G-RC |
993-POE90U-1BT6-R-ND | POE90U-1BT6-R |
PD-9501GR/AC-ND | PD-9501GR/AC |
549-PD-9001GI/DC-ND | PD-9001GI/DC |
288-1662-ND | POE-24 |
549-PD-9001GO-ET/AC-ND | PD-9001GO-ET/AC |
1528-2616-ND | 3785 |
271-2476-ND | PW180KA4800F01 |
271-2478-ND | PW180KB4800F01 |
2303-TP-POE-24-12W-ND | TP-POE-24-12W |
994-1052-ND | POE-48I |
2303-TP-POE-48-ND | TP-POE-48 |
150-PD-9001GR/AT/AC-EU-ND | PD-9001GR/AT/AC-EU |
2303-TP-POE-HP-56G-FBN-ND | TP-POE-HP-56G-FBN |
993-POE90U-560-R-ND | POE90U-560-R |
2303-TP-DC-1248GDX2-HP-ND | TP-DC-1248GDX2-HP |
2303-TP-DCDC-4856GD-BT-ND | TP-DCDC-4856GD-BT |
2303-TP-POE-HP-48GDX2-ND | TP-POE-HP-48GDX2 |
2303-TP-DCDC-A2456GD-BT-ND | TP-DCDC-A2456GD-BT |
993-1087-ND | POE36D-1AT |
4179-SUPT2WAXX-RMDL01-ND | SUPT2WAXX-RMDL01 |
4179-SEBD2APEX-EELE01-ND | SEBD2APEX-EELE01 |
4179-SEBD2APEX-UELE01-ND | SEBD2APEX-UELE01 |
4179-SEBD2APEX-NELE01-ND | SEBD2APEX-NELE01 |
3833-POE-MSPLT-4824P-ND | POE-MSPLT-4824P |
3426-POE-ICO-ND | POE-ICO |
2488-TNS-200IN-ND | TNS-200IN |
2671-CG-POE-CESBT-ND | CG-POE-CESBT |
4040-NV-ECLK-ND | NV-ECLK |
2740-F200-POE-KIT-ND | F200-POE-KIT |
4040-NV-FLXLK-C-ND | NV-FLXLK-C |
3426-POE-GIG-PBXA-16I-ND | POE-GIG-PBXA-16I |
3426-POE-GIG-PBXA-3ST-ND | POE-GIG-PBXA-3ST |
3426-POE-GIG-PBXA-3MC-ND | POE-GIG-PBXA-3MC |
2488-TNS-200IN-24V-ND | TNS-200IN-24V |
4040-NV-ECLK-PLS-ND | NV-ECLK-PLS |
4040-NV-ECLK-BSE-ND | NV-ECLK-BSE |
4040-NV-ECBSE-1X-ND | NV-ECBSE-1X |
4040-NV-ECLK-PLS-1X-ND | NV-ECLK-PLS-1X |
4040-NV-FLXLK-ND | NV-FLXLK |
4040-NV-FLXLK-1X-ND | NV-FLXLK-1X |
3833-LNP-201AG-T-ND | LNP-201AG-T |
4040-NV-EC-04-ND | NV-EC-04 |
4040-NV-ECLK-PLS-XKIT-ND | NV-ECLK-PLS-XKIT |
4040-NV-PL-PA011-6-ND | NV-PL-PA011-6 |
4040-NV-EC-04-XKIT-ND | NV-EC-04-XKIT |
993-POE16R-1AFG6-2-R-ND | POE16R-1AFG6-2-R |
993-POE60U-1BTE-R-ND | POE60U-1BTE-R |
549-PD-9501GI/DCF-ND | PD-9501GI/DCF |
993-POE15M-560E-R-ND | POE15M-560E-R |
1939-1046-ND | GT-96300-3648-T3-PP |
2303-TP-POE-24-10G-ND | TP-POE-24-10G |
2303-TP-POE+10G-ND | TP-POE+10G |
2303-TP-POE-24-ND | TP-POE-24 |
2303-TP-POE-HP-24G-ND | TP-POE-HP-24G |
150-PD-9001GR/SP/AC-US-ND | PD-9001GR/SP/AC-US |
288-1663-ND | POE-48 |
1939-1043-ND | GT-96180-1856-T2APOE |
1939-1045-ND | GT-96300-3648-T2-PP |
2287-T0005669-ND | T0005669 |
994-1049-ND | POE-24I |
2303-TP-POE++10G-ND | TP-POE++10G |
1939-1698-ND | GT966007056-T3-APOE |
2303-TP-POE-HP-48G-ND | TP-POE-HP-48G |
994-1051-ND | POE-24IR-CI |
150-PD-9501GC/AC-EU-ND | PD-9501GC/AC-EU |
1939-1902-ND | GT-96180-1856R2APOE |
2283-TL-POE-ND | TL-POE |
150-PD-9001GR/AT/AC-JP-ND | PD-9001GR/AT/AC-JP |
150-PD-9501GC/AC-JP-ND | PD-9501GC/AC-JP |
150-PD-9001GR/SP/AC-EU-ND | PD-9001GR/SP/AC-EU |
150-PD-9601-10GC/AC-UK-ND | PD-9601-10GC/AC-UK |
150-PD-9601-10GC/AC-ND | PD-9601-10GC/AC |
150-PD-9601-10GC/AC-EU-ND | PD-9601-10GC/AC-EU |
150-PD-9601-10GC/AC-JP-ND | PD-9601-10GC/AC-JP |
150-PD-9601-10GC/AC-US-ND | PD-9601-10GC/AC-US |
2287-KITPOEOUTDOOR-ND | KITPOEOUTDOOR |
1939-GT-96180-1830-T3-PP-ND | GT-96180-1830-T3-PP |
1939-GT-96180-1819-T2-PP-ND | GT-96180-1819-T2-PP |
1939-1576-ND | WR9QX375PPOENR6B |
1939-1033-ND | GT-96180-1818-T2-PP |
1939-1037-ND | GT-96180-1824-T2-PP |
1939-1039-ND | GT-96180-1830-T2-PP |
1939-1036-ND | GT-96180-1819-T3-PP |
1939-1034-ND | GT-96180-1818-T3-PP |
2287-T0005671-ND | T0005671 |
993-1078-ND | POE20D-1AF |
993-POEA30U-560-X-R-ND | POEA30U-560-X-R |
993-1150-ND | POE125U-8-C |
150-PD-9501GR/AC-JP-ND | PD-9501GR/AC-JP |
150-PD-9001-10GC/AC-EU-ND | PD-9001-10GC/AC-EU |
150-PD-3504G/AC-EU-ND | PD-3504G/AC-EU |
150-PD-9501GR/SP/AC-US-ND | PD-9501GR/SP/AC-US |
150-PD-9024G/ACDC/M-US-ND | PD-9024G/ACDC/M-US |
2266-PW180KB4800F03-ND | PW180KB4800F03 |
2671-CG-PWRPNESTKIT-ND | CG-PWRPNESTKIT |
3922-DITDTK-MRJETHS-ND | DIT DTK-MRJETHS |
4017-ACC-POE-ND | ACC-POE |
3922-DITDTK-MRJPOE-ND | DIT DTK-MRJPOE |
2671-CG-POE-CESAT-ND | CG-POE-CESAT |
2996-POE-171A-60-ND | POE-171A-60 |
2666-CWMJ8-POE-C6A-ND | CWMJ8-POE-C6A |
3922-INT561211-ND | INT 561211 |
3922-SIGFO-EC30100-ND | SIG FO-EC30100 |
3922-SIGFO-065-18POEINJZ-ND | SIG FO-065-18POEINJZ |
3833-INJ-0200G-60-24-T-ND | INJ-0200G-60-24-T |
3833-INJ-C200G-BT-T-ND | INJ-C200G-BT-T |
4040-NV-FLX-04-ND | NV-FLX-04 |
3833-INJ-C201G-BT-T-ND | INJ-C201G-BT-T |
3833-INJ-24-ND | INJ-24 |
3833-TINJ-101-M12-24V-ND | TINJ-101-M12-24V |
3922-SIGFO-EC30040-ND | SIG FO-EC30040 |
3922-SIGFO-EI30100-ND | SIG FO-EI30100 |
3922-SIGFO-EC30130-ND | SIG FO-EC30130 |
3922-SIGFO-EC30110-ND | SIG FO-EC30110 |
3922-SIGFO-EC30010-ND | SIG FO-EC30010 |
3922-SIGFO-EC30030-ND | SIG FO-EC30030 |
3922-SIGFO-EC30020-ND | SIG FO-EC30020 |
3833-INJ-24A-ND | INJ-24A |
3833-INJ-24-T-ND | INJ-24-T |
3833-27030078-ND | 27030078 |
3922-SIGFO-EI30130-ND | SIG FO-EI30130 |
3922-SIGFO-EI30110-ND | SIG FO-EI30110 |
3833-INJ-24A-T-ND | INJ-24A-T |
993-POE15M-1AFE-R-ND | POE15M-1AFE-R |
POE29U-1AT(PL)D-R-ND | POE29U-1AT(PL)D-R |
1939-1048-ND | GT96300-3656-T3-APOE |
993-1080-ND | POE21-120 |
993-1081-ND | POE21-240 |
150-PD-9001GR/AT/AC-US-ND | PD-9001GR/AT/AC-US |
993-POE90U-1BT-5-R-ND | POE90U-1BT-5-R |
993-1076-ND | POE14-050 |
150-PD-3501G/AC-EU-ND | PD-3501G/AC-EU |
150-PD-9001GR/AT/AC-ND | PD-9001GR/AT/AC |
549-PD-OUT/SP11-ND | PD-OUT/SP11 |
PD-9501GR/AC-US-ND | PD-9501GR/AC-US |
150-PD-9501GC/AC-US-ND | PD-9501GC/AC-US |
2303-TP-DC-2448GDX2-HP-ND | TP-DC-2448GDX2-HP |
1939-1042-ND | GT-96180-1848-T3-PP |
1939-1038-ND | GT-96180-1824-T3-PP |
1939-1041-ND | GT-96180-1848-T2-PP |
1939-1044-ND | GT96180-1856T3-APOE |
1939-1904-ND | GT-96300-3656-R2-AP |
1939-1905-ND | GT-96300-3656-R3A-AP |
1939-1699-ND | GT966007056-T3-PPOE |
994-1048-ND | POE-18I |
994-1215-ND | POE-48ID |
150-PD-9501GCI/DC-ND | PD-9501GCI/DC |
1528-1770-ND | 3239 |
1939-1903-ND | GT-96180-1856R3APOE |
2359-AL-PWS-8D-ND | AL-PWS-8D |
150-PD-9601GC/AC-US-ND | PD-9601GC/AC-US |
150-PD-9501-10GC/AC-EU-ND | PD-9501-10GC/AC-EU |
150-PD-9501-10GC/AC-US-ND | PD-9501-10GC/AC-US |
150-PD-9004G/AC-ND | PD-9004G/AC |
150-PD-9501GCO/AC-ND | PD-9501GCO/AC |
2303-TPDIN-1256GD-BT-ND | TPDIN-1256GD-BT |
150-PD-9601GCO/AC-ND | PD-9601GCO/AC |
150-PD-9501-10GCO/AC-ND | PD-9501-10GCO/AC |
150-PD-9512GC/AC-US-ND | PD-9512GC/AC-US |
2266-PW180KA4800N01-ND,271-2477-ND | PW180KA4800N01 |
2266-PW180KB4800N01-ND,271-2479-ND | PW180KB4800N01 |
PENB1020B4800F01-ND | PENB1020B4800F01 |
1939-GT-96300-3624-T3-PP-ND | GT-96300-3624-T3-PP |
1939-GT-96300-3656-T2APOE-ND | GT-96300-3656-T2APOE |
3833-TP-POE-24IR-CI-ND,2303-TP-POE-24IR-CI-ND | TP-POE-24IR-CI |
POEA30U-1ATE-R-ND | POEA30U-1ATE-R |
BB-806-39800-ND | BB-806-39800 |
POE-24I-CI-ND | POE-24I-CI |
3833-TP-POE-48G-ND,2303-TP-POE-48G-ND | TP-POE-48G |
3833-TP-POE-24G-ND,2303-TP-POE-24G-ND | TP-POE-24G |
3833-TP-POE-18G-ND,2303-TP-POE-18G-ND | TP-POE-18G |
150-PD-3501G/AC-NC-ND | PD-3501G/AC-NC |
150-PD-3501G/AC-CN-ND | PD-3501G/AC-CN |
150-PD-3501G/AC-TW-ND | PD-3501G/AC-TW |
150-PD-3501G/AC-AUS-ND | PD-3501G/AC-AUS |
150-PD-3501G/AC-BR-ND | PD-3501G/AC-BR |
150-PD-3501G/AC-JP-ND | PD-3501G/AC-JP |
150-PD-3501G/AC-UK-ND | PD-3501G/AC-UK |
3833-TP-POE-48GD-ND,2303-TP-POE-48GD-ND | TP-POE-48GD |
3833-TP-POE-1824G-ND,2303-TP-POE-1824G-ND | TP-POE-1824G |
POE-HP-24I-ND | POE-HP-24I |
POE-HP-50I-ND | POE-HP-50I |
150-PD-AS-951/12-24-ND | PD-AS-951/12-24 |
3833-TP-POE-2456GD-ND,2303-TP-POE-2456GD-ND | TP-POE-2456GD |
150-PD-9001GR/AT/AC-AU-ND | PD-9001GR/AT/AC-AU |
150-PD-9001GR/AT/AC-UK-ND | PD-9001GR/AT/AC-UK |
3833-TP-POE-HP-48GD-ND,2303-TP-POE-HP-48GD-ND | TP-POE-HP-48GD |
3833-TP-MS4X4-ND,2303-TP-MS4X4-ND | TP-MS4X4 |
993-POE90U-1BT6-A-RC-ND | POE90U-1BT6-A-RC |
993-POE90U-560-5-R-ND | POE90U-560-5-R |
150-PD-9501GR/AC-EU-ND | PD-9501GR/AC-EU |
150-PD-9501GC/AC-ND | PD-9501GC/AC |
150-PD-9501GC/AC-UK-ND | PD-9501GC/AC-UK |
150-PD-9501G/48VDC-ND | PD-9501G/48VDC |
150-PD-9001GR/SP/AC-UK-ND | PD-9001GR/SP/AC-UK |
150-PD-9001GR/SP/AC-ND | PD-9001GR/SP/AC |
150-PD-9001GR/SP/AC-JP-ND | PD-9001GR/SP/AC-JP |
150-PD-9001GR/SP/AC-AU-ND | PD-9001GR/SP/AC-AU |
150-PD-9001-10GC/AC-UK-ND | PD-9001-10GC/AC-UK |
150-PD-9001-10GC/AC-ND | PD-9001-10GC/AC |
150-PD-9001-10GC/AC-JP-ND | PD-9001-10GC/AC-JP |
150-PD-9001-10GC/AC-US-ND | PD-9001-10GC/AC-US |
3833-TP-POE-HP-56G-ND,2303-TP-POE-HP-56G-ND | TP-POE-HP-56G |
150-PD-9601GC/AC-EU-ND | PD-9601GC/AC-EU |
150-PD-9601GC/AC-JP-ND | PD-9601GC/AC-JP |
150-PD-9601GC/AC-ND | PD-9601GC/AC |
150-PD-9601GC/AC-UK-ND | PD-9601GC/AC-UK |
993-1156-ND | POE125U-8-N |
100-POE-SPL-12BB-ND | 100-POE-SPL-12 |
150-PD-9501-10GC/AC-UK-ND | PD-9501-10GC/AC-UK |
150-PD-9501-10GC/AC-JP-ND | PD-9501-10GC/AC-JP |
150-PD-9501-10GC/AC-ND | PD-9501-10GC/AC |
150-PD-9501-10GC/AC-CN-ND | PD-9501-10GC/AC-CN |
2303-TP-DC-1256G-VHP-ND | TP-DC-1256G-VHP |
2303-TP-DC-1256GD-BT-ND | TP-DC-1256GD-BT |
2303-TP-DC-1256GD-VHP-ND | TP-DC-1256GD-VHP |
993-POE240U-4BT-R-ND | POE240U-4BT-R |
2891042-ND | 2891042 |
3833-TP-MS4G-VHP-ND,2303-TP-MS4G-VHP-ND | TP-MS4G-VHP |
993-POE240U-4BT-N-R-ND | POE240U-4BT-N-R |
150-PD-9501GCS/AC-ND | PD-9501GCS/AC |
150-PD-9501GCS/AC-JP-ND | PD-9501GCS/AC-JP |
150-PD-9501GCS/AC-EU-ND | PD-9501GCS/AC-EU |
150-PD-9501GCS/AC-UK-ND | PD-9501GCS/AC-UK |
150-PD-9501GCS/AC-US-ND | PD-9501GCS/AC-US |
288-1667-ND | JB-POE-24 |
288-1671-ND | JB-POE-48 |
150-PD-9004G/AC-AU-ND | PD-9004G/AC-AU |
150-PD-9004G/AC-JP-ND | PD-9004G/AC-JP |
150-PD-9004G/AC-EU-ND | PD-9004G/AC-EU |
150-PD-9004G/AC-US-ND | PD-9004G/AC-US |
150-PD-9004G/AC-UK-ND | PD-9004G/AC-UK |
993-1172-ND | POE576U-8AT |
993-1154-ND | POE125U-4-AT-N |
150-PD-9501GO/48VDC-ND | PD-9501GO/48VDC |
150-PD-9601GO/AC-ND | PD-9601GO/AC |
993-1168-ND | POE576U-16AT |
3833-TP-MS308-ND,2303-TP-MS308-ND | TP-MS308 |
942200001-ND | 942200001 |
150-PD-6512G/AC/M-US-ND | PD-6512G/AC/M-US |
150-PD-6512G/AC/M-JP-ND | PD-6512G/AC/M-JP |
150-PD-6512G/AC/M-UK-ND | PD-6512G/AC/M-UK |
150-PD-6512G/AC/M-ND | PD-6512G/AC/M |
150-PD-6512G/AC/M-AU-ND | PD-6512G/AC/M-AU |
150-PD-6512G/AC/M-EU-ND | PD-6512G/AC/M-EU |
943979001-ND | 943979001 |
3833-TP-MS316-ND,2303-TP-MS316-ND | TP-MS316 |
943980001-ND | 943980001 |
150-PD-6524G/AC/M/F-EU-ND | PD-6524G/AC/M/F-EU |
150-PD-6524G/AC/M/F-JP-ND | PD-6524G/AC/M/F-JP |
150-PD-6524G/AC/M/F-UK-ND | PD-6524G/AC/M/F-UK |
150-PD-6524G/AC/M/F-US-ND | PD-6524G/AC/M/F-US |
150-PD-6524G/AC/M/F-ND | PD-6524G/AC/M/F |
150-PD-6524G/AC/M/F-AU-ND | PD-6524G/AC/M/F-AU |
3833-TP-MS324-ND,2303-TP-MS324-ND | TP-MS324 |
3833-TP-MS616-ND,2303-TP-MS616-ND | TP-MS616 |
150-PD-9006G/ACDC/M-EU-ND | PD-9006G/ACDC/M-EU |
150-PD-9006G/ACDC/M-AU-ND | PD-9006G/ACDC/M-AU |
150-PD-9006G/ACDC/M-JP-ND | PD-9006G/ACDC/M-JP |
150-PD-9006G/ACDC/M-ND | PD-9006G/ACDC/M |
150-PD-9006G/ACDC/M-UK-ND | PD-9006G/ACDC/M-UK |
150-PD-9006G/ACDC/M-US-ND | PD-9006G/ACDC/M-US |
3833-TP-MS616-ISO-ND,2303-TP-MS616-ISO-ND | TP-MS616-ISO |
150-PD-9012G/ACDC/M-ND | PD-9012G/ACDC/M |
150-PD-9012G/ACDC/M-AU-ND | PD-9012G/ACDC/M-AU |
150-PD-9012G/ACDC/M-EU-ND | PD-9012G/ACDC/M-EU |
150-PD-9012G/ACDC/M-UK-ND | PD-9012G/ACDC/M-UK |
150-PD-9506GC/AC-ND | PD-9506GC/AC |
150-PD-9506GC/AC-US-ND | PD-9506GC/AC-US |
150-PD-9012G/ACDC/M-US-ND | PD-9012G/ACDC/M-US |
150-PD-9506GC/AC-EU-ND | PD-9506GC/AC-EU |
150-PD-9506GC/AC-JP-ND | PD-9506GC/AC-JP |
150-PD-9506GC/AC-UK-ND | PD-9506GC/AC-UK |
150-PD-9506GC/AC-AU-ND | PD-9506GC/AC-AU |
150-PD-9012G/ACDC/M-JP-ND | PD-9012G/ACDC/M-JP |
150-PD-9506-10GC/AC-AU-ND | PD-9506-10GC/AC-AU |
150-PD-9506-10GC/AC-EK-ND | PD-9506-10GC/AC-EK |
150-PD-9506-10GC/AC-ND | PD-9506-10GC/AC |
150-PD-9506-10GC/AC-JP-ND | PD-9506-10GC/AC-JP |
150-PD-9506-10GC/AC-US-ND | PD-9506-10GC/AC-US |
150-PD-9606GC/AC-US-ND | PD-9606GC/AC-US |
150-PD-9606GC/AC-AU-ND | PD-9606GC/AC-AU |
150-PD-9606GC/AC-EU-ND | PD-9606GC/AC-EU |
150-PD-9606GC/AC-JP-ND | PD-9606GC/AC-JP |
150-PD-9606GC/AC-ND | PD-9606GC/AC |
150-PD-9606GC/AC-UK-ND | PD-9606GC/AC-UK |
150-PD-9024G/ACDC/M-EU-ND | PD-9024G/ACDC/M-EU |
150-PD-9024G/ACDC/M-JP-ND | PD-9024G/ACDC/M-JP |
150-PD-9024G/ACDC/M-AU-ND | PD-9024G/ACDC/M-AU |
150-PD-9024G/ACDC/M-BR-ND | PD-9024G/ACDC/M-BR |
150-PD-9024G/ACDC/M-UK-ND | PD-9024G/ACDC/M-UK |
150-PD-9512GC/AC-JP-ND | PD-9512GC/AC-JP |
150-PD-9512GC/AC-ND | PD-9512GC/AC |
150-PD-9512GC/AC-UK-ND | PD-9512GC/AC-UK |
150-PD-9512GC/AC-AU-ND | PD-9512GC/AC-AU |
150-PD-9512GC/AC-EU-ND | PD-9512GC/AC-EU |
150-PD-9512-10GC/AC-JP-ND | PD-9512-10GC/AC-JP |
150-PD-9512-10GC/AC-US-ND | PD-9512-10GC/AC-US |
150-PD-9512-10GC/AC-ND | PD-9512-10GC/AC |
150-PD-9512-10GC/AC-AU-ND | PD-9512-10GC/AC-AU |
150-PD-9512-10GC/AC-EK-ND | PD-9512-10GC/AC-EK |
150-PD-9612GC/AC-AU-ND | PD-9612GC/AC-AU |
150-PD-9612GC/AC-UK-ND | PD-9612GC/AC-UK |
150-PD-9612GC/AC-ND | PD-9612GC/AC |
150-PD-9612GC/AC-US-ND | PD-9612GC/AC-US |
150-PD-9612GC/AC-EU-ND | PD-9612GC/AC-EU |
150-PD-9612GC/AC-JP-ND | PD-9612GC/AC-JP |
150-PD-9524GC/AC-AU-ND | PD-9524GC/AC-AU |
150-PD-9524GC/AC-JP-ND | PD-9524GC/AC-JP |
150-PD-9524GC/AC-ND | PD-9524GC/AC |
150-PD-9524GC/AC-US-ND | PD-9524GC/AC-US |
150-PD-9524GC/AC-EU-ND | PD-9524GC/AC-EU |
150-PD-9524GC/AC-UK-ND | PD-9524GC/AC-UK |
150-PD-9624GC/AC-ND | PD-9624GC/AC |
150-PD-9624GC/AC-US-ND | PD-9624GC/AC-US |
150-PD-9624GC/AC-AU-ND | PD-9624GC/AC-AU |
150-PD-9624GC/AC-EU-ND | PD-9624GC/AC-EU |
150-PD-9624GC/AC-UK-ND | PD-9624GC/AC-UK |
150-PD-9624GC/AC-JP-ND | PD-9624GC/AC-JP |
150-PD-9524-10GC/AC-ND | PD-9524-10GC/AC |
150-PD-9524-10GC/AC-EK-ND | PD-9524-10GC/AC-EK |
150-PD-9524-10GC/AC-AU-ND | PD-9524-10GC/AC-AU |
150-PD-9524-10GC/AC-JP-ND | PD-9524-10GC/AC-JP |
150-PD-9524-10GC/AC-US-ND | PD-9524-10GC/AC-US |
1528-1779-ND | 3238 |
3922-TRETPE-104GS-ND | TRE TPE-104GS |
3922-INT524179-ND | INT 524179 |
4111-SE05-0009-ND | SE05-0009 |
3833-TP-POE-48G-24W-ND | TP-POE-48G-24W |
3922-INT561518-ND | INT 561518 |
3922-DITDTK-MRJPOES-ND | DIT DTK-MRJPOES |
2666-MJ8-POE-C6A-ND | MJ8-POE-C6A |
3922-TRETPE-117GI-ND | TRE TPE-117GI |
2740-RXT-POE-KIT-ND | RXT-POE-KIT |
2996-POE-171A-95-ND | POE-171A-95 |
3833-SPL-101GT-AT-ND | SPL-101GT-AT |
3833-05059984-ND | 5059984 |
3833-INJ-102GT-ND | INJ-102GT |
3833-INJ-102GT-24V-ND | INJ-102GT-24V |
4040-NV-FLXLK-BSE-ND | NV-FLXLK-BSE |
4040-NV-FLXBSE-1X-ND | NV-FLXBSE-1X |
4040-NV-EC1701PLS-BSE-ND | NV-EC1701PLS-BSE |
3833-TINJ-101GT-M12-ND | TINJ-101GT-M12 |
3833-INJ-102GT+±24V-ND | INJ-102GT+±24V |
3833-INJ-101GT+±60W-24V-ND | INJ-101GT+±60W-24V |
3833-INJ-C201G-BT-100-T-ND | INJ-C201G-BT-100-T |
3833-INJ-C201G-BT-24-T-ND | INJ-C201G-BT-24-T |
3833-INJ-C201G-BT-100-24-T-ND | INJ-C201G-BT-100-24-T |
3833-CL141E/BT90/52-ND | CL141E/BT90/52 |
4040-NV-FLXLK-XKIT-ND | NV-FLXLK-XKIT |
3922-DITDTK-RM12POES-ND | DIT DTK-RM12POES |
4040-NV-FLX-04-XKIT-ND | NV-FLX-04-XKIT |
3833-CL141E/BT90/EUI-ND | CL141E/BT90/EUI |
LS15RB0501J01-ND | LS15RB0501J01 |
LS15RB1201J01-ND | LS15RB1201J01 |
LS15RB2401J01-ND | LS15RB2401J01 |
2266-LS15RB1201J04-ND,271-2626-ND | LS15RB1201J04 |
POE-18I-EU-ND | POE-18I-EU |
POE-18I-INT-ND | POE-18I-INT |
POE-24I-EU-ND | POE-24I-EU |
POE-24I-INT-ND | POE-24I-INT |
POE-24S-AFI–ND | POE-24S-AFI- |
POE-48I-CI-EU-ND | POE-48I-CI-EU |
POE-48I-INT-ND | POE-48I-INT |
POE-48I5S-AFI-ND | POE-48I5S-AFI |
POE-48ID-EU-ND | POE-48ID-EU |
POE-4X18I-ND | POE-4X18I |
POE-4X24I-ND | POE-4X24I |
POE-4X48I-ND | POE-4X48I |
POE-4X48I-AFI-ND | POE-4X48I-AFI |
POE-9S-AFI-ND | POE-9S-AFI |
POE-HP-50I-EU-ND | POE-HP-50I-EU |
POE-PS-150-001-ND | POE-PS-150-001 |
POE-24I-L-ND | POE-24I-L |
POE-9S-AFI–ND | POE-9S-AFI- |
PENB1020B4800N01-ND | PENB1020B4800N01 |
HNT000754-ND | HNT000754 |
993-1418-ND | POE15M-1AF |
993-POE15M-560-R-ND | POE15M-560-R |
150-PD-9024G/ACDC/M-ND | PD-9024G/ACDC/M |
150-PD-9006G/ACDC/M-EK-ND | PD-9006G/ACDC/M-EK |
150-PD-3504G/AC-ND | PD-3504G/AC |
150-PD-3501GC/AC-US-ND | PD-3501GC/AC-US |
150-PD-9501GR/AC-AU-ND | PD-9501GR/AC-AU |
150-PD-3501GC/AC-EU-ND | PD-3501GC/AC-EU |
150-PD-3504G/AC-AU-ND | PD-3504G/AC-AU |
150-PD-6524G/AC/M/F-EK-ND | PD-6524G/AC/M/F-EK |
150-PD-9512G/ACDC/M-ND | PD-9512G/ACDC/M |
150-PD-9501GR/AC-UK-ND | PD-9501GR/AC-UK |
150-PD-9501GR/AC-BR-ND | PD-9501GR/AC-BR |
150-PD-9612G/ACDC/M-ND | PD-9612G/ACDC/M |
150-PD-9524G/ACDC/M-ND | PD-9524G/ACDC/M |
150-PD-3504G/AC-UK-ND | PD-3504G/AC-UK |
150-PD-9012G/ACDC/M-EK-ND | PD-9012G/ACDC/M-EK |
150-PD-6512G/AC/M-EK-ND | PD-6512G/AC/M-EK |
150-PD-9601G/AC-JP-ND | PD-9601G/AC-JP |
150-PD-9501GR/SP/AC-ND | PD-9501GR/SP/AC |
150-PD-3504G/AC-US-ND | PD-3504G/AC-US |
150-PD-9501GR/SP/AC-AU-ND | PD-9501GR/SP/AC-AU |
150-PD-9601G/AC-EU-ND | PD-9601G/AC-EU |
150-PD-9501-10G/AC-ND | PD-9501-10G/AC |
150-PD-9501GR/SP/AC-JP-ND | PD-9501GR/SP/AC-JP |
150-PD-9001GCO/AC-ND | PD-9001GCO/AC |
150-PD-9501G-SFP/AC-ND | PD-9501G-SFP/AC |
150-PD-9506G/ACDC/M-ND | PD-9506G/ACDC/M |
150-PD-3501GC/AC-JP-ND | PD-3501GC/AC-JP |
150-PD-9501GR/SP/AC-UK-ND | PD-9501GR/SP/AC-UK |
150-PD-3501GC/AC-UK-ND | PD-3501GC/AC-UK |
150-PD-3504G/AC-JP-ND | PD-3504G/AC-JP |
150-PD-9501GR/SP/AC-EU-ND | PD-9501GR/SP/AC-EU |
150-PD-3501GC/AC-ND | PD-3501GC/AC |
150-PD-9524GC/AC-EK-ND | PD-9524GC/AC-EK |
150-PD-9601G/AC-UK-ND | PD-9601G/AC-UK |
150-PD-9501GO/12-24VDC-ND | PD-9501GO/12-24VDC |
993-POE90U-1BT-N6-R-ND | POE90U-1BT-N6-R |
993-POE90U-560-X-R-ND | POE90U-560-X-R |
993-POEA30U-560E-R-ND | POEA30U-560E-R |
993-POEA30U-1AT-2-R-ND | POEA30U-1AT-2-R |
993-POE60U-1BT-X-R-ND | POE60U-1BT-X-R |
993-POEA30U-560-5-R-ND | POEA30U-560-5-R |
993-POE90U-1BT-2-R-ND | POE90U-1BT-2-R |
993-POEA30U-560-2-R-ND | POEA30U-560-2-R |
993-POE90U-560-2-R-ND | POE90U-560-2-R |
993-POE60U-1BT-2-R-ND | POE60U-1BT-2-R |
993-POE90U-1BT-X-R-ND | POE90U-1BT-X-R |
993-POEA30U-1AT-X-R-ND | POEA30U-1AT-X-R |
993-POE60U-560E-R-ND | POE60U-560E-R |
993-POE806U-8BT-R-ND | POE806U-8BT-R |
993-POE60U-560-5-R-ND | POE60U-560-5-R |
993-POEA30U-560-R-ND | POEA30U-560-R |
993-POE150-ND | POE150 |
993-POE75U-1BT-R-ND | POE75U-1BT-R |
993-POE15W-560-R-ND | POE15W-560-R |
993-POEO30U-1AT-R-ND | POEO30U-1AT-R |
993-POE120-8AF-ND | POE120-8AF |
993-POE120-4AT-R-ND | POE120-4AT-R |
993-POE60U-560-X-R-ND | POE60U-560-X-R |
993-POEO75U-1BT-R-ND | POEO75U-1BT-R |
993-POE60U-560-2-R-ND | POE60U-560-2-R |
993-POE806U-8BT-N-R-ND | POE806U-8BT-N-R |
993-POE450-ND | POE450 |
993-POE16R-1AFG6-R-ND | POE16R-1AFG6-R |
993-POE60U-1BTE-A-RC-ND | POE60U-1BTE-A-RC |
993-POE16R-1AF6-2-R-ND | POE16R-1AF6-2-R |
150-PD-9001GC/AC-US-ND | PD-9001GC/AC-US |
150-PD-6506G/AC/M-JP-ND | PD-6506G/AC/M-JP |
150-PD-6506G/AC/M-US-ND | PD-6506G/AC/M-US |
150-PD-9001GC/AC-UK-ND | PD-9001GC/AC-UK |
150-PD-9001-25GR/AC-ND | PD-9001-25GR/AC |
150-PD-9001GC/AC-JP-ND | PD-9001GC/AC-JP |
150-PD-6506G/AC/M-UK-ND | PD-6506G/AC/M-UK |
150-PD-9001-10GR/AC-ND | PD-9001-10GR/AC |
150-PD-9001GC/AC-ND | PD-9001GC/AC |
150-PD-9024G/ACDC/M-EK-ND | PD-9024G/ACDC/M-EK |
150-PD-9001GC/AC-EU-ND | PD-9001GC/AC-EU |
150-PD-6506G/AC/M-EK-ND | PD-6506G/AC/M-EK |
150-PD-6506G/AC/M-ND | PD-6506G/AC/M |
150-PD-6506G/AC/M-AU-ND | PD-6506G/AC/M-AU |
150-PD-6506G/AC/M-EU-ND | PD-6506G/AC/M-EU |
4040-NV-PLLK-6-ND | NV-PLLK-6 |
4040-NV-ECLK-PLS-1X-AB-ND | NV-ECLK-PLS-1X-AB |
4381-7940112380-ND,281-7940112380-ND | 7940112380 |
4040-NV-FLXLK-1X-AB-ND | NV-FLXLK-1X-AB |
