I purchased a power supply FSP330-AAAN3 from your site with P/N 9NA3300209 however it has a different connector than expected.
I looked into this and found that the power supply I need has the same model number, FSP330-AAAN3 however the P/N should be 9NA3300203. Do you have this power supply available?
Hello jhorvath,
This part is sold under the part number FSP330-AAAN3, and it should have a 4 pin connector.
If you have a different connector, then it was either specially made to that application from the manufacture, or the OEM for the device changed the output plug.
We do not have another version of this model number. If you have the information on the output plug you need, we can see if we have something else to offer.
Also, to be sure we are searching for the right item, please verify the output voltage and current of your device.
