Powering the Future: Introduction to SoCs and PMICs for Embedded Systems
Introduction
As embedded system continue to grow, traditional microcontrollers often fall short of meeting modern performance, so the demand for higher performance, tighter integration, and energy efficiency has made System-on-Chip (SoC) solutions increasingly popular.
Unlike traditional microcontrollers that often require a single supply voltage, SoCs typically demand multiple power rails, each with specific voltage levels, current capabilities, sequencing requirements, and timing constraints. Failing to meet these requirements can lead to unreliable operation, reduced performance, or even permanent damage to the device.
This article explores the fundamentals of powering SoCs using PMICs basics and show the difference between Traditional power management and PMIC solution.
What Is an SoC?
A System-on-Chip (SoC) integrates the essential building blocks of a complete computing system onto a single Chip.
This includes the central processing unit (CPU), graphics processing unit (GPU), memory controllers, input/output (I/O) interfaces, and often specialized modules like those used for digital signal processing (DSP), AI accelerators, and wireless communication units (Wi-Fi, Bluetooth®, LTE/5G).
This high level of integration provides advantages such as:
  • Higher performance (Faster switching speed)
  • Compact and power efficient Form-factor
  • Low power consumption and less physical space
  • Low manufacturing costs, and improve reliability
  • Additionally, many SoCs are designed with specific applications in mind, allowing for customization and optimization that further enhances performance and efficiency.
Key features of SoCs include :
  • High integration
  • Energy efficiency
  • Real-time processing capabilities
  • And support for advanced connectivity.
Application of SoCs
Early SoCs were used in embedded systems and mobile phones, but as semiconductor technology advanced, SoCs became more powerful and versatile. Socs are particularly important in portable and wearable devices, where battery life and compact design are critical.
They are the backbone of modern consumer electronics, powering everything from smartphones and tablets to smartwatches, medical devices, smart TVs, automotive systems, and Internet of Things (IoT) devices.
For a wide variety of SoCs, check out the SoC product on DigiKey
What Is a PMIC?
A power management integrated circuit (PMIC) is a highly specialized semiconductor device designed to manage and regulate the power requirements of modern electronic systems.
The PMIC acts as the central hub for power distribution, ensuring that each subsystem receives the correct amount of power at the right time, while also optimizing energy usage to extend battery life and reduce heat generation.
PMICs typically integrate several key functions into a single chip, including
  • Voltage regulation (via buck, boost, or low dropout (LDO) regulators)
  • Battery charging and monitoring
  • Power sequencing logic
  • Thermal management
  • Fault detection and protection
  • This level of integration not only saves space on the circuit board but also simplifies design and improves overall system reliability.
Application of PMIC
These circuits are essential in complex devices such as smartphones, tablets, laptops, wearables, and embedded systems where multiple components require different voltage and current levels to operate efficiently and reliably.
Initially, power management was handled by discrete components, which were bulky and less efficient. As semiconductor technology advanced, manufacturers began to integrate these functions into single chips, giving rise to the first generation of PMICs. Over time, PMICs evolved to support increasingly sophisticated power architectures, including dynamic voltage scaling and intelligent power gating, which are now standard in energy-conscious designs.
Today, PMICs are a cornerstone of modern electronics, enabling devices to operate longer on smaller batteries, manage thermal loads more effectively, and meet stringent energy efficiency standards. They are especially critical in battery-powered and space-constrained applications, where every milliwatt and millimeter counts.
Discrete vs. PMIC Power Management: Summary Table
Aspect Discrete Power Management PMIC-Based Solution
Component Count Multiple individual components (buck, LDOs, chargers, protection circuits) Single integrated chip with all major power functions
Design Flexibility High – can select each component individually Moderate – integration may limit customization
PCB Footprint Large Small – ideal for compact designs
Design Complexity High – requires careful coordination of multiple parts Lower – simplified by integration
Thermal & EMI Management More challenging due to spread-out components Easier – centralized power control improves management
Power Sequencing Manual or requires additional logic Often built-in or programmable
Advanced Features Requires separate components for power monitoring, protection, and communication Frequently included (e.g., fault protection, I²C/SPI interface)
Best Use Cases High-power, custom designs Space-constrained, battery-powered, and portable applications (e.g., wearables)
System Efficiency & Reliability Lower due to part mismatch and longer traces Higher – optimized integration improves overall performance
For a wide variety of PMIC, check out the PMIC product on DigiKey
Conclusion
As SoCs become the backbone of modern electronics, managing their power efficiently is critical. This article introduced the basics of SoCs and PMICs, and how integrated power management offers clear advantages over discrete designs.
What’s Next?
This is part 1 of a 4-part series. Next, we’ll dive into key design factors when powering an SoC:
  1. SoC Power Architecture – Key parameters when designing SoC power (Voltage, current, sequencing, and timing)
  2. Advanced Power Control – Dynamic modes, sequencing, and interface control
  3. PMIC Selection – Real-world use in wearables, medical, and mobile devices
Applicable Part Numbers
DigiKey Part Number Manufacturer Part Number
5128-AMA3B1KK-KCR-TBTR-ND,5128-AMA3B1KK-KCR-TBCT-ND,5128-AMA3B1KK-KCR-TBDKR-ND AMA3B1KK-KCR-TB
5128-AMA4B2KP-KBRTR-ND,5128-AMA4B2KP-KBRCT-ND,5128-AMA4B2KP-KBRDKR-ND AMA4B2KP-KBR
1100-1353-ND M2S010-TQG144I
122-2008-ND XC7Z007S-1CLG400C
122-2002-ND XC7Z007S-1CLG225C
M2S010TS-1VFG256I-ND M2S010TS-1VFG256I
122-1855-ND XC7Z010-1CLG225C
122-1854-ND XC7Z010-1CLG400C
1100-1358-ND M2S025-FCSG325I
150-M2S025T-FCSG158I-ND M2S025T-FCSG158I
1100-1220-ND M2S025-FGG484
122-1963-ND XC7Z010-1CLG400I
122-2100-ND XC7Z010-1CLG225I
1100-1199-ND M2S025-VFG400I
1100-1360-ND M2S025-VFG256I
122-1852-ND XC7Z010-2CLG400I
1100-1234-ND A2F500M3G-FGG484I
122-2010-ND XC7Z014S-1CLG400C
122-2027-ND XC7Z014S-1CLG484C
122-1851-ND XC7Z020-1CLG400C
122-2003-ND XC7Z014S-1CLG400I
122-1850-ND XC7Z020-1CLG484C
122-2028-ND XC7Z014S-1CLG484I
122-1905-ND XC7Z015-1CLG485C
544-3464-ND 5CSEBA2U23I7N
122-2081-ND XC7Z020-1CLG400I
122-1849-ND XC7Z020-1CLG484I
122-2190-ND XC7Z015-1CLG485I
122-1848-ND XC7Z020-2CLG400I
122-2134-ND XA7Z020-1CLG400Q
122-1896-ND XC7Z020-2CLG484I
122-2017-ND XA7Z020-1CLG484Q
122-2088-ND XC7Z015-2CLG485I
122-1895-ND XC7Z020-3CLG484E
M2S090TS-1FCS325I-ND M2S090TS-1FCS325I
122-1894-ND XC7Z030-1FBG484C
1100-1363-ND M2S090-FGG484I
544-2968-ND 5CSXFC6C6U23C8N
122-1892-ND XC7Z030-1FBG676C
122-1893-ND XC7Z030-1FBG484I
122-2254-ND XCZU2CG-1SBVA484I
M2S090TS-1FGG484I-ND M2S090TS-1FGG484I
M2S090TS-1FG484I-ND M2S090TS-1FG484I
544-3307-ND 5CSEBA6U23I7N
122-2180-ND XC7Z030-1SBG485I
122-1891-ND XC7Z030-1FFG676C
1100-1364-ND M2S150-FCVG484I
150-MPFS250T-FCVG484I-ND MPFS250T-FCVG484I
122-2020-ND XC7Z030-2FBG676I
122-2185-ND XC7Z030-1FFG676I
150-MPFS250T-1FCVG484I-ND MPFS250T-1FCVG484I
122-2262-ND XCZU4CG-1SFVC784I
559-R9A06G037GNP#AA0-ND R9A06G037GNP#AA0
5128-AMA3B2KK-KBRTR-ND,5128-AMA3B2KK-KBRCT-ND,5128-AMA3B2KK-KBRDKR-ND AMA3B2KK-KBR
1711-SC-20100S-A-ND SC-20100S-A
1100-1233-ND A2F200M3F-FGG256I
122-1999-ND XC7Z007S-2CLG400I
1100-1010-ND A2F500M3G-FGG484
5769-MT8390IV/KZATR-ND,5769-MT8390IV/KZACT-ND,5769-MT8390IV/KZADKR-ND MT8390IV/KZA
122-1853-ND XC7Z010-2CLG225I
1100-1362-ND M2S060-FCSG325I
544-3522-ND 5CSEBA4U19I7SN
122-2189-ND XC7Z015-2CLG485E
122-2186-ND XC7Z020-3CLG400E
M2S090T-FCS325I-ND M2S090T-FCS325I
544-3305-ND 5CSEBA6U19I7N
544-3503-ND 5CSXFC5C6U23I7N
544-3525-ND 5CSEMA6F31C6N
XA7Z030-1FBV484Q-ND XA7Z030-1FBV484Q
150-MPFS250T-FCSG536E-ND MPFS250T-FCSG536E
150-MPFS250T-FCSG536I-ND MPFS250T-FCSG536I
122-2258-ND XCZU3CG-1SFVC784E
M2S150T-1FCG1152I-ND M2S150T-1FCG1152I
M2S150T-1FC1152I-ND M2S150T-1FC1152I
122-2263-ND XCZU4CG-2SFVC784I
5128-AMA3B1KK-KBR-B0TR-ND,5128-AMA3B1KK-KBR-B0CT-ND,5128-AMA3B1KK-KBR-B0DKR-ND AMA3B1KK-KBR-B0
505-MAX32655GXG±ND MAX32655GXG+
5128-AMA4B2KP-KXRTR-ND,5128-AMA4B2KP-KXRCT-ND,5128-AMA4B2KP-KXRDKR-ND AMA4B2KP-KXR
122-2012-ND XC7Z007S-1CLG400I
122-2013-ND XC7Z007S-2CLG400E
XA7Z010-1CLG225Q-ND XA7Z010-1CLG225Q
544-3459-ND 5CSEBA4U23C8SN
122-1847-ND XC7Z020-2CLG484E
122-XCZU2CG-1UBVA530I-ND XCZU2CG-1UBVA530I
544-3179-ND 5CSXFC6C6U23I7N
150-MPFS250T-FCVG484E-ND MPFS250T-FCVG484E
122-XAZU1EG-1SFVA625I-ND XAZU1EG-1SFVA625I
122-2055-ND XCZU2CG-L1SFVC784I
150-MPFS250T-1FCVG484E-ND MPFS250T-1FCVG484E
150-MPFS250T-FCG1152E-ND MPFS250T-FCG1152E
150-MPFS250T-1FCSG536E-ND MPFS250T-1FCSG536E
150-MPFS250TS-FCVG484I-ND MPFS250TS-FCVG484I
150-MPFS250TS-1FCVG484I-ND MPFS250TS-1FCVG484I
122-2260-ND XCZU3CG-2SFVC784E
150-MPFS250TLS-FCG1152I-ND MPFS250TLS-FCG1152I
1100-1350-ND M2S005-VFG256
1100-1349-ND M2S005-VFG256I
1100-1346-ND M2S005S-VFG256I
1100-1357-ND M2S010-VFG256
1100-1223-ND M2S025-VFG400
544-3552-ND 5CSEBA2U23C8SN
1100-1221-ND M2S025T-FGG484
122-2014-ND XC7Z012S-1CLG485C
296-TDA4VL21HGAALZRQ1TR-ND,296-TDA4VL21HGAALZRQ1CT-ND,296-TDA4VL21HGAALZRQ1DKR-ND TDA4VL21HGAALZRQ1
1100-1224-ND M2S050-FGG484
1100-1361-ND M2S050-FCSG325I
544-3015-ND 5CSXFC2C6U23C8N
1100-1201-ND M2S050T-FGG484I
544-2966-ND 5CSEBA5U23C8N
1100-1168-ND M2S050T-FGG896
150-M2S060T-VFG784-ND M2S060T-VFG784
544-3018-ND 5CSXFC4C6U23C8N
150-M2S060T-VFG784I-ND M2S060T-VFG784I
150-M2S060T-1VFG784-ND M2S060T-1VFG784
150-M2S060TS-VFG784-ND M2S060TS-VFG784
150-M2S060T-1VFG784I-ND M2S060T-1VFG784I
150-M2S060TS-VFG784I-ND M2S060TS-VFG784I
150-M2S060TS-1VFG784-ND M2S060TS-1VFG784
M2S090-FGG676-ND M2S090-FGG676
150-M2S060TS-1VFG784I-ND M2S060TS-1VFG784I
544-3542-ND 5CSEMA5F31C7N
544-2967-ND 5CSEBA5U23I7N
544-3019-ND 5CSXFC4C6U23I7N
122-XCZU1CG-1UBVA494I-ND XCZU1CG-1UBVA494I
5CSEBA6U19I7NTS-ND 5CSEBA6U19I7NTS
544-3535-ND 5CSEMA6F31C7N
5CSEBA6U23I7NTS-ND 5CSEBA6U23I7NTS
544-3498-ND 5CSEMA6U23I7N
122-XCZU1CG-2UBVA494I-ND XCZU1CG-2UBVA494I
122-XAZU1EG-1SBVA484I-ND XAZU1EG-1SBVA484I
122-XCZU1EG-2UBVA494I-ND XCZU1EG-2UBVA494I
122-2064-ND XAZU2EG-1SFVC784I
150-MPFS250TL-FCVG484E-ND MPFS250TL-FCVG484E
122-XAZU1EG-1SBVA484Q-ND XAZU1EG-1SBVA484Q
5128-AMAPH1KK-KCRTR-ND,5128-AMAPH1KK-KCRCT-ND,5128-AMAPH1KK-KCRDKR-ND AMAPH1KK-KCR
5128-AMAPH1KK-KCR-TBTR-ND,5128-AMAPH1KK-KCR-TBCT-ND,5128-AMAPH1KK-KCR-TBDKR-ND AMAPH1KK-KCR-TB
5128-AMAPH1KK-KBRTR-ND,5128-AMAPH1KK-KBRCT-ND,5128-AMAPH1KK-KBRDKR-ND AMAPH1KK-KBR
5128-AMAP31KK-KCRTR-ND,5128-AMAP31KK-KCRCT-ND,5128-AMAP31KK-KCRDKR-ND AMAP31KK-KCR
5128-AMA3B1KK-KQR-B0TR-ND,5128-AMA3B1KK-KQR-B0CT-ND,5128-AMA3B1KK-KQR-B0DKR-ND AMA3B1KK-KQR-B0
5128-APOLLO512-KCRTR-ND,5128-APOLLO512-KCRCT-ND,5128-APOLLO512-KCRDKR-ND APOLLO512-KCR
5128-AMA3B1KK-KCR-B0TR-ND,5128-AMA3B1KK-KCR-B0CT-ND,5128-AMA3B1KK-KCR-B0DKR-ND AMA3B1KK-KCR-B0
5128-APOLLO512-KBRTR-ND,5128-APOLLO512-KBRCT-ND,5128-APOLLO512-KBRDKR-ND APOLLO512-KBR
5128-AMAP42KL-KBRTR-ND,5128-AMAP42KL-KBRCT-ND,5128-AMAP42KL-KBRDKR-ND AMAP42KL-KBR
5128-AMA4B2KL-KXRTR-ND,5128-AMA4B2KL-KXRCT-ND,5128-AMA4B2KL-KXRDKR-ND AMA4B2KL-KXR
5128-AMAP42KP-KBRTR-ND,5128-AMAP42KP-KBRCT-ND,5128-AMAP42KP-KBRDKR-ND AMAP42KP-KBR
559-R9A08G045S31GBG#BC0-ND R9A08G045S31GBG#BC0
559-R9A08G045S33GBG#BC0-ND R9A08G045S33GBG#BC0
5128-AP510NFA-CBRTR-ND,5128-AP510NFA-CBRCT-ND,5128-AP510NFA-CBRDKR-ND AP510NFA-CBR
559-R9A08G045S31GBG#AC0-ND R9A08G045S31GBG#AC0
568-MIMX9301DVVXDAB-ND MIMX9301DVVXDAB
568-MIMX9302DVVXDAB-ND MIMX9302DVVXDAB
559-R9A08G045S33GBG#AC0-ND R9A08G045S33GBG#AC0
568-MIMX9331DVVXMAB-ND MIMX9331DVVXMAB
568-MIMX9351DVVXMAB-ND MIMX9351DVVXMAB
568-MIMX9351XVVXMAB-ND MIMX9351XVVXMAB
5767-MT8365V/BZBTR-ND,5767-MT8365V/BZBCT-ND,5767-MT8365V/BZBDKR-ND MT8365V/BZB
568-MIMX8MN5DVPIZDA-ND MIMX8MN5DVPIZDA
568-MIMX8MN5DVPIZCA-ND MIMX8MN5DVPIZCA
1676-OSD6254-1G-IPM-ND OSD6254-1G-IPM
568-MIMX8MM5DVTLZCA-ND MIMX8MM5DVTLZCA
568-MIMX8ML8DVNLZCB-ND MIMX8ML8DVNLZCB
568-MIMX8ML8DVNLZDB-ND MIMX8ML8DVNLZDB
5769-MT8385V/AZATR-ND,5769-MT8385V/AZACT-ND,5769-MT8385V/AZADKR-ND MT8385V/AZA
5769-MT8370AV/AZATR-ND,5769-MT8370AV/AZACT-ND,5769-MT8370AV/AZADKR-ND MT8370AV/AZA
122-2009-ND XC7Z007S-1CLG225I
5CSEBA2U19C8SN-ND 5CSEBA2U19C8SN
5769-MT8370IV/KZATR-ND,5769-MT8370IV/KZACT-ND,5769-MT8370IV/KZADKR-ND MT8370IV/KZA
5769-MT8390AV/AZATR-ND,5769-MT8390AV/AZACT-ND,5769-MT8390AV/AZADKR-ND MT8390AV/AZA
M2S025T-1VFG400I-ND M2S025T-1VFG400I
544-A5EA008BB23BE4S-ND A5EA008BB23BE4S
XC7Z010-3CLG400E-ND XC7Z010-3CLG400E
544-A5EA008BB23BE6X-ND A5EA008BB23BE6X
544-A5EA008BB23BI4S-ND A5EA008BB23BI4S
M2S060-1FCSG325I-ND M2S060-1FCSG325I
5769-MT8395AV/ZATR-ND,5769-MT8395AV/ZACT-ND,5769-MT8395AV/ZADKR-ND MT8395AV/ZA
5CSEMA4U23C8N-ND 5CSEMA4U23C8N
5769-MT8395IV/ZATR-ND,5769-MT8395IV/ZACT-ND,5769-MT8395IV/ZADKR-ND MT8395IV/ZA
544-3010-ND 5CSEBA4U19I7N
M2S060T-1FGG484I-ND M2S060T-1FGG484I
544-3013-ND 5CSEMA4U23I7N
544-3012-ND 5CSEMA4U23C6N
5CSEBA5U23C7N-ND 5CSEBA5U23C7N
544-A5EA013BB23BI6S-ND A5EA013BB23BI6S
544-3504-ND 5CSEBA5U19I7N
5CSEMA4U23A7N-ND 5CSEMA4U23A7N
544-A5EA013BB23BI4S-ND A5EA013BB23BI4S
5CSEMA5U23I7N-ND 5CSEMA5U23I7N
544-A5EA013BB23BI6X-ND A5EA013BB23BI6X
2156-UPD720231AK8-612-BAE-A-ND UPD720231AK8-612-BAE-A
2156-UPD60803F1-A11-BND-E2-A-ND UPD60803F1-A11-BND-E2-A
2266-2336163-9-ND 2336163-9
2156-EP7209-CV-D-ND EP7209-CV-D
2156-EP7209-CB-D-ND EP7209-CB-D
2156-UPD63712GC-8EU-A-ND UPD63712GC-8EU-A
2156-UPD63712CGC-8EU-A-ND UPD63712CGC-8EU-A
2156-UPD63712BGC-8EU-A-ND UPD63712BGC-8EU-A
2156-UPD63712AGC-8EU-A-ND UPD63712AGC-8EU-A
2156-UPD60802AF1-A10-BND-E2-A-ND UPD60802AF1-A10-BND-E2-A
2156-UPD60802AF1-A11-BND-E2-A-ND UPD60802AF1-A11-BND-E2-A
2156-UPD60802F1-A11-BND-E2-A-ND UPD60802F1-A11-BND-E2-A
2156-UPD60802AF1-A11-BND-A-ND UPD60802AF1-A11-BND-A
2156-UPD9937F1-CAL-A-ND UPD9937F1-CAL-A
2156-EP7211-CV-D-ND EP7211-CV-D
2156-EP7211-CB-D-ND EP7211-CB-D
2156-EP7212-CV-D-ND EP7212-CV-D
2156-PS7111-VC-A-ND PS7111-VC-A
2156-UPD72893BF1-FN3-A-ND UPD72893BF1-FN3-A
2156-PSB21650ELV1.5-G-ND PSB21650ELV1.5-G
2156-PSB21650ELV1.5G-ND PSB21650ELV1.5G
2156-HD46505SP-2-ND HD46505SP-2
2156-HD64412FIV-ND HD64412FIV
M2S005S-1VFG256I-ND M2S005S-1VFG256I
2156-UPD63702AGF-3B9-A-ND UPD63702AGF-3B9-A
1100-1355-ND M2S010T-VFG256
2156-PSB21653EV1.4-G-ND PSB21653EV1.4-G
2156-R8J66744BG#R0-ND R8J66744BG#R0
2698-PLCHIP-P10-51220-ND PLCHIP-P10-51220
2156-SC1201UFH-266-ND SC1201UFH-266
2156-R8J66607B00FP#RF1S-ND R8J66607B00FP#RF1S
2698-PLCHIP-P13-51220-ND PLCHIP-P13-51220
2156-SC1201UFH-266B-ND SC1201UFH-266B
2156-SC1200UFH-266-ND SC1200UFH-266
2156-SC2200UCL-300-ND SC2200UCL-300
2156-PXB4340EV1.1-G-ND PXB4340EV1.1-G
296-TDA4AL88TGAALZRQ1TR-ND,296-TDA4AL88TGAALZRQ1CT-ND,296-TDA4AL88TGAALZRQ1DKR-ND TDA4AL88TGAALZRQ1
2156-WDC6202GJL250X-ND WDC6202GJL250X
296-TDA4VE88TGAALZRQ1TR-ND,296-TDA4VE88TGAALZRQ1CT-ND,296-TDA4VE88TGAALZRQ1DKR-ND TDA4VE88TGAALZRQ1
1100-1225-ND M2S050T-FGG484
2156-PXB4330EV2.1-ND PXB4330EV2.1
544-3306-ND 5CSEBA6U23C6N
2156-88MW322-A0-NXUE/AZ-ND 88MW322-A0-NXUE/AZ
2156-TA7S04-60QC-600237-ND TA7S04-60QC
2156-TA7S20-60GC-600237-ND TA7S20-60GC
2156-UPD63F810GM(A)-8EV-A-1833-ND UPD63F810GM(A)-8EV-A
1100-1200-ND M2S050-FGG484I
122-2006-ND XC7Z012S-2CLG485I
122-XCZU1CG-1SBVA484I-ND XCZU1CG-1SBVA484I
122-1889-ND XC7Z030-2FBG484I
544-3524-ND 5CSEMA6F31I7N
122-1925-ND XC7Z030-2SBG485I
1100-1365-ND M2S150T-FCG1152I
544-3233-ND 5CSXFC6D6F31C6N
150-MPFS250T-1FCG1152I-ND MPFS250T-1FCG1152I
M2S150TS-1FC1152I-ND M2S150TS-1FC1152I
XCZU3EG-1SFVC784I-ND XCZU3EG-1SFVC784I
122-2270-ND XCZU4EG-1SFVC784E
122-1898-ND XC7Z045-2FFG676I
XCZU5EG-2SFVC784I-ND XCZU5EG-2SFVC784I
122-1897-ND XC7Z045-2FFG900I
122-2129-ND XC7Z100-2FFG900I
122-2021-ND XC7Z100-2FFG1156I
568-MIMX9331XVVXMAB-ND MIMX9331XVVXMAB
1100-1351-ND M2S005-VFG400I
1100-1356-ND M2S010-VFG256I
150-MPFS025T-FCSG325I-ND MPFS025T-FCSG325I
1100-1196-ND M2S025-FGG484I
544-3539-ND 5CSEMA5F31C6N
544-3178-ND 5CSEMA5F31I7N
122-2053-ND XCZU2EG-L1SBVA484I
544-3162-ND 5CSXFC6D6F31I7N
544-3446-ND 5CSTFD6D5F31I7N
122-2067-ND XAZU3EG-1SFVC784I
122-XCZU3EG-2UBVA530I-ND XCZU3EG-2UBVA530I
122-1901-ND XC7Z045-1FFG676C
XC7Z045-1FFG900I-ND XC7Z045-1FFG900I
122-2266-ND XCZU9EG-2FFVB1156E
122-2268-ND XCZU7EV-2FFVC1156I
1100-1348-ND M2S005-TQG144
1100-1344-ND M2S005-FGG484I
1100-1354-ND M2S010-TQG144
1100-1216-ND M2S010-FGG484
150-MPFS025T-FCVG484E-ND MPFS025T-FCVG484E
150-MPFS025T-FCSG325E-ND MPFS025T-FCSG325E
150-MPFS025T-FCVG484I-ND MPFS025T-FCVG484I
150-MPFS025TL-FCSG325E-ND MPFS025TL-FCSG325E
150-MPFS025T-1FCSG325I-ND MPFS025T-1FCSG325I
150-MPFS025TL-FCSG325I-ND MPFS025TL-FCSG325I
150-MPFS025TS-FCVG484I-ND MPFS025TS-FCVG484I
150-MPFS025TS-FCSG325I-ND MPFS025TS-FCSG325I
150-MPFS025TS-1FCSG325I-ND MPFS025TS-1FCSG325I
150-MPFS095T-FCVG484E-ND MPFS095T-FCVG484E
XC7Z020-L1CLG484I-ND XC7Z020-L1CLG484I
544-3550-ND 5CSEMA5F31C8N
150-MPFS095T-FCSG325E-ND MPFS095T-FCSG325E
150-MPFS095T-FCVG484I-ND MPFS095T-FCVG484I
150-MPFS095T-1FCVG484I-ND MPFS095T-1FCVG484I
150-MPFS095T-FCSG325I-ND MPFS095T-FCSG325I
150-MPFS095T-FCVG784E-ND MPFS095T-FCVG784E
150-MPFS095T-FCSG536I-ND MPFS095T-FCSG536I
150-MPFS095T-FCVG784I-ND MPFS095T-FCVG784I
150-MPFS095TL-FCSG325I-ND MPFS095TL-FCSG325I
150-MPFS160T-FCVG484I-ND MPFS160T-FCVG484I
150-MPFS160T-FCVG784E-ND MPFS160T-FCVG784E
150-MPFS160T-1FCVG484I-ND MPFS160T-1FCVG484I
150-MPFS160T-1FCVG784E-ND MPFS160T-1FCVG784E
150-MPFS160T-FCVG784I-ND MPFS160T-FCVG784I
122-XCZU1CG-1SFVA625I-ND XCZU1CG-1SFVA625I
122-XCZU2CG-2UBVA530E-ND XCZU2CG-2UBVA530E
122-XCZU2EG-1UBVA530I-ND XCZU2EG-1UBVA530I
150-MPFS250T-FCVG784E-ND MPFS250T-FCVG784E
122-XCZU2CG-2UBVA530I-ND XCZU2CG-2UBVA530I
150-MPFS250T-FCVG784I-ND MPFS250T-FCVG784I
150-MPFS160TL-FCSG536I-ND MPFS160TL-FCSG536I
122-XCZU1EG-2SBVA484I-ND XCZU1EG-2SBVA484I
150-MPFS250T-1FCVG784I-ND MPFS250T-1FCVG784I
150-MPFS250T-1FCG1152E-ND MPFS250T-1FCG1152E
122-XCZU2EG-2UBVA530I-ND XCZU2EG-2UBVA530I
122-XCZU1EG-2SFVC784I-ND XCZU1EG-2SFVC784I
122-XCZU3EG-1UBVA530E-ND XCZU3EG-1UBVA530E
150-MPFS250T-1FCSG536I-ND MPFS250T-1FCSG536I
122-XCZU3CG-1UBVA530I-ND XCZU3CG-1UBVA530I
150-MPFS250TL-FCSG536I-ND MPFS250TL-FCSG536I
150-MPFS250TLS-FCVG484I-ND MPFS250TLS-FCVG484I
150-MPFS250TS-FCSG536I-ND MPFS250TS-FCSG536I
122-XCZU3EG-1UBVA530I-ND XCZU3EG-1UBVA530I
150-MPFS250TS-FCG1152I-ND MPFS250TS-FCG1152I
2084-SOM-2532CCBX-S9A1-ND SOM-2532CCBX-S9A1
2084-SOM-2532DCBX-U0A1-ND SOM-2532DCBX-U0A1
122-2269-ND XCZU4EV-1SFVC784E
XCZU4CG-1FBVB900E-ND XCZU4CG-1FBVB900E
544-3616-ND 10AS027E3F29I2SG
122-XAZU5EV-1SFVC784I-ND XAZU5EV-1SFVC784I
544-3598-ND 10AS048E4F29I3SG
122-2176-ND XC7Z035-2FFG900I
122-XCVM1302-2HSINBVB1024-ND XCVM1302-2HSINBVB1024
1711-SC-13048Q-A-ND SC-13048Q-A
1100-1347-ND M2S005-TQG144I
1100-1352-ND M2S005-VFG400
1100-1345-ND M2S005-FGG484
1100-1192-ND M2S010-FGG484I
1100-1193-ND M2S010T-FGG484I
150-MPFS025T-1FCVG484E-ND MPFS025T-1FCVG484E
150-MPFS025T-1FCSG325E-ND MPFS025T-1FCSG325E
150-MPFS025TL-FCVG484E-ND MPFS025TL-FCVG484E
150-MPFS025T-1FCVG484I-ND MPFS025T-1FCVG484I
150-MPFS025TL-FCVG484I-ND MPFS025TL-FCVG484I
150-MPFS025TLS-FCVG484I-ND MPFS025TLS-FCVG484I
150-MPFS025TS-1FCVG484I-ND MPFS025TS-1FCVG484I
150-MPFS025TLS-FCSG325I-ND MPFS025TLS-FCSG325I
122-2001-ND XC7Z012S-1CLG485I
122-2004-ND XC7Z014S-2CLG400I
150-MPFS095T-1FCVG484E-ND MPFS095T-1FCVG484E
150-MPFS095T-FCSG536E-ND MPFS095T-FCSG536E
150-MPFS095TL-FCVG484E-ND MPFS095TL-FCVG484E
150-MPFS095TL-FCVG484I-ND MPFS095TL-FCVG484I
150-MPFS095T-1FCSG536E-ND MPFS095T-1FCSG536E
150-MPFS095T-1FCSG325I-ND MPFS095T-1FCSG325I
150-MPFS095TL-FCSG325E-ND MPFS095TL-FCSG325E
544-3160-ND 5CSXFC5D6F31C8N
544-3465-ND 5CSEMA6F31C8N
150-MPFS095TS-FCVG484I-ND MPFS095TS-FCVG484I
150-MPFS160T-FCVG484E-ND MPFS160T-FCVG484E
150-MPFS095TL-FCSG536E-ND MPFS095TL-FCSG536E
150-MPFS095T-1FCSG536I-ND MPFS095T-1FCSG536I
150-MPFS095TL-FCVG784E-ND MPFS095TL-FCVG784E
150-MPFS095T-1FCVG784I-ND MPFS095T-1FCVG784I
150-MPFS095TS-1FCVG484I-ND MPFS095TS-1FCVG484I
150-MPFS095TLS-FCVG484I-ND MPFS095TLS-FCVG484I
544-3507-ND 5CSEBA6U23C7N
150-MPFS095TS-FCSG325I-ND MPFS095TS-FCSG325I
150-MPFS160T-1FCVG484E-ND MPFS160T-1FCVG484E
150-MPFS095TL-FCSG536I-ND MPFS095TL-FCSG536I
150-MPFS095TLS-FCSG325I-ND MPFS095TLS-FCSG325I
150-MPFS095TS-1FCSG325I-ND MPFS095TS-1FCSG325I
150-MPFS095TS-FCSG536I-ND MPFS095TS-FCSG536I
150-MPFS160TL-FCVG484E-ND MPFS160TL-FCVG484E
150-MPFS095TS-FCVG784I-ND MPFS095TS-FCVG784I
150-MPFS095TS-1FCSG536I-ND MPFS095TS-1FCSG536I
150-MPFS160TL-FCVG484I-ND MPFS160TL-FCVG484I
150-MPFS160TL-FCVG784E-ND MPFS160TL-FCVG784E
150-MPFS160T-FCSG536E-ND MPFS160T-FCSG536E
150-MPFS095TS-1FCVG784I-ND MPFS095TS-1FCVG784I
150-MPFS095TLS-FCVG784I-ND MPFS095TLS-FCVG784I
150-MPFS160TS-FCVG484I-ND MPFS160TS-FCVG484I
544-3531-ND 5CSXFC5D6F31I7N
150-MPFS160TL-FCVG784I-ND MPFS160TL-FCVG784I
122-XCZU1CG-2SBVA484I-ND XCZU1CG-2SBVA484I
150-MPFS160T-1FCSG536E-ND MPFS160T-1FCSG536E
150-MPFS160T-FCSG536I-ND MPFS160T-FCSG536I
150-MPFS160TS-1FCVG484I-ND MPFS160TS-1FCVG484I
150-MPFS160TLS-FCVG484I-ND MPFS160TLS-FCVG484I
122-XAZU1EG-1SFVC784I-ND XAZU1EG-1SFVC784I
122-XCZU1CG-2SFVC784I-ND XCZU1CG-2SFVC784I
150-MPFS160TS-FCVG784I-ND MPFS160TS-FCVG784I
150-MPFS160T-1FCSG536I-ND MPFS160T-1FCSG536I
150-MPFS160TL-FCSG536E-ND MPFS160TL-FCSG536E
544-3159-ND 5CSTFD5D5F31I7N
150-MPFS160TS-FCSG536I-ND MPFS160TS-FCSG536I
2084-SOM-2532CCBC-S5A1-ND SOM-2532CCBC-S5A1
150-MPFS160TS-1FCSG536I-ND MPFS160TS-1FCSG536I
XCZU2EG-2SFVC784I-ND XCZU2EG-2SFVC784I
2084-SOM-2532DCBC-U0A1-ND SOM-2532DCBC-U0A1
122-2261-ND XCZU3CG-2SFVC784I
544-3589-ND 10AS016E3F27E2SG
544-3596-ND 10AS032E3F29E2SG
122-2034-ND XCZU9CG-1FFVC900E
122-2033-ND XCZU9EG-1FFVC900E
122-XCVM1302-1LSENSVF1369-ND XCVM1302-1LSENSVF1369
XCZU9EG-2FFVC900E-ND XCZU9EG-2FFVC900E
122-XCVM1402-2LSEVFVC1596-ND XCVM1402-2LSEVFVC1596
122-XCVM1402-2MLIVSVD1760-ND XCVM1402-2MLIVSVD1760
150-MPFS095TC-FCSG325I-ND MPFS095TC-FCSG325I
150-MPFS250TC-FCVG484I-ND MPFS250TC-FCVG484I
XCZU2CG-1SFVC784E-ND XCZU2CG-1SFVC784E
150-MPFS250TC-FCVG784I-ND MPFS250TC-FCVG784I
XCZU2EG-1SFVC784E-ND XCZU2EG-1SFVC784E
XCZU2CG-1SFVC784I-ND XCZU2CG-1SFVC784I
XCZU2EG-1SFVA625I-ND XCZU2EG-1SFVA625I
XCZU2EG-1SFVC784I-ND XCZU2EG-1SFVC784I
XCZU2CG-2SFVC784I-ND XCZU2CG-2SFVC784I
XCZU3CG-1SFVC784I-ND XCZU3CG-1SFVC784I
XCZU3EG-2SFVC784I-ND XCZU3EG-2SFVC784I
XC7Z035-1FBG676C-ND XC7Z035-1FBG676C
XCZU4CG-2SFVC784E-ND XCZU4CG-2SFVC784E
XCZU4EG-1SFVC784I-ND XCZU4EG-1SFVC784I
XC7Z035-1FBG676I-ND XC7Z035-1FBG676I
XCZU4EV-1SFVC784I-ND XCZU4EV-1SFVC784I
XCZU4CG-1FBVB900I-ND XCZU4CG-1FBVB900I
XC7Z035-2FBG676I-ND XC7Z035-2FBG676I
122-1899-ND XC7Z045-2FBG676I
XCZU5EV-2SFVC784I-ND XCZU5EV-2SFVC784I
XC7Z045-3FFG900E-ND XC7Z045-3FFG900E
XCZU7EV-2FBVB900I-ND XCZU7EV-2FBVB900I
XCZU17EG-2FFVC1760E-ND XCZU17EG-2FFVC1760E
544-AGFB014R24B2E2V-ND AGFB014R24B2E2V
2156-UPD72874AGC-YEB-A-ND UPD72874AGC-YEB-A
2156-KS8695-ND KS8695
568-MIMX9332DVVXMAB-ND MIMX9332DVVXMAB
2156-UPD72893BGD-LML-A-ND UPD72893BGD-LML-A
568-MIMX9352XVVXMAB-ND MIMX9352XVVXMAB
1100-1219-ND M2S010-VFG400
2698-PLCHIP-P10-51220X1-ND PLCHIP-P10-51220X1
2698-PLCHIP-P10-51220X5-ND PLCHIP-P10-51220X5
2698-PLCHIP-P13-51220X5-ND PLCHIP-P13-51220X5
150-MPFS250T-1FCVG784E-ND MPFS250T-1FCVG784E
150-MPFS250TL-FCVG784E-ND MPFS250TL-FCVG784E
150-MPFS250TL-FCVG484I-ND MPFS250TL-FCVG484I
150-MPFS250TL-FCSG536E-ND MPFS250TL-FCSG536E
150-MPFS250TL-FCVG784I-ND MPFS250TL-FCVG784I
150-MPFS250TL-FCG1152E-ND MPFS250TL-FCG1152E
2698-PLCHIP-P10-51220X10-ND PLCHIP-P10-51220X10
150-MPFS250TS-FCVG784I-ND MPFS250TS-FCVG784I
150-MPFS250TL-FCG1152I-ND MPFS250TL-FCG1152I
544-A5ED065BB23AE5SR0-ND A5ED065BB23AE5SR0
544-A5ED065BB32AE4SR0-ND A5ED065BB32AE4SR0
4230-10E00025005X0-ND 10E00025005X0
122-1924-ND XC7Z030-1SBG485C
122-2096-ND XC7Z030-1FBG676I
150-MPFS250T-FCG1152I-ND MPFS250T-FCG1152I
122-1888-ND XC7Z030-2FFG676I
122-2267-ND XCZU9EG-2FFVB1156I
568-MIMX9332XVVXMAB-ND MIMX9332XVVXMAB
150-MPFS250TS-1FCSG536I-ND MPFS250TS-1FCSG536I
1100-1008-ND A2F500M3G-1FGG484
150-MPFS095T-1FCVG784E-ND MPFS095T-1FCVG784E
150-MPFS095TL-FCVG784I-ND MPFS095TL-FCVG784I
150-MPFS160T-1FCVG784I-ND MPFS160T-1FCVG784I
150-MPFS160TLS-FCVG784I-ND MPFS160TLS-FCVG784I
150-MPFS160TS-1FCVG784I-ND MPFS160TS-1FCVG784I
122-2255-ND XCZU2CG-2SBVA484I
150-MPFS160TLS-FCSG536I-ND MPFS160TLS-FCSG536I
XCZU3EG-1SFVC784E-ND XCZU3EG-1SFVC784E
2084-SOM-2532CCBC-S9A1-ND SOM-2532CCBC-S9A1
150-MPFS250TLS-FCVG784I-ND MPFS250TLS-FCVG784I
150-MPFS250TLS-FCSG536I-ND MPFS250TLS-FCSG536I
122-XAZU1EG-1SFVA625Q-ND XAZU1EG-1SFVA625Q
XC7Z030-3FFG676E-ND XC7Z030-3FFG676E
150-MPFS250TS-1FCG1152I-ND MPFS250TS-1FCG1152I
122-XCZU3CG-2UBVA530I-ND XCZU3CG-2UBVA530I
1100-1195-ND M2S010-VFG400I
150-M2S025T-1FCSG158I-ND M2S025T-1FCSG158I
544-3546-ND 5CSEBA2U23C8N
150-MPFS095T-1FCSG325E-ND MPFS095T-1FCSG325E
544-3161-ND 5CSXFC6D6F31C8N
150-MPFS095TLS-FCSG536I-ND MPFS095TLS-FCSG536I
2084-SOM-2532CCBC-S3A1-ND SOM-2532CCBC-S3A1
2084-SOM-2532CNBC-S2A1-ND SOM-2532CNBC-S2A1
544-3563-ND 10AS027E4F29E3SG
5128-AP510NFA-CCRTR-ND,5128-AP510NFA-CCRCT-ND,5128-AP510NFA-CCRDKR-ND AP510NFA-CCR
122-2099-ND XC7Z010-2CLG400E
5CSEBA2U23A7N-ND 5CSEBA2U23A7N
544-A5EE008BB23BI5S-ND A5EE008BB23BI5S
544-3011-ND 5CSEBA4U23I7N
XC7Z015-L1CLG485I-ND XC7Z015-L1CLG485I
544-A5ED008BB23AI6S-ND A5ED008BB23AI6S
544-A5EB008BB23BI6S-ND A5EB008BB23BI6S
544-A5ED008BM16AI5S-ND A5ED008BM16AI5S
544-A5EB008BB23BI4S-ND A5EB008BB23BI4S
XCZU2CG-1SBVA484E-ND XCZU2CG-1SBVA484E
544-A5EE013BB23BE6S-ND A5EE013BB23BE6S
544-A5EE013BB23BI6S-ND A5EE013BB23BI6S
544-A5ED013BB23AE6S-ND A5ED013BB23AE6S
544-A5EB013BB23BE6S-ND A5EB013BB23BE6S
544-A5ED013BB23AE5S-ND A5ED013BB23AE5S
544-A5ED013BM16AI6S-ND A5ED013BM16AI6S
544-A5EB013BB23BI5S-ND A5EB013BB23BI5S
544-A5EC043BB23AI5S-ND A5EC043BB23AI5S
XC7Z030-3FBG676E-ND XC7Z030-3FBG676E
150-MPFS460T-FCG1152E-ND MPFS460T-FCG1152E
150-MPFS460T-1FCG1152E-ND MPFS460T-1FCG1152E
PI5USB30216CXUAEXTR-ND,PI5USB30216CXUAEXCT-ND,PI5USB30216CXUAEXDKR-ND PI5USB30216CXUAEX
UTC2000/MG-ND UTC2000/MG
846-BD91N01NUX-E2TR-ND,846-BD91N01NUX-E2CT-ND,846-BD91N01NUX-E2DKR-ND BD91N01NUX-E2
31-AP33772SDKZ-13-FA01TR-ND,31-AP33772SDKZ-13-FA01CT-ND,31-AP33772SDKZ-13-FA01DKR-ND AP33772SDKZ-13-FA01
296-TUSB320LAIRWBRTR-ND,296-TUSB320LAIRWBRCT-ND,296-TUSB320LAIRWBRDKR-ND TUSB320LAIRWBR
296-39439-2-ND,296-39439-1-ND,296-39439-6-ND TPS61252DSGR
497-17647-2-ND,497-17647-1-ND,497-17647-6-ND STUSB1600AQTR
448-CYPD3177-24LQXQTTR-ND,448-CYPD3177-24LQXQTCT-ND,448-CYPD3177-24LQXQTDKR-ND CYPD3177-24LQXQT
296-37700-2-ND,296-37700-1-ND,296-37700-6-ND SN6501DBVR
MAX1946ETA+TTR-ND,MAX1946ETA+TCT-ND,MAX1946ETA+TDKR-ND MAX1946ETA+T
296-47311-2-ND,296-47311-1-ND,296-47311-6-ND SN6505BDBVR
296-36967-2-ND,296-36967-1-ND,296-36967-6-ND SN6501QDBVRQ1
296-53549-2-ND,296-53549-1-ND,296-53549-6-ND SN6505AQDBVRQ1
296-48949-2-ND,296-48949-1-ND,296-48949-6-ND SN6505ADBVR
UCS1003-1-BP-TR-ND,UCS1003-1-BP-CT-ND,UCS1003-1-BP-DKR-ND UCS1003-1-BP-TR
UCS1003-1-BP-ND UCS1003-1-BP
150-MCP16501TD-E/RMBTR-ND,150-MCP16501TD-E/RMBCT-ND,150-MCP16501TD-E/RMBDKR-ND MCP16501TD-E/RMB
296-30388-2-ND,296-30388-1-ND,296-30388-6-ND SN6501DBVT
296-SN6505BQDBVRQ1TR-ND,296-SN6505BQDBVRQ1CT-ND,296-SN6505BQDBVRQ1DKR-ND SN6505BQDBVRQ1
296-21166-2-ND,296-21166-1-ND,296-21166-6-ND TPS65150PWPR
HV892K7-GTR-ND,HV892K7-GCT-ND,HV892K7-GDKR-ND HV892K7-G
296-TPS25730DREFRTR-ND,296-TPS25730DREFRCT-ND,296-TPS25730DREFRDKR-ND TPS25730DREFR
296-TPS25751DREFRTR-ND,296-TPS25751DREFRCT-ND,296-TPS25751DREFRDKR-ND TPS25751DREFR
296-UCC25800AQDGNRQ1TR-ND,296-UCC25800AQDGNRQ1CT-ND,296-UCC25800AQDGNRQ1DKR-ND UCC25800AQDGNRQ1
296-43154-2-ND,296-43154-1-ND,296-43154-6-ND SN6505BDBVT
568-15384-2-ND,568-15384-1-ND,568-15384-6-ND PCA9420UKZ
296-SN6505BQDBVTQ1TR-ND,296-SN6505BQDBVTQ1CT-ND,296-SN6505BQDBVTQ1DKR-ND SN6505BQDBVTQ1
175-MAX77958EWV+TTR-ND,175-MAX77958EWV+TCT-ND,175-MAX77958EWV+TDKR-ND MAX77958EWV+T
296-TPS6521903RHBRTR-ND,296-TPS6521903RHBRCT-ND,296-TPS6521903RHBRDKR-ND TPS6521903RHBR
576-4263-2-ND,576-4263-1-ND,576-4263-6-ND MIC5166YML-TR
296-SN6507DGQRTR-ND,296-SN6507DGQRCT-ND,296-SN6507DGQRDKR-ND SN6507DGQR
296-51123-2-ND,296-51123-1-ND,296-51123-6-ND HD3SS3220IRNHR
296-48293-2-ND,296-48293-1-ND,296-48293-6-ND HD3SS3220RNHR
MAX16126TCA+TTR-ND,MAX16126TCA+TCT-ND,MAX16126TCA+TDKR-ND MAX16126TCA+T
296-38885-2-ND,296-38885-1-ND,296-38885-6-ND BQ51013BRHLR
296-27258-2-ND,296-27258-1-ND,296-27258-6-ND BQ24640RVAR
296-SN6507DGQRQ1TR-ND,296-SN6507DGQRQ1CT-ND,296-SN6507DGQRQ1DKR-ND SN6507DGQRQ1
175-MAX17612AATB+TTR-ND,175-MAX17612AATB+TCT-ND,175-MAX17612AATB+TDKR-ND MAX17612AATB+T
TLE94713ESV33XUMA1TR-ND,TLE94713ESV33XUMA1CT-ND,TLE94713ESV33XUMA1DKR-ND TLE94713ESV33XUMA1
2312-ACT8865QI305-TTR-ND,2312-ACT8865QI305-TCT-ND,2312-ACT8865QI305-TDKR-ND ACT8865QI305-T
175-MAX16127TC/V+TTR-ND,175-MAX16127TC/V+TCT-ND,175-MAX16127TC/V+TDKR-ND MAX16127TC/V+T
296-43694-2-ND,296-43694-1-ND,296-43694-6-ND HD3SS3220IRNHT
2312-ACT8945AQJ405-TTR-ND,2312-ACT8945AQJ405-TCT-ND,2312-ACT8945AQJ405-TDKR-ND ACT8945AQJ405-T
497-19781-2-ND,497-19781-1-ND,497-19781-6-ND STPMIC1APQR
296-BQ51050BRHLRTR-ND,296-BQ51050BRHLRCT-ND,296-BQ51050BRHLRDKR-ND BQ51050BRHLR
296-37685-2-ND,296-37685-1-ND,296-37685-6-ND TPS65910A3A1RSLR
296-BQ25190YBGRTR-ND,296-BQ25190YBGRCT-ND,296-BQ25190YBGRDKR-ND BQ25190YBGR
296-35502-2-ND,296-35502-1-ND,296-35502-6-ND BQ51050BRHLT
296-46287-2-ND,296-46287-1-ND,296-46287-6-ND BQ24650RVAR
MAX253CUA+TR-ND,MAX253CUA+CT-ND,MAX253CUA+DKR-ND MAX253CUA+T
MAX253CSA+TTR-ND,MAX253CSA+TCT-ND,MAX253CSA+TDKR-ND MAX253CSA+T
497-STWBC86JR-ND STWBC86JR
MAX253CSA±ND MAX253CSA+
296-17835-2-ND,296-17835-1-ND,296-17835-6-ND TPS75003RHLR
2763-KTE7001ENAA-DA-TBTR-ND,2763-KTE7001ENAA-DA-TBCT-ND,2763-KTE7001ENAA-DA-TBDKR-ND KTE7001ENAA-DA-TB
448-WLC1115-68LQXQTTR-ND,448-WLC1115-68LQXQTCT-ND,448-WLC1115-68LQXQTDKR-ND WLC1115-68LQXQT
568-PCA9450BHNYTR-ND,568-PCA9450BHNYCT-ND,568-PCA9450BHNYDKR-ND PCA9450BHNY
568-PCA9450AAHNYTR-ND,568-PCA9450AAHNYCT-ND,568-PCA9450AAHNYDKR-ND PCA9450AAHNY
MAX16127TC+TR-ND,MAX16127TC+CT-ND,MAX16127TC+DKR-ND MAX16127TC+T
505-LTC4365CTS8#TRMPBFTR-ND,505-LTC4365CTS8#TRMPBFCT-ND,505-LTC4365CTS8#TRMPBFDKR-ND LTC4365CTS8#TRMPBF
505-LTC4365CDDB#TRMPBFTR-ND,505-LTC4365CDDB#TRMPBFCT-ND,505-LTC4365CDDB#TRMPBFDKR-ND LTC4365CDDB#TRMPBF
175-MAX77654AENV+TTR-ND,175-MAX77654AENV+TCT-ND,175-MAX77654AENV+TDKR-ND MAX77654AENV+T
296-TPS25762CAQRQLRQ1TR-ND,296-TPS25762CAQRQLRQ1CT-ND,296-TPS25762CAQRQLRQ1DKR-ND TPS25762CAQRQLRQ1
296-27699-2-ND,296-27699-1-ND,296-27699-6-ND BQ24650RVAT
296-19438-2-ND,296-19438-1-ND,296-19438-6-ND TPS75003RHLT
505-LTC4365ITS8-1#TRMPBFTR-ND,505-LTC4365ITS8-1#TRMPBFCT-ND,505-LTC4365ITS8-1#TRMPBFDKR-ND LTC4365ITS8-1#TRMPBF
505-LTC4365IDDB#TRMPBFTR-ND,505-LTC4365IDDB#TRMPBFCT-ND,505-LTC4365IDDB#TRMPBFDKR-ND LTC4365IDDB#TRMPBF
505-LTC4365ITS8#TRMPBFTR-ND,505-LTC4365ITS8#TRMPBFCT-ND,505-LTC4365ITS8#TRMPBFDKR-ND LTC4365ITS8#TRMPBF
LTC4365IDDB-1#TRMPBFTR-ND,LTC4365IDDB-1#TRMPBFCT-ND,LTC4365IDDB-1#TRMPBFDKR-ND LTC4365IDDB-1#TRMPBF
505-LTC4365ITS8-1#TRPBFTR-ND,505-LTC4365ITS8-1#TRPBFCT-ND,505-LTC4365ITS8-1#TRPBFDKR-ND LTC4365ITS8-1#TRPBF
MAX253ESA+TTR-ND,MAX253ESA+TCT-ND,MAX253ESA+TDKR-ND MAX253ESA+T
175-MAX17525ATP+TTR-ND,175-MAX17525ATP+TCT-ND,175-MAX17525ATP+TDKR-ND MAX17525ATP+T
BD71837AMWV-E2TR-ND,BD71837AMWV-E2CT-ND,BD71837AMWV-E2DKR-ND BD71837AMWV-E2
LTC4361ITS8-2#TRMPBFTR-ND,LTC4361ITS8-2#TRMPBFCT-ND,LTC4361ITS8-2#TRMPBFDKR-ND LTC4361ITS8-2#TRMPBF
LTC4361IDC-1#TRMPBFTR-ND,LTC4361IDC-1#TRMPBFCT-ND,LTC4361IDC-1#TRMPBFDKR-ND LTC4361IDC-1#TRMPBF
497-STPMIC25APQRTR-ND,497-STPMIC25APQRCT-ND,497-STPMIC25APQRDKR-ND STPMIC25APQR
448-IR35215MTRPBFTR-ND,448-IR35215MTRPBFCT-ND,448-IR35215MTRPBFDKR-ND IR35215MTRPBF
LTC4362IDCB-2#TRMPBFTR-ND,LTC4362IDCB-2#TRMPBFCT-ND,LTC4362IDCB-2#TRMPBFDKR-ND LTC4362IDCB-2#TRMPBF
505-LTC4365HTS8#TRMPBFTR-ND,505-LTC4365HTS8#TRMPBFCT-ND,505-LTC4365HTS8#TRMPBFDKR-ND LTC4365HTS8#TRMPBF
505-LTC4365HDDB#TRMPBFTR-ND,505-LTC4365HDDB#TRMPBFCT-ND,505-LTC4365HDDB#TRMPBFDKR-ND LTC4365HDDB#TRMPBF
505-LTC4365HTS8#TRPBFTR-ND,505-LTC4365HTS8#TRPBFCT-ND,505-LTC4365HTS8#TRPBFDKR-ND LTC4365HTS8#TRPBF
296-37158-2-ND,296-37158-1-ND,296-37158-6-ND TPS65217CRSLT
MAX845EUA+TTR-ND,MAX845EUA+TCT-ND,MAX845EUA+TDKR-ND MAX845EUA+T
MAX845ESA+TTR-ND,MAX845ESA+TCT-ND,MAX845ESA+TDKR-ND MAX845ESA+T
175-MAX17526AATP+TTR-ND,175-MAX17526AATP+TCT-ND,175-MAX17526AATP+TDKR-ND MAX17526AATP+T
MAX17526AATP±ND MAX17526AATP+
505-LTC4367IMS8#TRPBFTR-ND,505-LTC4367IMS8#TRPBFCT-ND,505-LTC4367IMS8#TRPBFDKR-ND LTC4367IMS8#TRPBF
505-LTC4367IDD-1#PBF-ND LTC4367IDD-1#PBF
505-LTC4367IMS8-1#TRPBFTR-ND,505-LTC4367IMS8-1#TRPBFCT-ND,505-LTC4367IMS8-1#TRPBFDKR-ND LTC4367IMS8-1#TRPBF
LTC4367IMS8#PBF-ND LTC4367IMS8#PBF
MAX17613AATP±ND MAX17613AATP+
LT4430ES6#TRPBFTR-ND,LT4430ES6#TRPBFCT-ND,LT4430ES6#TRPBFDKR-ND LT4430ES6#TRPBF
MAX253CPA±ND MAX253CPA+
296-24939-2-ND,296-24939-1-ND,296-24939-6-ND TPS65070RSLR
MAX253ESA±ND MAX253ESA+
568-PCA9451AHNYTR-ND,568-PCA9451AHNYCT-ND,568-PCA9451AHNYDKR-ND PCA9451AHNY
MAX845ESA±ND MAX845ESA+
LTC3225EDDB-1#TRMPBFTR-ND,LTC3225EDDB-1#TRMPBFCT-ND,LTC3225EDDB-1#TRMPBFDKR-ND LTC3225EDDB-1#TRMPBF
LTC3225EDDB#TRPBFTR-ND,LTC3225EDDB#TRPBFCT-ND,LTC3225EDDB#TRPBFDKR-ND LTC3225EDDB#TRPBF
505-LTC3225EDDB#TRMPBFTR-ND,505-LTC3225EDDB#TRMPBFCT-ND,505-LTC3225EDDB#TRMPBFDKR-ND LTC3225EDDB#TRMPBF
296-39934-2-ND,296-39934-1-ND,296-39934-6-ND BQ25570RGRR
LTC4367HMS8-1#PBF-ND LTC4367HMS8-1#PBF
505-LTC4367HMS8#TRPBFTR-ND,505-LTC4367HMS8#TRPBFCT-ND,505-LTC4367HMS8#TRPBFDKR-ND LTC4367HMS8#TRPBF
505-LTC4367HMS8-1#TRPBFTR-ND,505-LTC4367HMS8-1#TRPBFCT-ND,505-LTC4367HMS8-1#TRPBFDKR-ND LTC4367HMS8-1#TRPBF
LTC4367HDD-1#PBF-ND LTC4367HDD-1#PBF
505-LTC4367HDD#PBF-ND LTC4367HDD#PBF
LTC4425EMSE#TRPBFTR-ND,LTC4425EMSE#TRPBFCT-ND,LTC4425EMSE#TRPBFDKR-ND LTC4425EMSE#TRPBF
LTC4425EMSE#PBF-ND LTC4425EMSE#PBF
505-MAX14691ATP±ND MAX14691ATP+
505-LT2940IMS#TRPBFTR-ND,505-LT2940IMS#TRPBFCT-ND,505-LT2940IMS#TRPBFDKR-ND LT2940IMS#TRPBF
LTC4425IDD#PBF-ND LTC4425IDD#PBF
175-MAX17613AATP+TTR-ND,175-MAX17613AATP+TCT-ND,175-MAX17613AATP+TDKR-ND MAX17613AATP+T
505-LTC3558EUD#PBF-ND LTC3558EUD#PBF
LTC3226EUD#PBF-ND LTC3226EUD#PBF
505-LTC3226EUD#TRPBFTR-ND,505-LTC3226EUD#TRPBFCT-ND,505-LTC3226EUD#TRPBFDKR-ND LTC3226EUD#TRPBF
MAX749CSA+TTR-ND,MAX749CSA+TCT-ND,MAX749CSA+TDKR-ND MAX749CSA+T
296-TPS6591133A2NMA-ND TPS6591133A2NMA
296-TPS65931211RWERQ1TR-ND,296-TPS65931211RWERQ1CT-ND,296-TPS65931211RWERQ1DKR-ND TPS65931211RWERQ1
LTC3127EDD#TRPBFTR-ND,LTC3127EDD#TRPBFCT-ND,LTC3127EDD#TRPBFDKR-ND LTC3127EDD#TRPBF
505-LTC3127EDD#PBF-ND LTC3127EDD#PBF
LTC3625EDE#PBF-ND LTC3625EDE#PBF
LTC1153IS8#PBF-ND LTC1153IS8#PBF
568-13650-2-ND,568-13650-1-ND,568-13650-6-ND MC13892DJVLR2
296-TPS6594133ARWERQ1TR-ND,296-TPS6594133ARWERQ1CT-ND,296-TPS6594133ARWERQ1DKR-ND TPS6594133ARWERQ1
505-LT3751EUFD#PBF-ND LT3751EUFD#PBF
505-LTC4125IUFD#TRPBFTR-ND,505-LTC4125IUFD#TRPBFCT-ND,505-LTC4125IUFD#TRPBFDKR-ND LTC4125IUFD#TRPBF
505-LT3751EFE#PBF-ND LT3751EFE#PBF
MAX749ESA±ND MAX749ESA+
505-LTC3101EUF#TRPBFTR-ND,505-LTC3101EUF#TRPBFCT-ND,505-LTC3101EUF#TRPBFDKR-ND LTC3101EUF#TRPBF
505-ADN8833ACBZ-R7TR-ND,505-ADN8833ACBZ-R7CT-ND,505-ADN8833ACBZ-R7DKR-ND ADN8833ACBZ-R7
LTC3350EUHF#TRPBFTR-ND,LTC3350EUHF#TRPBFCT-ND,LTC3350EUHF#TRPBFDKR-ND LTC3350EUHF#TRPBF
505-LTC3350EUHF#PBF-ND LTC3350EUHF#PBF
505-LTC3350IUHF#PBF-ND LTC3350IUHF#PBF
296-52056-2-ND,296-52056-1-ND,296-52056-6-ND TPS6590378ZWSR
296-52057-2-ND,296-52057-1-ND,296-52057-6-ND TPS6590379ZWSR
175-MAX8521EWX+TTR-ND,175-MAX8521EWX+TCT-ND,175-MAX8521EWX+TDKR-ND MAX8521EWX+T
505-LTC3556EUFD#PBF-ND LTC3556EUFD#PBF
MC34708VM-ND MC34708VM
505-ADN8834ACPZ-R7TR-ND,505-ADN8834ACPZ-R7CT-ND,505-ADN8834ACPZ-R7DKR-ND ADN8834ACPZ-R7
505-ADN8834ACBZ-R7TR-ND,505-ADN8834ACBZ-R7CT-ND,505-ADN8834ACBZ-R7DKR-ND ADN8834ACBZ-R7
505-LTC3351EUFF#TRPBFTR-ND,505-LTC3351EUFF#TRPBFCT-ND,505-LTC3351EUFF#TRPBFDKR-ND LTC3351EUFF#TRPBF
505-LTC3351EUFF#PBF-ND LTC3351EUFF#PBF
LTC3586EUFE#PBF-ND LTC3586EUFE#PBF
505-LTM4663EV#PBF-ND LTM4663EV#PBF
505-ADN8831ACPZ-REEL7TR-ND,505-ADN8831ACPZ-REEL7CT-ND,505-ADN8831ACPZ-REEL7DKR-ND ADN8831ACPZ-REEL7
ADN8834ACPZ-R2TR-ND,ADN8834ACPZ-R2CT-ND,ADN8834ACPZ-R2DKR-ND ADN8834ACPZ-R2
505-LTC3351IUFF#TRPBFTR-ND,505-LTC3351IUFF#TRPBFCT-ND,505-LTC3351IUFF#TRPBFDKR-ND LTC3351IUFF#TRPBF
505-LTC3351IUFF#PBF-ND LTC3351IUFF#PBF
505-LTM4663IV#PBF-ND LTM4663IV#PBF
505-ADN8835ACPZ-R7TR-ND,505-ADN8835ACPZ-R7CT-ND,505-ADN8835ACPZ-R7DKR-ND ADN8835ACPZ-R7
MAX8521ETP±ND MAX8521ETP+
MAX8521ETP+TTR-ND,MAX8521ETP+TCT-ND,MAX8521ETP+TDKR-ND MAX8521ETP+T
MAX8520ETP+TTR-ND,MAX8520ETP+TCT-ND,MAX8520ETP+TDKR-ND MAX8520ETP+T
MAX8520ETP±ND MAX8520ETP+
MAX1968EUI+TTR-ND,MAX1968EUI+TCT-ND,MAX1968EUI+TDKR-ND MAX1968EUI+T
296-40069-2-ND,296-40069-1-ND,296-40069-6-ND,2156-DRV595DAPR-ND DRV595DAPR
505-HMC981LP3E-ND HMC981LP3E
LTC1923EGN#TRPBFTR-ND,LTC1923EGN#TRPBFCT-ND,LTC1923EGN#TRPBFDKR-ND LTC1923EGN#TRPBF
505-LTC1923EGN#PBF-ND LTC1923EGN#PBF
LTC1923EUH#PBF-ND LTC1923EUH#PBF
MAX1978ETM+TTR-ND,MAX1978ETM+TCT-ND,MAX1978ETM+TDKR-ND MAX1978ETM+T
2156-DRV595DAP-ND,296-38931-5-ND DRV595DAP
MAX1978ETM±ND MAX1978ETM+
MAX1969EUI±ND MAX1969EUI+
1127-1191-2-ND,1127-1191-1-ND,1127-1191-6-ND HMC980LP4ETR
505-HMC980LP4E-ND HMC980LP4E
MAX4940CTN±ND MAX4940CTN+
1245-1030-ND HI-8435PQIF
505-HMC920LP5ETR-ND,505-HMC920LP5ETRCT-ND,505-HMC920LP5ETRDKR-ND HMC920LP5ETR
505-HMC920LP5E-ND HMC920LP5E
175-MAX14808ETK+TTR-ND,175-MAX14808ETK+TCT-ND,175-MAX14808ETK+TDKR-ND MAX14808ETK+T
MAX14808ETK±ND MAX14808ETK+
448-IR35204MTRPBFTR-ND,448-IR35204MTRPBFCT-ND,448-IR35204MTRPBFDKR-ND IR35204MTRPBF
MC34VR500V1ES-ND MC34VR500V1ES
296-39375-2-ND,296-39375-1-ND,296-39375-6-ND,2156-TPS2513ADBVR-ND TPS2513ADBVR
296-40725-2-ND,296-40725-1-ND,296-40725-6-ND TPS2514ADBVR
296-38344-2-ND,296-38344-1-ND,296-38344-6-ND TPD1S514-1YZR
31-AP25810LDFZ20-13TR-ND,31-AP25810LDFZ20-13CT-ND,31-AP25810LDFZ20-13DKR-ND AP25810LDFZ20-13
296-30552-2-ND,296-30552-1-ND,296-30552-6-ND TPS2511DGNR
EMC1701-2-AIZL-TR-ND,EMC1701-2-AIZL-CT-ND,EMC1701-2-AIZL-DKR-ND EMC1701-2-AIZL-TR
31-AP33771CFBZ-13-FA01TR-ND,31-AP33771CFBZ-13-FA01CT-ND,31-AP33771CFBZ-13-FA01DKR-ND AP33771CFBZ-13-FA01
296-45436-2-ND,296-45436-1-ND,296-45436-6-ND TUSB319IDRFRQ1
296-39376-2-ND,296-39376-1-ND,296-39376-6-ND TPS2514DBVR
296-39952-2-ND,296-39952-1-ND,296-39952-6-ND BQ51003YFPR
UTC2000-I/MG-ND UTC2000-I/MG
336-EFP0104GM20-E-ND EFP0104GM20-E
LP2996MRX/NOPBTR-ND,LP2996MRX/NOPBCT-ND,LP2996MRX/NOPBDKR-ND LP2996MRX/NOPB
UCS1001-2-BP-TR-ND,UCS1001-2-BP-CT-ND,UCS1001-2-BP-DKR-ND UCS1001-2-BP-TR
1727-NXF6505BDA-Q100ZTR-ND,1727-NXF6505BDA-Q100ZCT-ND,1727-NXF6505BDA-Q100ZDKR-ND NXF6505BDA-Q100Z
UAA2016DGOS-ND UAA2016DG
1589-MP5031GRE-00A3-ZTR-ND,1589-MP5031GRE-00A3-ZCT-ND,1589-MP5031GRE-00A3-ZDKR-ND MP5031GRE-00A3-Z
2156-LP2997MR/NOPB-ND,LP2997MR/NOPB-ND LP2997MR/NOPB
448-2EP130RXTMA1TR-ND,448-2EP130RXTMA1CT-ND,448-2EP130RXTMA1DKR-ND 2EP130RXTMA1
296-43141-2-ND,296-43141-1-ND,296-43141-6-ND TUSB320HAIRWBR
296-39438-2-ND,296-39438-1-ND,296-39438-6-ND TPS61251DSGR
296-42543-2-ND,296-42543-1-ND,296-42543-6-ND TUSB320HIRWBR
FL5160MXTR-ND,FL5160MXCT-ND,FL5160MXDKR-ND FL5160MX
296-TPS2124YFPRTR-ND,296-TPS2124YFPRCT-ND,296-TPS2124YFPRDKR-ND TPS2124YFPR
448-CYPD3177-24LQXQ-ND CYPD3177-24LQXQ
296-TPD4S480RUKRTR-ND,296-TPD4S480RUKRCT-ND,296-TPD4S480RUKRDKR-ND TPD4S480RUKR
1589-MPQ5031GRE-0001-AEC1-ZTR-ND,1589-MPQ5031GRE-0001-AEC1-ZCT-ND,1589-MPQ5031GRE-0001-AEC1-ZDKR-ND MPQ5031GRE-0001-AEC1-Z
296-27867-2-ND,296-27867-1-ND,296-27867-6-ND TPS61252DSGT
497-17648-2-ND,497-17648-1-ND,497-17648-6-ND STUSB1602AQTR
175-MAX14636CVB+TTR-ND,175-MAX14636CVB+TCT-ND,175-MAX14636CVB+TDKR-ND MAX14636CVB+T
1727-NEH2000BYJTR-ND,1727-NEH2000BYJCT-ND,1727-NEH2000BYJDKR-ND NEH2000BYJ
UCS1002-2-BP-TR-ND,UCS1002-2-BP-CT-ND,UCS1002-2-BP-DKR-ND UCS1002-2-BP-TR
150-MCP16501TA-E/RMBTR-ND,150-MCP16501TA-E/RMBCT-ND,150-MCP16501TA-E/RMBDKR-ND MCP16501TA-E/RMB
296-TPS25730SRSMRTR-ND,296-TPS25730SRSMRCT-ND,296-TPS25730SRSMRDKR-ND TPS25730SRSMR
296-SN6505DQDBVRQ1TR-ND,296-SN6505DQDBVRQ1CT-ND,296-SN6505DQDBVRQ1DKR-ND SN6505DQDBVRQ1
296-TPS25751SRSMRTR-ND,296-TPS25751SRSMRCT-ND,296-TPS25751SRSMRDKR-ND TPS25751SRSMR
175-MAX25256ATBA/V+TTR-ND,175-MAX25256ATBA/V+TCT-ND,175-MAX25256ATBA/V+TDKR-ND MAX25256ATBA/V+T
296-21167-2-ND,296-21167-1-ND,296-21167-6-ND TPS65150RGER
568-PCA9421UKZTR-ND,568-PCA9421UKZCT-ND,568-PCA9421UKZDKR-ND PCA9421UKZ
296-UCC25800BQDGNRQ1TR-ND,296-UCC25800BQDGNRQ1CT-ND,296-UCC25800BQDGNRQ1DKR-ND UCC25800BQDGNRQ1
296-43153-2-ND,296-43153-1-ND,296-43153-6-ND SN6505ADBVT
497-18082-2-ND,497-18082-1-ND,497-18082-6-ND STUSB4700YQTR
MAX17075ETG+TTR-ND,MAX17075ETG+TCT-ND,MAX17075ETG+TDKR-ND MAX17075ETG+T
296-TPS26750SRSMRTR-ND,296-TPS26750SRSMRCT-ND,296-TPS26750SRSMRDKR-ND TPS26750SRSMR
296-37845-2-ND,296-37845-1-ND,296-UCC29002DR/1DKR-ND UCC29002DR/1
296-41809-2-ND,296-41809-1-ND,296-41809-6-ND UCC29002DR
568-PCA9420BSAZTR-ND,568-PCA9420BSAZCT-ND,568-PCA9420BSAZDKR-ND PCA9420BSAZ
1589-MP6908AGJ-PTR-ND,1589-MP6908AGJ-PCT-ND,1589-MP6908AGJ-PDKR-ND MP6908AGJ-P
296-TPS6521904RHBRTR-ND,296-TPS6521904RHBRCT-ND,296-TPS6521904RHBRDKR-ND TPS6521904RHBR
296-TPS6521908RHBRTR-ND,296-TPS6521908RHBRCT-ND,296-TPS6521908RHBRDKR-ND TPS6521908RHBR
175-MAX77958CEWV+TTR-ND,175-MAX77958CEWV+TCT-ND,175-MAX77958CEWV+TDKR-ND MAX77958CEWV+T
296-TPS6521901RHBRTR-ND,296-TPS6521901RHBRCT-ND,296-TPS6521901RHBRDKR-ND TPS6521901RHBR
1589-MP5470GL-0000-ZTR-ND,1589-MP5470GL-0000-ZCT-ND,1589-MP5470GL-0000-ZDKR-ND MP5470GL-0000-Z
MAX4840AEXT+TTR-ND,MAX4840AEXT+TCT-ND,MAX4840AEXT+TDKR-ND MAX4840AEXT+T
296-13387-5-ND TPS2148IDGN
1964-1012-2-ND,1964-1012-1-ND,1964-1012-6-ND PCC110
296-16904-2-ND,296-16904-1-ND,296-16904-6-ND,2156-TPS65145RGER-ND TPS65145RGER
296-BQ51013CRHLRTR-ND,296-BQ51013CRHLRCT-ND,296-BQ51013CRHLRDKR-ND BQ51013CRHLR
MAX1823BEUB+TTR-ND,MAX1823BEUB+TCT-ND,MAX1823BEUB+TDKR-ND MAX1823BEUB+T
296-49010-2-ND,296-49010-1-ND,296-49010-6-ND TPS651851RSLR
296-TPS6522053RHBRTR-ND,296-TPS6522053RHBRCT-ND,296-TPS6522053RHBRDKR-ND TPS6522053RHBR
MAX4840EXT+TTR-ND,MAX4840EXT+TCT-ND,MAX4840EXT+TDKR-ND MAX4840EXT+T
296-41761-2-ND,296-41761-1-ND,296-41761-6-ND TPS65150QPWPRQ1
296-44365-2-ND,296-44365-1-ND,296-44365-6-ND TPS650061RUKR
559-R9A02G011GNP#AC0-ND R9A02G011GNP#AC0
1028-RT1719GQWTR-ND,1028-RT1719GQWCT-ND,1028-RT1719GQWDKR-ND RT1719GQW
296-TPS26636PWPRTR-ND,296-TPS26636PWPRCT-ND,296-TPS26636PWPRDKR-ND TPS26636PWPR
568-PCA9460AUKZTR-ND,568-PCA9460AUKZCT-ND,568-PCA9460AUKZDKR-ND PCA9460AUKZ
175-MAX14699EWC+TTR-ND,175-MAX14699EWC+TCT-ND,175-MAX14699EWC+TDKR-ND MAX14699EWC+T
296-49643-2-ND,296-49643-1-ND,296-49643-6-ND HD3SS3220RNHT
497-4551-ND AVS1ACP08
296-35067-2-ND,296-35067-1-ND,296-35067-6-ND,2156-BQ51051BRHLR-ND BQ51051BRHLR
296-35638-2-ND,296-35638-1-ND,296-35638-6-ND BQ51013BRHLT
497-STPMIC1BPQRTR-ND,497-STPMIC1BPQRCT-ND,497-STPMIC1BPQRDKR-ND STPMIC1BPQR
296-39469-2-ND,296-39469-1-ND,296-39469-6-ND TPS65910AA1RSLR
505-MAX17523AATE±ND MAX17523AATE+
296-37078-2-ND,296-37078-1-ND,296-37078-6-ND BQ25505RGRR
296-UCC25800AQDGNQ1-ND UCC25800AQDGNQ1
296-48495-2-ND,296-48495-1-ND,296-48495-6-ND BQ25504RGTR
505-LTC4360CSC8-1#TRMPBFTR-ND,505-LTC4360CSC8-1#TRMPBFCT-ND,505-LTC4360CSC8-1#TRMPBFDKR-ND LTC4360CSC8-1#TRMPBF
296-40880-2-ND,296-40880-1-ND,296-40880-6-ND TPS65217DRSLR
1028-RTQ6749GQW-QT-A2TR-ND,1028-RTQ6749GQW-QT-A2CT-ND,1028-RTQ6749GQW-QT-A2DKR-ND RTQ6749GQW-QT-A2
175-MAX17523ATE+TTR-ND,175-MAX17523ATE+TCT-ND,175-MAX17523ATE+TDKR-ND MAX17523ATE+T
MAX17523ATE±ND MAX17523ATE+
296-30568-2-ND,296-30568-1-ND,296-30568-6-ND BQ51013ARHLR
296-28832-2-ND,296-28832-1-ND,296-28832-6-ND,2156-TPS65185RGZR-ND TPS65185RGZR
175-MAX77840EWG+TTR-ND,175-MAX77840EWG+TCT-ND,175-MAX77840EWG+TDKR-ND MAX77840EWG+T
296-TPS6521920WRHBRQ1TR-ND,296-TPS6521920WRHBRQ1CT-ND,296-TPS6521920WRHBRQ1DKR-ND TPS6521920WRHBRQ1
505-LTC4360ISC8-1#TRMPBFTR-ND,505-LTC4360ISC8-1#TRMPBFCT-ND,505-LTC4360ISC8-1#TRMPBFDKR-ND LTC4360ISC8-1#TRMPBF
505-LTC4360ISC8-2#TRMPBFTR-ND,505-LTC4360ISC8-2#TRMPBFCT-ND,505-LTC4360ISC8-2#TRMPBFDKR-ND LTC4360ISC8-2#TRMPBF
296-29494-ND TPS65910AA1RSL
MAX17525ATP±ND MAX17525ATP+
296-32032-2-ND,296-32032-1-ND,296-32032-6-ND BQ24640RVAT
MAX14721ATP±ND MAX14721ATP+
296-LP877451A1RXVRQ1TR-ND,296-LP877451A1RXVRQ1CT-ND,296-LP877451A1RXVRQ1DKR-ND LP877451A1RXVRQ1
LTC4367CMS8#PBF-ND LTC4367CMS8#PBF
LTC4367CDD#PBF-ND LTC4367CDD#PBF
296-29741-2-ND,296-29741-1-ND,296-29741-6-ND,2156-BQ25504RGTT-ND BQ25504RGTT
296-40879-2-ND,296-40879-1-ND,296-40879-6-ND TPS65217BRSLR
LTC4365CTS8#TRPBFTR-ND,LTC4365CTS8#TRPBFCT-ND,LTC4365CTS8#TRPBFDKR-ND LTC4365CTS8#TRPBF
LTC4365CDDB#TRPBFTR-ND,LTC4365CDDB#TRPBFCT-ND,LTC4365CDDB#TRPBFDKR-ND LTC4365CDDB#TRPBF
175-MAX77658BANX+TTR-ND,175-MAX77658BANX+TCT-ND,175-MAX77658BANX+TDKR-ND MAX77658BANX+T
175-MAX16946GTE/V+TTR-ND,175-MAX16946GTE/V+TCT-ND,175-MAX16946GTE/V+TDKR-ND MAX16946GTE/V+T
MAX16946GEE/V±ND MAX16946GEE/V+
505-LTC4361CTS8-2#TRMPBFTR-ND,505-LTC4361CTS8-2#TRMPBFCT-ND,505-LTC4361CTS8-2#TRMPBFDKR-ND LTC4361CTS8-2#TRMPBF
497-STPMIC1DPQRTR-ND,497-STPMIC1DPQRCT-ND,497-STPMIC1DPQRDKR-ND STPMIC1DPQR
LTC4365IDDB#TRPBFTR-ND,LTC4365IDDB#TRPBFCT-ND,LTC4365IDDB#TRPBFDKR-ND LTC4365IDDB#TRPBF
568-TEA2208T/1JTR-ND,568-TEA2208T/1JCT-ND,568-TEA2208T/1JDKR-ND TEA2208T/1J
505-LTC4365ITS8#TRPBFTR-ND,505-LTC4365ITS8#TRPBFCT-ND,505-LTC4365ITS8#TRPBFDKR-ND LTC4365ITS8#TRPBF
296-TPS25762CQRQLRQ1TR-ND,296-TPS25762CQRQLRQ1CT-ND,296-TPS25762CQRQLRQ1DKR-ND TPS25762CQRQLRQ1
LM25066APSQE/NOPBTR-ND,LM25066APSQE/NOPBCT-ND,LM25066APSQE/NOPBDKR-ND LM25066APSQE/NOPB
505-LTC4361IDC-2#TRMPBFTR-ND,505-LTC4361IDC-2#TRMPBFCT-ND,505-LTC4361IDC-2#TRMPBFDKR-ND LTC4361IDC-2#TRMPBF
LTC4361ITS8-1#TRMPBFTR-ND,LTC4361ITS8-1#TRMPBFCT-ND,LTC4361ITS8-1#TRMPBFDKR-ND LTC4361ITS8-1#TRMPBF
LTC4361HTS8-2#TRMPBFTR-ND,LTC4361HTS8-2#TRMPBFCT-ND,LTC4361HTS8-2#TRMPBFDKR-ND LTC4361HTS8-2#TRMPBF
LTC4361HDC-2#TRMPBFTR-ND,LTC4361HDC-2#TRMPBFCT-ND,LTC4361HDC-2#TRMPBFDKR-ND LTC4361HDC-2#TRMPBF
505-LTC4361HTS8-1#TRMPBFTR-ND,505-LTC4361HTS8-1#TRMPBFCT-ND,505-LTC4361HTS8-1#TRMPBFDKR-ND LTC4361HTS8-1#TRMPBF
505-LTC4365HDDB#TRPBFTR-ND,505-LTC4365HDDB#TRPBFCT-ND,505-LTC4365HDDB#TRPBFDKR-ND LTC4365HDDB#TRPBF
505-LTC4365HTS8-1#TRPBFTR-ND,505-LTC4365HTS8-1#TRPBFCT-ND,505-LTC4365HTS8-1#TRPBFDKR-ND LTC4365HTS8-1#TRPBF
505-LTC4365HDDB-1#TRMPBFTR-ND,505-LTC4365HDDB-1#TRMPBFCT-ND,505-LTC4365HDDB-1#TRMPBFDKR-ND LTC4365HDDB-1#TRMPBF
505-LTC4365HTS8-1#TRMPBFTR-ND,505-LTC4365HTS8-1#TRMPBFCT-ND,505-LTC4365HTS8-1#TRMPBFDKR-ND LTC4365HTS8-1#TRMPBF
MAX14527ETA+TTR-ND,MAX14527ETA+TCT-ND,MAX14527ETA+TDKR-ND MAX14527ETA+T
568-TEA2209T/1JTR-ND,568-TEA2209T/1JCT-ND,568-TEA2209T/1JDKR-ND TEA2209T/1J
LTC4367IDD#PBF-ND LTC4367IDD#PBF
505-LTC4367IMS8-1#PBF-ND LTC4367IMS8-1#PBF
LM1949N/NOPB-ND LM1949N/NOPB
MC32PF3000A1EP-ND MC32PF3000A1EP
1589-MP8833GD-0000-ZTR-ND,1589-MP8833GD-0000-ZCT-ND,1589-MP8833GD-0000-ZDKR-ND MP8833GD-0000-Z
ADM1192-1ARMZ-R7TR-ND,ADM1192-1ARMZ-R7CT-ND,ADM1192-1ARMZ-R7DKR-ND ADM1192-1ARMZ-R7
505-ADM1191-2ARMZ-R7TR-ND,505-ADM1191-2ARMZ-R7CT-ND,505-ADM1191-2ARMZ-R7DKR-ND ADM1191-2ARMZ-R7
LT4430IS6#TRMPBFTR-ND,LT4430IS6#TRMPBFCT-ND,LT4430IS6#TRMPBFDKR-ND LT4430IS6#TRMPBF
568-13804-ND MC33FS4500CAE
MAX845EUA±ND MAX845EUA+
296-40234-2-ND,296-40234-1-ND,296-40234-6-ND,2156-LM5056APMHX/NOPB-ND LM5056APMHX/NOPB
505-LT3468ES5#TRMPBFTR-ND,505-LT3468ES5#TRMPBFCT-ND,505-LT3468ES5#TRMPBFDKR-ND LT3468ES5#TRMPBF
MC34PF3000A1EP-ND MC34PF3000A1EP
505-LTC4367HDD#TRPBFTR-ND,505-LTC4367HDD#TRPBFCT-ND,505-LTC4367HDD#TRPBFDKR-ND LTC4367HDD#TRPBF
505-LTC4367HMS8#PBF-ND LTC4367HMS8#PBF
LTC4425EDD#PBF-ND LTC4425EDD#PBF
175-MAX17851AUP/V+TTR-ND,175-MAX17851AUP/V+TCT-ND,175-MAX17851AUP/V+TDKR-ND MAX17851AUP/V+T
568-MC33664ATL1EGR2TR-ND,568-MC33664ATL1EGR2CT-ND,568-MC33664ATL1EGR2DKR-ND MC33664ATL1EGR2
MAX17561AUD±ND MAX17561AUD+
2156-DRV592VFP-ND,296-12550-ND DRV592VFP
296-O31310QRWGRQ1TR-ND,296-O31310QRWGRQ1CT-ND,296-O31310QRWGRQ1DKR-ND O31310QRWGRQ1
568-MFS2613AMDA2AD-ND MFS2613AMDA2AD
568-MFS2613AMDA4AD-ND MFS2613AMDA4AD
296-2499-5-ND UC2907DW
568-MFS2613AMDA3AD-ND MFS2613AMDA3AD
20-RAA215300A2GNP#HA1TR-ND,20-RAA215300A2GNP#HA1CT-ND,20-RAA215300A2GNP#HA1DKR-ND RAA215300A2GNP#HA1
LTC4425IMSE#PBF-ND LTC4425IMSE#PBF
LTC1153CS8#TRPBFTR-ND,LTC1153CS8#TRPBFCT-ND,LTC1153CS8#TRPBFDKR-ND LTC1153CS8#TRPBF
LTC1153CS8#PBF-ND LTC1153CS8#PBF
LT3420EMS-1#PBF-ND LT3420EMS-1#PBF
296-37014-2-ND,296-37014-1-ND,296-37014-6-ND,2156-BQ25570RGRT-ND BQ25570RGRT
MAX749CSA±ND MAX749CSA+
568-13859-ND MC34PF4210A1ES
LT3420EDD-1#PBF-ND LT3420EDD-1#PBF
MAX17000AETG+TR-ND,MAX17000AETG+CT-ND,MAX17000AETG+DKR-ND MAX17000AETG+T
497-18911-2-ND,497-18911-1-ND,497-18911-6-ND L9945TR
505-MAX17563AUD±ND MAX17563AUD+
MAX17562AUD±ND MAX17562AUD+
505-LTC3108EDE#TRPBFTR-ND,505-LTC3108EDE#TRPBFCT-ND,505-LTC3108EDE#TRPBFDKR-ND LTC3108EDE#TRPBF
161-LTC3108EGN#TRPBFTR-ND,161-LTC3108EGN#TRPBFCT-ND,161-LTC3108EGN#TRPBFDKR-ND LTC3108EGN#TRPBF
LTC3127EMSE#PBF-ND LTC3127EMSE#PBF
568-MC33PF8100EQES-ND MC33PF8100EQES
505-LTC3588EMSE-1#TRPBFTR-ND,505-LTC3588EMSE-1#TRPBFCT-ND,505-LTC3588EMSE-1#TRPBFDKR-ND LTC3588EMSE-1#TRPBF
505-LTC4125EUFD#TRPBFTR-ND,505-LTC4125EUFD#TRPBFCT-ND,505-LTC4125EUFD#TRPBFDKR-ND LTC4125EUFD#TRPBF
505-LTC4125EUFD#PBF-ND LTC4125EUFD#PBF
1744-AMP8DB6QF65-ND AMP8DB6QF65
MC34709VK-ND MC34709VK
MC34704AEP-ND MC34704AEP
296-TPS65941213RWERQ1TR-ND,296-TPS65941213RWERQ1CT-ND,296-TPS65941213RWERQ1DKR-ND TPS65941213RWERQ1
296-TPS65941120RWERQ1TR-ND,296-TPS65941120RWERQ1CT-ND,296-TPS65941120RWERQ1DKR-ND TPS65941120RWERQ1
505-LTC4125IUFD#PBF-ND LTC4125IUFD#PBF
LTC3101EUF#PBF-ND LTC3101EUF#PBF
296-25721-2-ND,296-25721-1-ND,296-25721-6-ND,2156-UCD9246RGCT-ND UCD9246RGCT
LT3751IUFD#PBF-ND LT3751IUFD#PBF
568-MVR5510AMDA0ES-ND MVR5510AMDA0ES
568-MVR5510AMDALES-ND MVR5510AMDALES
296-25804-ND UCD9248PFC
296-37687-2-ND,296-37687-1-ND,296-37687-6-ND TPS65950A3ZXNR
296-ADS131B23QPHPRQ1TR-ND,296-ADS131B23QPHPRQ1CT-ND,296-ADS131B23QPHPRQ1DKR-ND ADS131B23QPHPRQ1
LTC3589IUJ-2#PBF-ND LTC3589IUJ-2#PBF
505-MAX16922ATPH/V±ND MAX16922ATPH/V+
296-48205-2-ND,296-48205-1-ND,296-48205-6-ND TPS6590378ZWST
5903-MM101-02ADA-TR-ND,5903-MM101-02ADA-TRCT-ND,5903-MM101-02ADA-TRDKR-ND MM101-02ADA-TR
2156-DRV591VFP-ND,296-12430-ND DRV591VFP
MAX1979ETM±ND MAX1979ETM+
MAX1968EUI±ND MAX1968EUI+
NCP398MUTBGOSTR-ND,NCP398MUTBGOSCT-ND,NCP398MUTBGOSDKR-ND NCP398MUTBG
UAA2016PGOS-ND UAA2016PG
CDM10VDXTSA1TR-ND,CDM10VDXTSA1CT-ND,CDM10VDXTSA1DKR-ND CDM10VDXTSA1
CDM10V2XTSA1TR-ND,CDM10V2XTSA1CT-ND,CDM10V2XTSA1DKR-ND CDM10V2XTSA1
AP5727WG-7DITR-ND,AP5727WG-7DICT-ND,AP5727WG-7DIDKR-ND AP5727WG-7
CDM10VXTSA1TR-ND,CDM10VXTSA1CT-ND,CDM10VXTSA1DKR-ND CDM10VXTSA1
NCS1002DR2GOSTR-ND,NCS1002DR2GOSCT-ND,NCS1002DR2GOSDKR-ND NCS1002DR2G
NCS1002ADR2GOSTR-ND,NCS1002ADR2GOSCT-ND,NCS1002ADR2GOSDKR-ND NCS1002ADR2G
BD42500G-CTR-ND,BD42500G-CCT-ND,BD42500G-CDKR-ND BD42500G-CTR
BD42530EFJ-CE2TR-ND,BD42530EFJ-CE2CT-ND,BD42530EFJ-CE2DKR-ND BD42530EFJ-CE2
PI5USB30216DXUAEXTR-ND,PI5USB30216DXUAEXCT-ND,PI5USB30216DXUAEXDKR-ND PI5USB30216DXUAEX
296-37668-2-ND,296-37668-1-ND,296-37668-6-ND TPS2513DBVR
296-35052-2-ND,296-35052-1-ND,296-35052-6-ND,2156-TPD5S115YFFR-ND TPD5S115YFFR
LP2995MRX/NOPBTR-ND,LP2995MRX/NOPBCT-ND,LP2995MRX/NOPBDKR-ND LP2995MRX/NOPB
LP2995MX/NOPBTR-ND,LP2995MX/NOPBCT-ND,LP2995MX/NOPBDKR-ND LP2995MX/NOPB
31-AP43781DKZ-13TR-ND,31-AP43781DKZ-13CT-ND,31-AP43781DKZ-13DKR-ND AP43781DKZ-13
LP2997MX/NOPBTR-ND,LP2997MX/NOPBCT-ND,LP2997MX/NOPBDKR-ND LP2997MX/NOPB
EMC1702-1-KP-TR-ND,EMC1702-1-KP-CT-ND,EMC1702-1-KP-DKR-ND EMC1702-1-KP-TR
296-TPS2511QDGNQ1-ND TPS2511QDGNQ1
LP2995MR/NOPB-ND LP2995MR/NOPB
LP2995M/NOPB-ND LP2995M/NOPB
296-36071-5-ND TPS2511DGN
296-TPS2514DBVTTR-ND,296-TPS2514DBVTCT-ND,296-TPS2514DBVTDKR-ND,2156-TPS2514DBVT-ND TPS2514DBVT
LP2997M/NOPB-ND LP2997M/NOPB
PI5USB30213XEAEXTR-ND,PI5USB30213XEAEXCT-ND,PI5USB30213XEAEXDKR-ND PI5USB30213XEAEX
559-RAA2900014H12HPD#GB0TR-ND,559-RAA2900014H12HPD#GB0CT-ND,559-RAA2900014H12HPD#GB0DKR-ND RAA2900014H12HPD#GB0
EMC1704-2-AP-TR-ND,EMC1704-2-AP-CT-ND,EMC1704-2-AP-DKR-ND EMC1704-2-AP-TR
LP2996MR/NOPB-ND LP2996MR/NOPB
296-48762-2-ND,296-48762-1-ND,296-48762-6-ND TPS65000RTER
2763-KTU1108EFAA-TR-ND,2763-KTU1108EFAA-TRCT-ND,2763-KTU1108EFAA-TRDKR-ND KTU1108EFAA-TR
2156-LP2996AMR/NOPB-ND,296-37966-5-ND LP2996AMR/NOPB
1662-S-8471AAA-I6T1UTR-ND,1662-S-8471AAA-I6T1UCT-ND,1662-S-8471AAA-I6T1UDKR-ND S-8471AAA-I6T1U
296-35158-2-ND,296-35158-1-ND,296-35158-6-ND LM10010SD/NOPB
559-RAA2900024H12HPD#GB0TR-ND,559-RAA2900024H12HPD#GB0CT-ND,559-RAA2900024H12HPD#GB0DKR-ND RAA2900024H12HPD#GB0
296-27866-2-ND,296-27866-1-ND,296-27866-6-ND TPS61251DSGT
1589-MP5031GRE-00A3-PTR-ND,1589-MP5031GRE-00A3-PCT-ND,1589-MP5031GRE-00A3-PDKR-ND MP5031GRE-00A3-P
2129-RP605Z333B-E2-TTR-ND,2129-RP605Z333B-E2-TCT-ND,2129-RP605Z333B-E2-TDKR-ND RP605Z333B-E2-T
2129-RP605Z334A-E2-TTR-ND,2129-RP605Z334A-E2-TCT-ND,2129-RP605Z334A-E2-TDKR-ND RP605Z334A-E2-T
497-17117-2-ND,497-17117-1-ND,497-17117-6-ND STUSB4700QTR
296-40862-2-ND,296-40862-1-ND,296-40862-6-ND TPS65000TRTERQ1
UCS1002-2-BP-ND UCS1002-2-BP
296-24625-2-ND,296-24625-1-ND,296-24625-6-ND TPS65000RTET
2763-KTU1131EUAC-TR-ND,2763-KTU1131EUAC-TRCT-ND,2763-KTU1131EUAC-TRDKR-ND KTU1131EUAC-TR
497-STUSB4761QTR-ND,497-STUSB4761QCT-ND,497-STUSB4761QDKR-ND STUSB4761QTR
FL5150MXTR-ND,FL5150MXCT-ND,FL5150MXDKR-ND FL5150MX
LM26484SQE/NOPBTR-ND,LM26484SQE/NOPBCT-ND,LM26484SQE/NOPBDKR-ND LM26484SQE/NOPB
559-UPD166033T1U-E1-AYTR-ND,559-UPD166033T1U-E1-AYCT-ND,559-UPD166033T1U-E1-AYDKR-ND UPD166033T1U-E1-AY
1589-MP2696AGQ-0000-PTR-ND,1589-MP2696AGQ-0000-PCT-ND,1589-MP2696AGQ-0000-PDKR-ND MP2696AGQ-0000-P
MAX1931EUB±ND MAX1931EUB+
296-TPS65035000RZDRQ1TR-ND,296-TPS65035000RZDRQ1CT-ND,296-TPS65035000RZDRQ1DKR-ND TPS65035000RZDRQ1
NCS37010MNTWGOSTR-ND,NCS37010MNTWGOSCT-ND,NCS37010MNTWGOSDKR-ND NCS37010MNTWG
296-28012-2-ND,296-28012-1-ND,296-28012-6-ND UCC39002DR
296-53547-2-ND,296-53547-1-ND,296-53547-6-ND SN6505AQDBVTQ1
296-SN6505DQDBVTQ1TR-ND,296-SN6505DQDBVTQ1CT-ND,296-SN6505DQDBVTQ1DKR-ND SN6505DQDBVTQ1
1662-S-8474AC-I8T1UTR-ND,1662-S-8474AC-I8T1UCT-ND,1662-S-8474AC-I8T1UDKR-ND S-8474AC-I8T1U
296-37245-2-ND,296-37245-1-ND,296-37245-6-ND BQ51003YFPT
296-41941-5-ND TPS65150PWP
LP3906SQ-JXXI/NOPBTR-ND,LP3906SQ-JXXI/NOPBCT-ND,LP3906SQ-JXXI/NOPBDKR-ND LP3906SQ-JXXI/NOPB
MAX17112ETB+TTR-ND,MAX17112ETB+TCT-ND,MAX17112ETB+TDKR-ND MAX17112ETB+T
MAX4866LEUT+TTR-ND,MAX4866LEUT+TCT-ND,MAX4866LEUT+TDKR-ND MAX4866LEUT+T
2651-EM8500-A001-LF24B+TR-ND,2651-EM8500-A001-LF24B+CT-ND,2651-EM8500-A001-LF24B+DKR-ND EM8500-A001-LF24B+
TLE9471ESV33XUMA1TR-ND,TLE9471ESV33XUMA1CT-ND,TLE9471ESV33XUMA1DKR-ND TLE9471ESV33XUMA1
296-48763-2-ND,296-48763-1-ND,296-48763-6-ND TPS65001RUKR
MAX17612AATB±ND MAX17612AATB+
568-MFS5600AMMA0ES-ND MFS5600AMMA0ES
296-48726-2-ND,296-48726-1-ND,296-48726-6-ND TPS2151IPWPR
296-18998-2-ND,296-18998-1-ND,296-18998-6-ND,2156-TPS65140PWPR-ND TPS65140PWPR
LM2642MTCX/NOPBTR-ND,LM2642MTCX/NOPBCT-ND,LM2642MTCX/NOPBDKR-ND LM2642MTCX/NOPB
296-BQ51013BQWRHLRQ1TR-ND,296-BQ51013BQWRHLRQ1CT-ND,296-BQ51013BQWRHLRQ1DKR-ND BQ51013BQWRHLRQ1
MAX16129UAAGA±ND MAX16129UAAGA+
505-MAX1940EEE±ND MAX1940EEE+
497-SPSB0815-TR-ND,497-SPSB0815-TRCT-ND,497-SPSB0815-TRDKR-ND SPSB0815-TR
296-48500-2-ND,296-48500-1-ND,296-48500-6-ND,2156-BQ51222YFPR-ND BQ51222YFPR
296-BQ51050BYFPRTR-ND,296-BQ51050BYFPRCT-ND,296-BQ51050BYFPRDKR-ND,2156-BQ51050BYFPR-ND BQ51050BYFPR
846-BD86852MUF-CE2TR-ND,846-BD86852MUF-CE2CT-ND,846-BD86852MUF-CE2DKR-ND BD86852MUF-CE2
296-35504-2-ND,296-35504-1-ND,296-35504-6-ND BQ51013BYFPT
175-MAX16126TCD+TTR-ND,175-MAX16126TCD+TCT-ND,175-MAX16126TCD+TDKR-ND MAX16126TCD+T
296-TPS26636PWPTTR-ND,296-TPS26636PWPTCT-ND,296-TPS26636PWPTDKR-ND TPS26636PWPT
559-RAJ2800034H12HPF#GB0TR-ND,559-RAJ2800034H12HPF#GB0CT-ND,559-RAJ2800034H12HPF#GB0DKR-ND RAJ2800034H12HPF#GB0
448-TLE92633BQXV33XUMA2TR-ND,448-TLE92633BQXV33XUMA2CT-ND,448-TLE92633BQXV33XUMA2DKR-ND TLE92633BQXV33XUMA2
448-TLE92633BQXXUMA2TR-ND,448-TLE92633BQXXUMA2CT-ND,448-TLE92633BQXXUMA2DKR-ND TLE92633BQXXUMA2
568-14413-ND MC32PF3001A7EP
296-21429-2-ND,296-21429-1-ND,296-21429-6-ND,2156-TPS65165RSBR-ND TPS65165RSBR
296-41764-2-ND,296-41764-1-ND,296-41764-6-ND TPS65910A31A1RSLR
296-43623-2-ND,296-43623-1-ND,296-43623-6-ND,2156-TPS659102A1RSLR-ND TPS659102A1RSLR
296-TPS25846QWRHBRQ1TR-ND,296-TPS25846QWRHBRQ1CT-ND,296-TPS25846QWRHBRQ1DKR-ND TPS25846QWRHBRQ1
296-25358-2-ND,296-25358-1-ND,296-25358-6-ND,2156-TPS650061RUKT-ND TPS650061RUKT
MAX16928CGUP/V±ND MAX16928CGUP/V+
SM72295MAX/NOPBTR-ND,SM72295MAX/NOPBCT-ND,SM72295MAX/NOPBDKR-ND SM72295MAX/NOPB
296-25220-2-ND,296-25220-1-ND,296-25220-6-ND TPS650531RGER
296-25183-2-ND,296-25183-1-ND,296-25183-6-ND TPS650532RGER
296-35503-2-ND,296-35503-1-ND,296-35503-6-ND,2156-BQ51051BRHLT-ND BQ51051BRHLT
296-BQ51051BYFPTTR-ND,296-BQ51051BYFPTCT-ND,296-BQ51051BYFPTDKR-ND BQ51051BYFPT
175-MAX20084ATEA/VY+TTR-ND,175-MAX20084ATEA/VY+TCT-ND,175-MAX20084ATEA/VY+TDKR-ND MAX20084ATEA/VY+T
505-LT3585EDDB-3#TRPBFTR-ND,505-LT3585EDDB-3#TRPBFCT-ND,505-LT3585EDDB-3#TRPBFDKR-ND LT3585EDDB-3#TRPBF
LTC4360CSC8-2#TRMPBFTR-ND,LTC4360CSC8-2#TRMPBFCT-ND,LTC4360CSC8-2#TRMPBFDKR-ND LTC4360CSC8-2#TRMPBF
MAX16126TCA/V±ND MAX16126TCA/V+
497-16990-2-ND,497-16990-1-ND,497-16990-6-ND L99PM62GXPTR
296-TPS25830AQWRHBRQ1TR-ND,296-TPS25830AQWRHBRQ1CT-ND,296-TPS25830AQWRHBRQ1DKR-ND TPS25830AQWRHBRQ1
2156-TPS65910A1RSL-ND,296-28826-ND TPS65910A1RSL
296-30399-5-ND TPS65910A3A1RSL
296-LP87702DRHBRQ1TR-ND,296-LP87702DRHBRQ1CT-ND,296-LP87702DRHBRQ1DKR-ND LP87702DRHBRQ1
LT6110IDC#TRMPBFTR-ND,LT6110IDC#TRMPBFCT-ND,LT6110IDC#TRMPBFDKR-ND LT6110IDC#TRMPBF
296-TPS25840QWRHBRQ1TR-ND,296-TPS25840QWRHBRQ1CT-ND,296-TPS25840QWRHBRQ1DKR-ND TPS25840QWRHBRQ1
MAX253CUA±ND MAX253CUA+
175-MAX77643AANA+TTR-ND,175-MAX77643AANA+TCT-ND,175-MAX77643AANA+TDKR-ND MAX77643AANA+T
448-WLC1115-68LQXQ-ND WLC1115-68LQXQ
MC34PF3001A7EP-ND MC34PF3001A7EP
296-39553-2-ND,296-39553-1-ND,296-39553-6-ND BQ25505RGRT
296-27038-2-ND,296-27038-1-ND,296-27038-6-ND,2156-TPS65051RSMR-ND TPS65051RSMR
448-IR35223MTRPBFXUMA1TR-ND,448-IR35223MTRPBFXUMA1CT-ND,448-IR35223MTRPBFXUMA1DKR-ND IR35223MTRPBFXUMA1
LTC4365CDDB-1#TRMPBFTR-ND,LTC4365CDDB-1#TRMPBFCT-ND,LTC4365CDDB-1#TRMPBFDKR-ND LTC4365CDDB-1#TRMPBF
LT6110HDC#TRMPBFTR-ND,LT6110HDC#TRMPBFCT-ND,LT6110HDC#TRMPBFDKR-ND LT6110HDC#TRMPBF
505-LTC4365CTS8-1#TRMPBFTR-ND,505-LTC4365CTS8-1#TRMPBFCT-ND,505-LTC4365CTS8-1#TRMPBFDKR-ND LTC4365CTS8-1#TRMPBF
175-MAX77654BENV+TTR-ND,175-MAX77654BENV+TCT-ND,175-MAX77654BENV+TDKR-ND MAX77654BENV+T
175-MAX77654MENV+TTR-ND,175-MAX77654MENV+TCT-ND,175-MAX77654MENV+TDKR-ND MAX77654MENV+T
448-IR35221MTRPBFTR-ND,448-IR35221MTRPBFCT-ND,448-IR35221MTRPBFDKR-ND IR35221MTRPBF
LTC4361CTS8-1#TRMPBFTR-ND,LTC4361CTS8-1#TRMPBFCT-ND,LTC4361CTS8-1#TRMPBFDKR-ND LTC4361CTS8-1#TRMPBF
296-39954-2-ND,296-39954-1-ND,296-39954-6-ND BQ51013ARHLT
296-BQ51013AYFPTTR-ND,296-BQ51013AYFPTCT-ND,296-BQ51013AYFPTDKR-ND,2156-BQ51013AYFPT-ND BQ51013AYFPT
LTC4362CDCB-1#TRMPBFTR-ND,LTC4362CDCB-1#TRMPBFCT-ND,LTC4362CDCB-1#TRMPBFDKR-ND LTC4362CDCB-1#TRMPBF
175-MAX14721ATP+TTR-ND,175-MAX14721ATP+TCT-ND,175-MAX14721ATP+TDKR-ND MAX14721ATP+T
MAX16946GTE/V±ND MAX16946GTE/V+
505-MAX14722ATP±ND MAX14722ATP+
296-LM25066APSQ/NOPBTR-ND,296-LM25066APSQ/NOPBCT-ND,296-LM25066APSQ/NOPBDKR-ND LM25066APSQ/NOPB
2156-UC3902D-ND,296-11340-5-ND UC3902D
LTC4361IDC-1#TRPBFTR-ND,LTC4361IDC-1#TRPBFCT-ND,LTC4361IDC-1#TRPBFDKR-ND LTC4361IDC-1#TRPBF
296-21558-2-ND,296-21558-1-ND,296-21558-6-ND,2156-TPS65051RSMT-ND TPS65051RSMT
505-MAX17613CATP±ND MAX17613CATP+
505-LTC4367CDD#TRPBFTR-ND,505-LTC4367CDD#TRPBFCT-ND,505-LTC4367CDD#TRPBFDKR-ND LTC4367CDD#TRPBF
LTC4362IDCB-1#TRMPBFTR-ND,LTC4362IDCB-1#TRMPBFCT-ND,LTC4362IDCB-1#TRMPBFDKR-ND LTC4362IDCB-1#TRMPBF
LTC4367CMS8-1#PBF-ND LTC4367CMS8-1#PBF
LTC4361HDC-1#TRMPBFTR-ND,LTC4361HDC-1#TRMPBFCT-ND,LTC4361HDC-1#TRMPBFDKR-ND LTC4361HDC-1#TRMPBF
296-TPS65982DMCZBHRTR-ND,296-TPS65982DMCZBHRCT-ND,296-TPS65982DMCZBHRDKR-ND TPS65982DMCZBHR
505-LTC3553EUD#PBF-ND LTC3553EUD#PBF
MAX17613BATP±ND MAX17613BATP+
497-L99DZ200GTR-ND,497-L99DZ200GTRCT-ND,497-L99DZ200GTRDKR-ND L99DZ200GTR
LTC3554EUD#PBF-ND LTC3554EUD#PBF
296-43985-2-ND,296-43985-1-ND,296-43985-6-ND BQ29700DSER
4823-NPM1100-QDAA-RTR-ND,4823-NPM1100-QDAA-RCT-ND,4823-NPM1100-QDAA-RDKR-ND NPM1100-QDAA-R
4823-NPM1100-CAAA-E-RTR-ND,4823-NPM1100-CAAA-E-RCT-ND,4823-NPM1100-CAAA-E-RDKR-ND NPM1100-CAAA-E-R
1662-S-82A1AAG-I6T1UTR-ND,1662-S-82A1AAG-I6T1UCT-ND,1662-S-82A1AAG-I6T1UDKR-ND S-82A1AAG-I6T1U
296-BQ27427YZFRTR-ND,296-BQ27427YZFRCT-ND,296-BQ27427YZFRDKR-ND BQ27427YZFR
4823-NPM1300-CAAA-RTR-ND,4823-NPM1300-CAAA-RCT-ND,4823-NPM1300-CAAA-RDKR-ND NPM1300-CAAA-R
1662-S-8209ABB-T8T1UTR-ND,1662-S-8209ABB-T8T1UCT-ND,1662-S-8209ABB-T8T1UDKR-ND S-8209ABB-T8T1U
296-43359-2-ND,296-43359-1-ND,296-43359-6-ND BQ27426YZFR
296-BQ27Z561YPHR-R2TR-ND,296-BQ27Z561YPHR-R2CT-ND,296-BQ27Z561YPHR-R2DKR-ND BQ27Z561YPHR-R2
497-15077-2-ND,497-15077-1-ND,497-15077-6-ND STC3115AIQT
296-39941-2-ND,296-39941-1-ND,296-39941-6-ND BQ27441DRZR-G1A
296-43273-2-ND,296-43273-1-ND,296-43273-6-ND BQ76200PWR
296-36220-2-ND,296-36220-1-ND,296-36220-6-ND BQ27421YZFT-G1A
175-MAX17262HEWL+TTR-ND,175-MAX17262HEWL+TCT-ND,175-MAX17262HEWL+TDKR-ND MAX17262HEWL+T
296-37271-2-ND,296-37271-1-ND,296-37271-6-ND BQ27441DRZT-G1A
497-10526-2-ND,497-10526-1-ND,497-10526-6-ND STC3100IST
175-MAX17260SEWL+TTR-ND,175-MAX17260SEWL+TCT-ND,175-MAX17260SEWL+TDKR-ND MAX17260SEWL+T
175-MAX17262REWL+TTR-ND,175-MAX17262REWL+TCT-ND,175-MAX17262REWL+TDKR-ND MAX17262REWL+T
505-MAX17260SETD±ND MAX17260SETD+
175-MAX17260SETD+TTR-ND,175-MAX17260SETD+TCT-ND,175-MAX17260SETD+TDKR-ND MAX17260SETD+T
296-39959-2-ND,296-39959-1-ND,296-39959-6-ND BQ7692003PWR
MAX17048G+T10TR-ND,MAX17048G+T10CT-ND,MAX17048G+T10DKR-ND MAX17048G+T10
296-47251-2-ND,296-47251-1-ND,296-47251-6-ND BQ35100PWR
MAX17055EWL+TTR-ND,MAX17055EWL+TCT-ND,MAX17055EWL+TDKR-ND MAX17055EWL+T
MAX17055ETB+TTR-ND,MAX17055ETB+TCT-ND,MAX17055ETB+TDKR-ND MAX17055ETB+T
175-MAX17303X+TTR-ND,175-MAX17303X+TCT-ND,175-MAX17303X+TDKR-ND MAX17303X+T
296-24630-2-ND,296-24630-1-ND,296-24630-6-ND TPS65023RSBR
296-49567-2-ND,296-49567-1-ND,296-49567-6-ND BQ40Z50RSMR-R2
296-BQ28Z620DRZRTR-ND,296-BQ28Z620DRZRCT-ND,296-BQ28Z620DRZRDKR-ND BQ28Z620DRZR
497-8824-2-ND,497-8824-1-ND,497-8824-6-ND STC3100IQT
296-47250-2-ND,296-47250-1-ND,296-47250-6-ND BQ34110PWR
MAX17201G+TTR-ND,MAX17201G+TCT-ND,MAX17201G+TDKR-ND MAX17201G+T
505-LTC3337ACBZ-R7TR-ND,505-LTC3337ACBZ-R7CT-ND,505-LTC3337ACBZ-R7DKR-ND LTC3337ACBZ-R7
175-MAX77972EWX+TTR-ND,175-MAX77972EWX+TCT-ND,175-MAX77972EWX+TDKR-ND MAX77972EWX+T
296-39949-2-ND,296-39949-1-ND,296-39949-6-ND BQ34Z100PWR-G1
175-MAX17261METD+TTR-ND,175-MAX17261METD+TCT-ND,175-MAX17261METD+TDKR-ND MAX17261METD+T
MAX17261METD±ND MAX17261METD+
MAX6778XK+TTR-ND,MAX6778XK+TCT-ND,MAX6778XK+TDKR-ND MAX6778XK+T
296-BQ34Z100PWR-R2TR-ND,296-BQ34Z100PWR-R2CT-ND,296-BQ34Z100PWR-R2DKR-ND BQ34Z100PWR-R2
296-BQ78350DBTR-R1ATR-ND,296-BQ78350DBTR-R1ACT-ND,296-BQ78350DBTR-R1ADKR-ND BQ78350DBTR-R1A
296-BQ7693000DBTR-ND,296-BQ7693000DBCT-ND,296-BQ7693000DBDKR-ND BQ7693000DBTR
296-BQ7695202PFBRTR-ND,296-BQ7695202PFBRCT-ND,296-BQ7695202PFBRDKR-ND BQ7695202PFBR
175-MAX17320G20+TTR-ND,175-MAX17320G20+TCT-ND,175-MAX17320G20+TDKR-ND MAX17320G20+T
MAX17205G+00E-ND MAX17205G+00E
MAX17205G+TTR-ND,MAX17205G+TCT-ND,MAX17205G+TDKR-ND MAX17205G+T
296-BQ40Z80RSMTTR-ND,296-BQ40Z80RSMTCT-ND,296-BQ40Z80RSMTDKR-ND BQ40Z80RSMT
296-38833-5-ND BQ34Z100PW-G1
175-MAX17330X22+TTR-ND,175-MAX17330X22+TCT-ND,175-MAX17330X22+TDKR-ND MAX17330X22+T
505-LTC3337ERC#TRPBFTR-ND,505-LTC3337ERC#TRPBFCT-ND,505-LTC3337ERC#TRPBFDKR-ND LTC3337ERC#TRPBF
505-LTC3337ERC#TRMPBFTR-ND,505-LTC3337ERC#TRMPBFCT-ND,505-LTC3337ERC#TRMPBFDKR-ND LTC3337ERC#TRMPBF
175-MAX17335X22+TTR-ND,175-MAX17335X22+TCT-ND,175-MAX17335X22+TDKR-ND MAX17335X22+T
505-ADP5360ACBZ-2-R7TR-ND,505-ADP5360ACBZ-2-R7CT-ND,505-ADP5360ACBZ-2-R7DKR-ND ADP5360ACBZ-2-R7
296-47744-2-ND,296-47744-1-ND,296-47744-6-ND BQ40Z50RSMT-R2
448-TLE9012DQUXUMA1TR-ND,448-TLE9012DQUXUMA1CT-ND,448-TLE9012DQUXUMA1DKR-ND TLE9012DQUXUMA1
175-DS2786G+T&RTR-ND,175-DS2786G+T&RCT-ND,175-DS2786G+T&RDKR-ND DS2786G+T&R
DS2782G±ND DS2782G+
296-21511-2-ND,296-21511-1-ND,296-21511-6-ND,2156-BQ27210DRKR-ND BQ27210DRKR
505-LTC2943CDD#PBF-ND LTC2943CDD#PBF
DS2438AZ+TR-ND,DS2438AZ+CT-ND,DS2438AZ+DKR-ND DS2438AZ+T&R
505-LTC4162EUFD-L42#TRPBFTR-ND,505-LTC4162EUFD-L42#TRPBFCT-ND,505-LTC4162EUFD-L42#TRPBFDKR-ND LTC4162EUFD-L42#TRPBF
505-LTC4162EUFD-LAD#PBF-ND LTC4162EUFD-LAD#PBF
LTC4162EUFD-FADM#PBF-ND LTC4162EUFD-FADM#PBF
175-MAX38888ATD+TTR-ND,175-MAX38888ATD+TCT-ND,175-MAX38888ATD+TDKR-ND MAX38888ATD+T
DS2438Z±ND DS2438Z+
505-LTC4162IUFD-FAD#PBF-ND LTC4162IUFD-FAD#PBF
505-LTC2943IDD#PBF-ND LTC2943IDD#PBF
505-LTC2943IDD#TRPBFTR-ND,505-LTC2943IDD#TRPBFCT-ND,505-LTC2943IDD#TRPBFDKR-ND LTC2943IDD#TRPBF
505-LTC4041EUFD#PBF-ND LTC4041EUFD#PBF
LTC4040EUFD#TRPBFTR-ND,LTC4040EUFD#TRPBFCT-ND,LTC4040EUFD#TRPBFDKR-ND LTC4040EUFD#TRPBF
161-LTC4041EUFD#TRPBFTR-ND,161-LTC4041EUFD#TRPBFCT-ND,161-LTC4041EUFD#TRPBFDKR-ND LTC4041EUFD#TRPBF
DS2782E±ND DS2782E+
20-ISL94202IRTZ-ND ISL94202IRTZ
505-LTC2959IDDB#TRMPBFTR-ND,505-LTC2959IDDB#TRMPBFCT-ND,505-LTC2959IDDB#TRMPBFDKR-ND LTC2959IDDB#TRMPBF
LTC4090EDJC-5#PBF-ND LTC4090EDJC-5#PBF
505-LTC4041IUFD#PBF-ND LTC4041IUFD#PBF
ISL94202IRTZ-T7ATR-ND,ISL94202IRTZ-T7ACT-ND,ISL94202IRTZ-T7ADKR-ND ISL94202IRTZ-T7A
505-LTC2944IDD#TRPBFTR-ND,505-LTC2944IDD#TRPBFCT-ND,505-LTC2944IDD#TRPBFDKR-ND LTC2944IDD#TRPBF
505-LTC2944IDD#PBF-ND LTC2944IDD#PBF
175-DS2788E+T&RTR-ND,175-DS2788E+T&RCT-ND,175-DS2788E+T&RDKR-ND DS2788E+T&R
DS2788E±ND DS2788E+
DS2777G±ND DS2777G+
296-BQ79616PAPRQ1TR-ND,296-BQ79616PAPRQ1CT-ND,296-BQ79616PAPRQ1DKR-ND BQ79616PAPRQ1
505-ADBMS1818ASWAZ-ND ADBMS1818ASWAZ
505-LTC6811IG-1#3ZZTRPBFTR-ND,505-LTC6811IG-1#3ZZTRPBFCT-ND,505-LTC6811IG-1#3ZZTRPBFDKR-ND LTC6811IG-1#3ZZTRPBF
505-LTC6811IG-1#3ZZPBF-ND LTC6811IG-1#3ZZPBF
296-BQ79656PAPRQ1TR-ND,296-BQ79656PAPRQ1CT-ND,296-BQ79656PAPRQ1DKR-ND BQ79656PAPRQ1
505-LTC6811HG-2#TRPBFTR-ND,505-LTC6811HG-2#TRPBFCT-ND,505-LTC6811HG-2#TRPBFDKR-ND LTC6811HG-2#TRPBF
505-LTC6811HG-1#PBF-ND LTC6811HG-1#PBF
505-LTC6811HG-2#3ZZTRPBFTR-ND,505-LTC6811HG-2#3ZZTRPBFCT-ND,505-LTC6811HG-2#3ZZTRPBFDKR-ND LTC6811HG-2#3ZZTRPBF
505-LTC6811HG-1#3ZZTRPBFTR-ND,505-LTC6811HG-1#3ZZTRPBFCT-ND,505-LTC6811HG-1#3ZZTRPBFDKR-ND LTC6811HG-1#3ZZTRPBF
505-LTC6811HG-2#3ZZPBF-ND LTC6811HG-2#3ZZPBF
505-LTC6803IG-2#PBF-ND LTC6803IG-2#PBF
LTC6804IG-2#TRPBFTR-ND,LTC6804IG-2#TRPBFCT-ND,LTC6804IG-2#TRPBFDKR-ND LTC6804IG-2#TRPBF
505-LTC6804IG-2#PBF-ND LTC6804IG-2#PBF
LTC6803HG-4#PBF-ND LTC6803HG-4#PBF
LTC6801IG#PBF-ND LTC6801IG#PBF
2156-BQ2013HSN-A514-ND,296-9343-5-ND BQ2013HSN-A514
LTC6804IG-1#TRPBFTR-ND,LTC6804IG-1#TRPBFCT-ND,LTC6804IG-1#TRPBFDKR-ND LTC6804IG-1#TRPBF
505-LTC6804HG-1#PBF-ND LTC6804HG-1#PBF
505-LTC2949HLXE#3ZZPBF-ND LTC2949HLXE#3ZZPBF
488-HPM10-W29A100GTR-ND,488-HPM10-W29A100GCT-ND,488-HPM10-W29A100GDKR-ND HPM10-W29A100G
296-39944-2-ND,296-39944-1-ND,296-39944-6-ND BQ29701DSER
296-49566-2-ND,296-49566-1-ND,296-49566-6-ND BQ29733DSER
296-BQ29728DSERTR-ND,296-BQ29728DSERCT-ND,296-BQ29728DSERDKR-ND BQ29728DSER
296-39945-2-ND,296-39945-1-ND,296-39945-6-ND BQ29702DSER
296-39948-2-ND,296-39948-1-ND,296-39948-6-ND BQ29707DSER
296-39947-2-ND,296-39947-1-ND,296-39947-6-ND BQ29706DSER
296-49565-2-ND,296-49565-1-ND,296-49565-6-ND BQ29732DSER
296-BQ29737DSERTR-ND,296-BQ29737DSERCT-ND,296-BQ29737DSERDKR-ND BQ29737DSER
296-BQ298012RUGRTR-ND,296-BQ298012RUGRCT-ND,296-BQ298012RUGRDKR-ND BQ298012RUGR
296-BQ298009RUGRTR-ND,296-BQ298009RUGRCT-ND,296-BQ298009RUGRDKR-ND BQ298009RUGR
296-BQ298000RUGRTR-ND,296-BQ298000RUGRCT-ND,296-BQ298000RUGRDKR-ND BQ298000RUGR
296-BQ298217RUGRTR-ND,296-BQ298217RUGRCT-ND,296-BQ298217RUGRDKR-ND BQ298217RUGR
296-37689-2-ND,296-37689-1-ND,296-37689-6-ND BQ24392RSER
1662-S-8240ADQ-M6T1UTR-ND,1662-S-8240ADQ-M6T1UCT-ND,1662-S-8240ADQ-M6T1UDKR-ND S-8240ADQ-M6T1U
296-23341-2-ND,296-23341-1-ND,296-23341-6-ND BQ24315DSGR
1662-S-8261AAJMD-G2JT2GTR-ND,1662-S-8261AAJMD-G2JT2GCT-ND,1662-S-8261AAJMD-G2JT2GDKR-ND S-8261AAJMD-G2JT2G
296-27677-2-ND,296-27677-1-ND,296-27677-6-ND BQ29209DRBR
296-27668-2-ND,296-27668-1-ND,296-27668-6-ND BQ29200DRBR
4823-NPM1100-QDAA-R7TR-ND,4823-NPM1100-QDAA-R7CT-ND,4823-NPM1100-QDAA-R7DKR-ND NPM1100-QDAA-R7
4823-NPM1100-CAAA-E-R7TR-ND,4823-NPM1100-CAAA-E-R7CT-ND,4823-NPM1100-CAAA-E-R7DKR-ND NPM1100-CAAA-E-R7
296-32038-2-ND,296-32038-1-ND,296-32038-6-ND BQ29200DRBT
296-39970-2-ND,296-39970-1-ND,296-39970-6-ND,2156-BQ771807DPJR-ND BQ771807DPJR
296-47202-2-ND,296-47202-1-ND,296-47202-6-ND BQ27220YZFR
1662-S-82M1AAA-I6T1U7TR-ND,1662-S-82M1AAA-I6T1U7CT-ND,1662-S-82M1AAA-I6T1U7DKR-ND S-82M1AAA-I6T1U7
4823-NPM1300-CAAA-R7TR-ND,4823-NPM1300-CAAA-R7CT-ND,4823-NPM1300-CAAA-R7DKR-ND NPM1300-CAAA-R7
296-BQ27Z558YPHRTR-ND,296-BQ27Z558YPHRCT-ND,296-BQ27Z558YPHRDKR-ND BQ27Z558YPHR
296-LM74500QDDFRQ1TR-ND,296-LM74500QDDFRQ1CT-ND,296-LM74500QDDFRQ1DKR-ND LM74500QDDFRQ1
1662-S-8252AAG-M6T1UTR-ND,1662-S-8252AAG-M6T1UCT-ND,1662-S-8252AAG-M6T1UDKR-ND S-8252AAG-M6T1U
1662-S-8252AAL-M6T1UTR-ND,1662-S-8252AAL-M6T1UCT-ND,1662-S-8252AAL-M6T1UDKR-ND S-8252AAL-M6T1U
296-BQ7791501PWRTR-ND,296-BQ7791501PWRCT-ND,296-BQ7791501PWRDKR-ND BQ7791501PWR
296-50995-2-ND,296-50995-1-ND,296-50995-6-ND BQ7791500PWR
296-BQ7791514PWRTR-ND,296-BQ7791514PWRCT-ND,296-BQ7791514PWRDKR-ND BQ7791514PWR
497-15387-2-ND,497-15387-1-ND,497-15387-6-ND STC3117IJT
296-LM74501QDDFRQ1TR-ND,296-LM74501QDDFRQ1CT-ND,296-LM74501QDDFRQ1DKR-ND LM74501QDDFRQ1
296-BQ7720705DSSRTR-ND,296-BQ7720705DSSRCT-ND,296-BQ7720705DSSRDKR-ND BQ7720705DSSR
296-BQ77307RGRRTR-ND,296-BQ77307RGRRCT-ND,296-BQ77307RGRRDKR-ND BQ77307RGRR
296-BQ76905RGRRTR-ND,296-BQ76905RGRRCT-ND,296-BQ76905RGRRDKR-ND BQ76905RGRR
18-LS0502SCD33STR-ND,18-LS0502SCD33SCT-ND,18-LS0502SCD33SDKR-ND LS0502SCD33S
296-BQ76907RGRRTR-ND,296-BQ76907RGRRCT-ND,296-BQ76907RGRRDKR-ND BQ76907RGRR
296-37460-2-ND,296-37460-1-ND,296-37460-6-ND BQ27621YZFR-G1A
2508-MC3651DF1AAMTR-ND,2508-MC3651DF1AAMCT-ND,2508-MC3651DF1AAMDKR-ND MC3651DF1AAM
296-29341-2-ND,296-29341-1-ND,296-29341-6-ND BQ76925PWR
296-BQ27Z746YAHRTR-ND,296-BQ27Z746YAHRCT-ND,296-BQ27Z746YAHRDKR-ND BQ27Z746YAHR
1662-S-82D1AAD-A8T2U7TR-ND,1662-S-82D1AAD-A8T2U7CT-ND,1662-S-82D1AAD-A8T2U7DKR-ND S-82D1AAD-A8T2U7
296-38880-2-ND,296-38880-1-ND,296-38880-6-ND BQ27421YZFR-G1A
497-L9961TR-ND,497-L9961TRCT-ND,497-L9961TRDKR-ND L9961TR
1662-S-8254AAVFT-TB-UTR-ND,1662-S-8254AAVFT-TB-UCT-ND,1662-S-8254AAVFT-TB-UDKR-ND S-8254AAVFT-TB-U
296-39942-2-ND,296-39942-1-ND,296-39942-6-ND BQ27441DRZR-G1B
1662-S-82A2BAA-I8T1U7TR-ND,1662-S-82A2BAA-I8T1U7CT-ND,1662-S-82A2BAA-I8T1U7DKR-ND S-82A2BAA-I8T1U7
175-MAX14680EWC+TTR-ND,175-MAX14680EWC+TCT-ND,MAX14680EWC+TCT-ND,175-MAX14680EWC+TDKR-ND MAX14680EWC+T
296-48498-2-ND,296-48498-1-ND,296-48498-6-ND BQ4050RSMR
296-BQ7721611PWRTR-ND,296-BQ7721611PWRCT-ND,296-BQ7721611PWRDKR-ND BQ7721611PWR
296-BQ7721607PWRTR-ND,296-BQ7721607PWRCT-ND,296-BQ7721607PWRDKR-ND BQ7721607PWR
175-MAX17260BEWL+TTR-ND,175-MAX17260BEWL+TCT-ND,175-MAX17260BEWL+TDKR-ND MAX17260BEWL+T
296-43316-5-ND BQ76200PW
296-39960-2-ND,296-39960-1-ND,296-39960-6-ND BQ7692006PWR
296-46504-5-ND BQ7692003PW
296-39958-2-ND,296-39958-1-ND,296-39958-6-ND BQ7692000PWR
497-15078-2-ND,497-15078-1-ND,497-15078-6-ND STC3115IQT
MAX6776XKC+TR-ND,MAX6776XKC+CT-ND,MAX6776XKC+DKR-ND MAX6776XKC+T
505-MAX17303G±ND MAX17303G+
296-47649-2-ND,296-47649-1-ND,296-47649-6-ND BQ25703ARSNR
296-50953-2-ND,296-50953-1-ND,296-50953-6-ND BQ25713RSNR
296-45022-5-ND BQ35100PW
296-BQ28Z610DRZR-R1TR-ND,296-BQ28Z610DRZR-R1CT-ND,296-BQ28Z610DRZR-R1DKR-ND BQ28Z610DRZR-R1
MAX17201G+00E-ND MAX17201G+00E
LTC1998CS6#TRMPBFTR-ND,LTC1998CS6#TRMPBFCT-ND,LTC1998CS6#TRMPBFDKR-ND LTC1998CS6#TRMPBF
296-39961-2-ND,296-39961-1-ND,296-39961-6-ND BQ7693003DBTR
MAX6777XK+TR-ND,MAX6777XK+CT-ND,MAX6777XK+DKR-ND MAX6777XK+T
296-BQ7694202PFBRTR-ND,296-BQ7694202PFBRCT-ND,296-BQ7694202PFBRDKR-ND BQ7694202PFBR
296-BQ76942PFBRTR-ND,296-BQ76942PFBRCT-ND,296-BQ76942PFBRDKR-ND BQ76942PFBR
296-53517-2-ND,296-53517-1-ND,296-53517-6-ND BQ25887RGER
296-43369-2-ND,296-43369-1-ND,296-43369-6-ND BQ28Z610DRZR
296-50240-2-ND,296-50240-1-ND,296-50240-6-ND BQ25713BRSNT
296-27731-2-ND,296-27731-1-ND,296-27731-6-ND BQ76PL102RGTR
296-46956-2-ND,296-46956-1-ND,296-46956-6-ND BQ25703ARSNT
296-30535-2-ND,296-30535-1-ND,296-30535-6-ND,2156-BQ34Z100PWR-ND BQ34Z100PWR
296-45128-5-ND BQ34110PW
296-39462-2-ND,296-39462-1-ND,296-39462-6-ND TPS650250RHBR
296-BQ7695204PFBRTR-ND,296-BQ7695204PFBRCT-ND,296-BQ7695204PFBRDKR-ND BQ7695204PFBR
296-BQ7695201PFBRTR-ND,296-BQ7695201PFBRCT-ND,296-BQ7695201PFBRDKR-ND BQ7695201PFBR
505-MAX17320G20±ND MAX17320G20+
175-MAX6433UK+TTR-ND,175-MAX6433UK+TCT-ND,175-MAX6433UK+TDKR-ND MAX6433UK+T
296-BQ41Z50RSNRTR-ND,296-BQ41Z50RSNRCT-ND,296-BQ41Z50RSNRDKR-ND BQ41Z50RSNR
LTC4067EDE#PBF-ND LTC4067EDE#PBF
448-TLE9015DQUXUMA1TR-ND,448-TLE9015DQUXUMA1CT-ND,448-TLE9015DQUXUMA1DKR-ND TLE9015DQUXUMA1
296-BQ78350DBT-R1A-ND BQ78350DBT-R1A
505-MAX17320G22±ND MAX17320G22+
296-BQ7697204PFBRTR-ND,296-BQ7697204PFBRCT-ND,296-BQ7697204PFBRDKR-ND BQ7697204PFBR
296-BQ7697202PFBRTR-ND,296-BQ7697202PFBRCT-ND,296-BQ7697202PFBRDKR-ND BQ7697202PFBR
175-MAX17301X+TTR-ND,175-MAX17301X+TCT-ND,175-MAX17301X+TDKR-ND MAX17301X+T
296-BQ7694000DBTR-ND,296-BQ7694000DBTRCT-ND,296-BQ7694000DBTRDKR-ND BQ7694000DBTR
296-47745-2-ND,296-47745-1-ND,296-47745-6-ND BQ7694003DBTR
296-24038-2-ND,296-24038-1-ND,296-24038-6-ND TPS650250RHBT
296-50239-2-ND,296-50239-1-ND,296-50239-6-ND BQ25710RSNT
296-25926-2-ND,296-25926-1-ND,296-25926-6-ND BQ29312APWR
296-37788-5-ND BQ7694002DBT
DS2745U±ND DS2745U+
505-ADP5360ACBZ-1-R7TR-ND,505-ADP5360ACBZ-1-R7CT-ND,505-ADP5360ACBZ-1-R7DKR-ND ADP5360ACBZ-1-R7
505-LTC4162EUFD-SAD#PBF-ND LTC4162EUFD-SAD#PBF
DS2756E±ND DS2756E+
296-23520-2-ND,296-23520-1-ND,296-23520-6-ND BQ77PL900DLR
505-LTC4162IUFD-SADM#PBF-ND LTC4162IUFD-SADM#PBF
LTC2943CDD#TRPBFTR-ND,LTC2943CDD#TRPBFCT-ND,LTC2943CDD#TRPBFDKR-ND LTC2943CDD#TRPBF
296-27037-2-ND,296-27037-1-ND,296-27037-6-ND,2156-TPS65021RHAR-ND TPS65021RHAR
505-LTC4162EUFD-FAD#PBF-ND LTC4162EUFD-FAD#PBF
505-LTC4162EUFD-LADM#PBF-ND LTC4162EUFD-LADM#PBF
505-LTC4162EUFD-SADM#PBF-ND LTC4162EUFD-SADM#PBF
505-LT8584EFE#PBF-ND LT8584EFE#PBF
505-MAX17841BGUE/V±ND MAX17841BGUE/V+
568-MC33665ATS4AE-ND MC33665ATS4AE
DS2781E+TR-ND,DS2781E+CT-ND,DS2781E+DKR-ND DS2781E+T&R
505-LTC4040EUFD#PBF-ND LTC4040EUFD#PBF
DS2764AE±ND DS2764AE+
568-MC33772CTA1AE-ND MC33772CTA1AE
505-LTC4090EDJC#TRPBFTR-ND,505-LTC4090EDJC#TRPBFCT-ND,505-LTC4090EDJC#TRPBFDKR-ND LTC4090EDJC#TRPBF
568-MC33772CTP1AE-ND MC33772CTP1AE
DS2781E±ND DS2781E+
505-ADP5350ACBZ-1-R7TR-ND,505-ADP5350ACBZ-1-R7CT-ND,505-ADP5350ACBZ-1-R7DKR-ND ADP5350ACBZ-1-R7
505-LTC2944IDD#3ZZPBFTR-ND,505-LTC2944IDD#3ZZPBFCT-ND,505-LTC2944IDD#3ZZPBFDKR-ND LTC2944IDD#3ZZPBF
MAX20303BEWN+TTR-ND,MAX20303BEWN+TCT-ND,MAX20303BEWN+TDKR-ND MAX20303BEWN+T
568-MC33771CTP1AE-ND MC33771CTP1AE
BD14000EFV-CE2TR-ND,BD14000EFV-CE2CT-ND,BD14000EFV-CE2DKR-ND BD14000EFV-CE2
296-25918-2-ND,296-25918-1-ND,296-25918-6-ND BQ2060A-E619DBQR
MAX14921ECS±ND MAX14921ECS+
505-LTC3300ILXE-1#PBF-ND LTC3300ILXE-1#PBF
296-BQ79612PAPRQ1TR-ND,296-BQ79612PAPRQ1CT-ND,296-BQ79612PAPRQ1DKR-ND BQ79612PAPRQ1
20-ISL94216IRZ-ND ISL94216IRZ
505-LTC6810HG-1#3ZZTRPBFTR-ND,505-LTC6810HG-1#3ZZTRPBFCT-ND,505-LTC6810HG-1#3ZZTRPBFDKR-ND LTC6810HG-1#3ZZTRPBF
MAX17843ACB/V±ND MAX17843ACB/V+
296-BQ79758QPAPRQ1TR-ND,296-BQ79758QPAPRQ1CT-ND,296-BQ79758QPAPRQ1DKR-ND BQ79758QPAPRQ1
505-LTC6811HG-2#PBF-ND LTC6811HG-2#PBF
296-BQ79652PAPRQ1TR-ND,296-BQ79652PAPRQ1CT-ND,296-BQ79652PAPRQ1DKR-ND BQ79652PAPRQ1
296-BQ75614PAPRQ1TR-ND,296-BQ75614PAPRQ1CT-ND,296-BQ75614PAPRQ1DKR-ND BQ75614PAPRQ1
505-LTC6811HG-1#3ZZPBF-ND LTC6811HG-1#3ZZPBF
LTC6803IG-3#TRPBFTR-ND,LTC6803IG-3#TRPBFCT-ND,LTC6803IG-3#TRPBFDKR-ND LTC6803IG-3#TRPBF
505-LTC6803IG-3#PBF-ND LTC6803IG-3#PBF
LTC6802IG-1#PBF-ND LTC6802IG-1#PBF
505-LTC6803HG-3#PBF-ND LTC6803HG-3#PBF
505-LTC6804IG-1#PBF-ND LTC6804IG-1#PBF
LTC6804HG-1#TRPBFTR-ND,LTC6804HG-1#TRPBFCT-ND,LTC6804HG-1#TRPBFDKR-ND LTC6804HG-1#TRPBF
505-LTC6806HLW#3ZZPBF-ND LTC6806HLW#3ZZPBF
BD71L4LG-1GTRTR-ND,BD71L4LG-1GTRCT-ND,BD71L4LG-1GTRDKR-ND BD71L4LG-1GTR
296-39946-2-ND,296-39946-1-ND,296-39946-6-ND,2156-BQ29705DSER-ND BQ29705DSER
296-50976-2-ND,296-50976-1-ND,296-50976-6-ND,2156-BQ29704DSER-ND BQ29704DSER
296-50979-2-ND,296-50979-1-ND,296-50979-6-ND BQ29723DSER
296-44717-2-ND,296-44717-1-ND,296-44717-6-ND BQ29703DSER
296-36524-2-ND,296-36524-1-ND,296-36524-6-ND,2156-BQ294602DRVR-ND BQ294602DRVR
296-BQ298215RUGRTR-ND,296-BQ298215RUGRCT-ND,296-BQ298215RUGRDKR-ND BQ298215RUGR
296-34984-2-ND,296-34984-1-ND,296-34984-6-ND BQ294700DSGR
296-BQ294705DSGRTR-ND,296-BQ294705DSGRCT-ND,296-BQ294705DSGRDKR-ND BQ294705DSGR
296-BQ298216RUGRTR-ND,296-BQ298216RUGRCT-ND,296-BQ298216RUGRDKR-ND BQ298216RUGR
296-BQ298018RUGRTR-ND,296-BQ298018RUGRCT-ND,296-BQ298018RUGRDKR-ND BQ298018RUGR
296-BQ298010RUGRTR-ND,296-BQ298010RUGRCT-ND,296-BQ298010RUGRDKR-ND BQ298010RUGR
296-49563-2-ND,296-49563-1-ND,296-49563-6-ND BQ296103DSGR
296-34986-2-ND,296-34986-1-ND,296-34986-6-ND,2156-BQ294702DSGR-ND BQ294702DSGR
2508-MM3513C01NRHTR-ND,2508-MM3513C01NRHCT-ND,2508-MM3513C01NRHDKR-ND MM3513C01NRH
296-45454-2-ND,296-45454-1-ND,296-45454-6-ND,2156-BQ294711DSGR-ND BQ294711DSGR
296-34988-2-ND,296-34988-1-ND,296-34988-6-ND BQ294704DSGR
1662-S-8240ABF-I6T1UTR-ND,1662-S-8240ABF-I6T1UCT-ND,1662-S-8240ABF-I6T1UDKR-ND S-8240ABF-I6T1U
1662-S-8240ACW-I6T1UTR-ND,1662-S-8240ACW-I6T1UCT-ND,1662-S-8240ACW-I6T1UDKR-ND S-8240ACW-I6T1U
1662-S-8240ACS-M6T1UTR-ND,1662-S-8240ACS-M6T1UCT-ND,1662-S-8240ACS-M6T1UDKR-ND S-8240ACS-M6T1U
296-BQ24381DSGRTR-ND,296-BQ24381DSGRCT-ND,296-BQ24381DSGRDKR-ND BQ24381DSGR
296-BQ24314DSGRTR-ND,296-BQ24314DSGRCT-ND,296-BQ24314DSGRDKR-ND BQ24314DSGR
296-BQ24312DSGRTR-ND,296-BQ24312DSGRCT-ND,296-BQ24312DSGRDKR-ND BQ24312DSGR
296-46412-2-ND,296-46412-1-ND,296-46412-6-ND BQ24313DSGR
1662-S-8211CAA-I6T1UTR-ND,1662-S-8211CAA-I6T1UCT-ND,1662-S-8211CAA-I6T1UDKR-ND S-8211CAA-I6T1U
296-48492-2-ND,296-48492-1-ND,296-48492-6-ND,2156-BQ24308DSGR-296-ND BQ24308DSGR
4823-NPM1100-QDAB-RTR-ND,4823-NPM1100-QDAB-RCT-ND,4823-NPM1100-QDAB-RDKR-ND NPM1100-QDAB-R
4823-NPM1100-CAAB-R7TR-ND,4823-NPM1100-CAAB-R7CT-ND,4823-NPM1100-CAAB-R7DKR-ND NPM1100-CAAB-R7
4823-NPM1100-QDAB-R7TR-ND,4823-NPM1100-QDAB-R7CT-ND,4823-NPM1100-QDAB-R7DKR-ND NPM1100-QDAB-R7
296-44132-2-ND,296-44132-1-ND,296-44132-6-ND BQ29732DSET
296-BQ29701DSETTR-ND,296-BQ29701DSETCT-ND,296-BQ29701DSETDKR-ND BQ29701DSET
296-46885-2-ND,296-46885-1-ND,296-46885-6-ND BQ29702DSET
296-44130-2-ND,296-44130-1-ND,296-44130-6-ND BQ29723DSET
296-BQ24316DSJTTR-ND,296-BQ24316DSJTCT-ND,296-BQ24316DSJTDKR-ND,2156-BQ24316DSJT-ND BQ24316DSJT
296-23933-2-ND,296-23933-1-ND,296-23933-6-ND BQ24313DSGT
296-49154-2-ND,296-49154-1-ND,296-49154-6-ND BQ29209DRBT
296-BQ294702DSGTTR-ND,296-BQ294702DSGTCT-ND,296-BQ294702DSGTDKR-ND,2156-BQ294702DSGT-ND BQ294702DSGT
296-45462-2-ND,296-45462-1-ND,296-45462-6-ND,2156-BQ294711DSGT-ND BQ294711DSGT
296-BQ294708DSGTTR-ND,296-BQ294708DSGTCT-ND,296-BQ294708DSGTDKR-ND,2156-BQ294708DSGT-ND BQ294708DSGT
296-BQ294512DRVTTR-ND,296-BQ294512DRVTCT-ND,296-BQ294512DRVTDKR-ND,2156-BQ294512DRVT-ND BQ294512DRVT
296-42150-2-ND,296-42150-1-ND,296-42150-6-ND,2156-BQ296103DSGT-ND BQ296103DSGT
296-BQ296111DSGTTR-ND,296-BQ296111DSGTCT-ND,296-BQ296111DSGTDKR-ND,2156-BQ296111DSGT-ND BQ296111DSGT
296-BQ296100DSGTTR-ND,296-BQ296100DSGTCT-ND,296-BQ296100DSGTDKR-ND,2156-BQ296100DSGT-ND BQ296100DSGT
296-BQ298012RUGTTR-ND,296-BQ298012RUGTCT-ND,296-BQ298012RUGTDKR-ND BQ298012RUGT
296-BQ298006RUGTTR-ND,296-BQ298006RUGTCT-ND,296-BQ298006RUGTDKR-ND BQ298006RUGT
296-47578-2-ND,296-47578-1-ND,296-47578-6-ND BQ298000RUGT
296-BQ298015RUGTTR-ND,296-BQ298015RUGTCT-ND,296-BQ298015RUGTDKR-ND BQ298015RUGT
296-34929-2-ND,296-34929-1-ND,296-34929-6-ND BQ24314CDSGT
1662-S-8229AAA-M6T1UTR-ND,1662-S-8229AAA-M6T1UCT-ND,1662-S-8229AAA-M6T1UDKR-ND S-8229AAA-M6T1U
296-39967-2-ND,296-39967-1-ND,296-39967-6-ND BQ771800DPJR
296-BQ771824DPJRTR-ND,296-BQ771824DPJRCT-ND,296-BQ771824DPJRDKR-ND BQ771824DPJR
2508-MM3513H01NRHTR-ND,2508-MM3513H01NRHCT-ND,2508-MM3513H01NRHDKR-ND MM3513H01NRH
1662-S-82A1ACH-I6T1UTR-ND,1662-S-82A1ACH-I6T1UCT-ND,1662-S-82A1ACH-I6T1UDKR-ND S-82A1ACH-I6T1U
296-BQ771807DPJTTR-ND,296-BQ771807DPJTCT-ND,296-BQ771807DPJTDKR-ND,2156-BQ771807DPJT-ND BQ771807DPJT
296-BQ771818DPJTTR-ND,296-BQ771818DPJTCT-ND,296-BQ771818DPJTDKR-ND BQ771818DPJT
296-BQ771800DPJTTR-ND,296-BQ771800DPJTCT-ND,296-BQ771800DPJTDKR-ND BQ771800DPJT
296-47253-2-ND,296-47253-1-ND,296-47253-6-ND BQ7790500PWR
296-BQ7790521PWRTR-ND,296-BQ7790521PWRCT-ND,296-BQ7790521PWRDKR-ND BQ7790521PWR
296-BQ7790522PWRTR-ND,296-BQ7790522PWRCT-ND,296-BQ7790522PWRDKR-ND BQ7790522PWR
296-BQ771600DPJTTR-ND,296-BQ771600DPJTCT-ND,296-BQ771600DPJTDKR-ND BQ771600DPJT
296-BQ7791513PWRTR-ND,296-BQ7791513PWRCT-ND,296-BQ7791513PWRDKR-ND BQ7791513PWR
2508-MM3220H15NRHTR-ND,2508-MM3220H15NRHCT-ND,2508-MM3220H15NRHDKR-ND MM3220H15NRH
1662-S-82N1BAA-I6T1U7TR-ND,1662-S-82N1BAA-I6T1U7CT-ND,1662-S-82N1BAA-I6T1U7DKR-ND S-82N1BAA-I6T1U7
296-47448-ND BQ7790512PW
1662-S-8252AAY-M6T1UTR-ND,1662-S-8252AAY-M6T1UCT-ND,1662-S-8252AAY-M6T1UDKR-ND S-8252AAY-M6T1U
1662-S-8252ABE-M6T1UTR-ND,1662-S-8252ABE-M6T1UCT-ND,1662-S-8252ABE-M6T1UDKR-ND S-8252ABE-M6T1U
1662-S-8252ABD-M6T1UTR-ND,1662-S-8252ABD-M6T1UCT-ND,1662-S-8252ABD-M6T1UDKR-ND S-8252ABD-M6T1U
296-BQ7791506PWRTR-ND,296-BQ7791506PWRCT-ND,296-BQ7791506PWRDKR-ND BQ7791506PWR
296-BQ7791502PWRTR-ND,296-BQ7791502PWRCT-ND,296-BQ7791502PWRDKR-ND BQ7791502PWR
296-BQ7720700DSSRTR-ND,296-BQ7720700DSSRCT-ND,296-BQ7720700DSSRDKR-ND BQ7720700DSSR
296-BQ7720702DSSRTR-ND,296-BQ7720702DSSRCT-ND,296-BQ7720702DSSRDKR-ND BQ7720702DSSR
296-42132-2-ND,296-42132-1-ND,296-42132-6-ND BQ27546YZFT-G1
1662-S-8264AAA-I8T1UTR-ND,1662-S-8264AAA-I8T1UCT-ND,1662-S-8264AAA-I8T1UDKR-ND S-8264AAA-I8T1U
296-50289-2-ND,296-50289-1-ND,296-50289-6-ND BQ7791500PWT
296-BQ7791501PWTTR-ND,296-BQ7791501PWTCT-ND,296-BQ7791501PWTDKR-ND BQ7791501PWT
296-36570-2-ND,296-36570-1-ND,296-36570-6-ND BQ76925RGER
1662-S-82B2AAA-I8T1U7TR-ND,1662-S-82B2AAA-I8T1U7CT-ND,1662-S-82B2AAA-I8T1U7DKR-ND S-82B2AAA-I8T1U7
296-49560-2-ND,296-49560-1-ND,296-49560-6-ND BQ27220YZFT
296-39937-2-ND,296-39937-1-ND,296-39937-6-ND BQ27421YZFR-G1B
296-37471-2-ND,296-37471-1-ND,296-37471-6-ND BQ27621YZFT-G1A
296-50959-2-ND,296-50959-1-ND,296-50959-6-ND BQ27Z561YPHR
1662-S-8254AAMFT-TB-UTR-ND,1662-S-8254AAMFT-TB-UCT-ND,1662-S-8254AAMFT-TB-UDKR-ND S-8254AAMFT-TB-U
296-29506-5-ND BQ76925PW
1662-S-82A2AAA-A8T2U7TR-ND,1662-S-82A2AAA-A8T2U7CT-ND,1662-S-82A2AAA-A8T2U7DKR-ND S-82A2AAA-A8T2U7
175-MAX14634EWC+TTR-ND,175-MAX14634EWC+TCT-ND,175-MAX14634EWC+TDKR-ND MAX14634EWC+T
296-36221-2-ND,296-36221-1-ND,296-36221-6-ND BQ27421YZFT-G1B
296-BQ34210IPWRQ1TR-ND,296-BQ34210IPWRQ1CT-ND,296-BQ34210IPWRQ1DKR-ND BQ34210IPWRQ1
296-37272-2-ND,296-37272-1-ND,296-37272-6-ND BQ27441DRZT-G1B
MAX16915AUB±ND MAX16915AUB+
MAX16914AUB±ND MAX16914AUB+
296-37912-2-ND,296-37912-1-ND,296-37912-6-ND BQ27742YZFR-G1
296-46290-2-ND,296-46290-1-ND,296-46290-6-ND BQ27531YZFR-G1
296-37269-2-ND,296-37269-1-ND,296-37269-6-ND,2156-BQ27411DRZT-G1A-ND BQ27411DRZT-G1A
1662-S-8265CAA-K8T2U7TR-ND,1662-S-8265CAA-K8T2U7CT-ND,1662-S-8265CAA-K8T2U7DKR-ND S-8265CAA-K8T2U7
296-37742-2-ND,296-37742-1-ND,296-37742-6-ND BQ27742YZFT-G1
296-38609-2-ND,296-38609-1-ND,296-38609-6-ND BQ27532YZFT-G1
MAX6775XKB+TTR-ND,MAX6775XKB+TCT-ND,MAX6775XKB+TDKR-ND MAX6775XKB+T
296-44125-2-ND,296-44125-1-ND,296-44125-6-ND,2156-BQ27320YZFT-ND BQ27320YZFT
175-MAX17261MEWL+TTR-ND,175-MAX17261MEWL+TCT-ND,175-MAX17261MEWL+TDKR-ND MAX17261MEWL+T
296-38886-5-ND BQ7692006PW
296-50952-2-ND,296-50952-1-ND,296-50952-6-ND BQ25713BRSNR
296-BQ78Z100DRZRTR-ND,296-BQ78Z100DRZRCT-ND,296-BQ78Z100DRZRDKR-ND BQ78Z100DRZR
296-48109-2-ND,296-48109-1-ND,296-48109-6-ND BQ25700ARSNR
MAX17215G+00E-ND MAX17215G+00E
296-BQ24770RUYRTR-ND,296-BQ24770RUYRCT-ND,296-BQ24770RUYRDKR-ND BQ24770RUYR
175-MAX17320X20+TTR-ND,175-MAX17320X20+TCT-ND,175-MAX17320X20+TDKR-ND MAX17320X20+T
MAX6775XKC+TTR-ND,MAX6775XKC+TCT-ND,MAX6775XKC+TDKR-ND MAX6775XKC+T
175-MAX6775XKA+TTR-ND,175-MAX6775XKA+TCT-ND,175-MAX6775XKA+TDKR-ND MAX6775XKA+T
296-BQ7694203PFBRTR-ND,296-BQ7694203PFBRCT-ND,296-BQ7694203PFBRDKR-ND BQ7694203PFBR
296-BQ7694204PFBRTR-ND,296-BQ7694204PFBRCT-ND,296-BQ7694204PFBRDKR-ND BQ7694204PFBR
296-25733-2-ND,296-25733-1-ND,296-25733-6-ND,2156-TPS65023QRHARQ1-ND TPS65023QRHARQ1
296-25412-2-ND,296-25412-1-ND,296-25412-6-ND TPS65023QRSBRQ1
296-39962-2-ND,296-39962-1-ND,296-39962-6-ND BQ7693006DBTR
296-21318-2-ND,296-21318-1-ND,296-21318-6-ND TPS65023RSBT
296-37690-2-ND,296-37690-1-ND,296-37690-6-ND BQ27425YZFT-G2A
296-BQ7695203PFBRTR-ND,296-BQ7695203PFBRCT-ND,296-BQ7695203PFBRDKR-ND BQ7695203PFBR
DS2786BG±ND DS2786BG+
505-MAX17320G10±ND MAX17320G10+
296-BQ769142PFBRTR-ND,296-BQ769142PFBRCT-ND,296-BQ769142PFBRDKR-ND BQ769142PFBR
DS2746G±ND DS2746G+
296-37789-5-ND BQ7694003DBT
296-37786-5-ND BQ7694000DBT
MAX14653EWC+TTR-ND,MAX14653EWC+TCT-ND,MAX14653EWC+TDKR-ND MAX14653EWC+T
296-43394-2-ND,296-43394-1-ND,296-43394-6-ND BQ28Z610DRZT
296-27696-2-ND,296-27696-1-ND,296-27696-6-ND TPS65023BRSBT
505-MAX17320G12±ND MAX17320G12+
296-39722-5-ND BQ7693000DBT
296-43250-5-ND BQ7693002DBT
296-47693-ND BQ7693003DBT
MAX17205G±ND MAX17205G+
296-46955-2-ND,296-46955-1-ND,296-46955-6-ND BQ25700ARSNT
296-49339-2-ND,296-49339-1-ND,296-49339-6-ND TPS650243RHBR
296-44149-2-ND,296-44149-1-ND,296-44149-6-ND BQ4050RSMT
DS2786G±ND DS2786G+
2156-BQ34Z100PW-ND,296-30497-5-ND BQ34Z100PW
296-35695-2-ND,296-35695-1-ND,296-35695-6-ND,2156-BQ34Z110PWR-ND BQ34Z110PWR
20-RAA4892062GNP#AA5-ND RAA4892062GNP#AA5
296-38365-2-ND,296-38365-1-ND,296-38365-6-ND BQ40Z50RSMT
LTC4099EUDC#PBF-ND LTC4099EUDC#PBF
296-25928-5-ND BQ77PL900DL
LTC4066EUF-1#PBF-ND LTC4066EUF-1#PBF
LTC4066EUF#PBF-ND LTC4066EUF#PBF
505-LTC4162EUFD-L42#PBF-ND LTC4162EUFD-L42#PBF
505-LTC4162EUFD-L42M#PBF-ND LTC4162EUFD-L42M#PBF
505-LTC4162EUFD-L41#PBF-ND LTC4162EUFD-L41#PBF
LTC4162EUFD-L41M#PBF-ND LTC4162EUFD-L41M#PBF
LTC4098EUDC#PBF-ND LTC4098EUDC#PBF
296-41213-2-ND,296-41213-1-ND,296-41213-6-ND BQ76PL536APAPR
LTC4098EUDC-3.6#PBF-ND LTC4098EUDC-3.6#PBF
296-28422-2-ND,296-28422-1-ND,296-28422-6-ND BQ33100PWR
LTC4162IUFD-FADM#PBF-ND LTC4162IUFD-FADM#PBF
505-LTC4162IUFD-SAD#PBF-ND LTC4162IUFD-SAD#PBF
LTC4162IUFD-SSTM#PBF-ND LTC4162IUFD-SSTM#PBF
DS2781G±ND DS2781G+
505-LTC2944CDD#TRPBFTR-ND,505-LTC2944CDD#TRPBFCT-ND,505-LTC2944CDD#TRPBFDKR-ND LTC2944CDD#TRPBF
505-LTC2944CDD#PBF-ND LTC2944CDD#PBF
LTC4160EUDC#PBF-ND LTC4160EUDC#PBF
ISL94212INZ-ND ISL94212INZ
DS2438AZ±ND DS2438AZ+
296-18582-2-ND,296-18582-1-ND,296-18582-6-ND,2156-TPS65020RHAT-ND TPS65020RHAT
DS2764BE±ND DS2764BE+
DS2778G±ND DS2778G+
505-LT8584HFE#PBF-ND LT8584HFE#PBF
296-28926-2-ND,296-28926-1-ND,296-28926-6-ND BQ76PL536APAPT
LT1579CS8-3.3#PBF-ND LT1579CS8-3.3#PBF
505-LTC4040IUFD#PBF-ND LTC4040IUFD#PBF
568-MC33772CTP2AE-ND MC33772CTP2AE
DS2780E±ND DS2780E+
DS2776G±ND DS2776G+
DS2762AE±ND DS2762AE+
DS2762BE±ND DS2762BE+
2156-BQ2019PW-ND,296-9348-5-ND BQ2019PW
MAX14920ECB±ND MAX14920ECB+
161-LTC3300ILXE-2#WPBF-ND LTC3300ILXE-2#WPBF
505-LTC6810IG-1#3ZZTRPBFTR-ND,505-LTC6810IG-1#3ZZTRPBFCT-ND,505-LTC6810IG-1#3ZZTRPBFDKR-ND LTC6810IG-1#3ZZTRPBF
505-MAX17823BGCB/V±ND MAX17823BGCB/V+
296-BQ79614PAPRQ1TR-ND,296-BQ79614PAPRQ1CT-ND,296-BQ79614PAPRQ1DKR-ND BQ79614PAPRQ1
505-LTC6811IG-1#PBF-ND LTC6811IG-1#PBF
505-LTC3300HLXE-1#PBF-ND LTC3300HLXE-1#PBF
LTC3305EFE#PBF-ND LTC3305EFE#PBF
296-18388-5-ND BQ2060A-E619DBQ
175-MAX14921ECS+TTR-ND,175-MAX14921ECS+TCT-ND,175-MAX14921ECS+TDKR-ND MAX14921ECS+T
LTC4110EUHF#PBF-ND LTC4110EUHF#PBF
505-ADBMS1818ASWZ-RLTR-ND,505-ADBMS1818ASWZ-RLCT-ND,505-ADBMS1818ASWZ-RLDKR-ND ADBMS1818ASWZ-RL
505-ADBMS1818ASWAZ-RLTR-ND,505-ADBMS1818ASWAZ-RLCT-ND,505-ADBMS1818ASWAZ-RLDKR-ND ADBMS1818ASWAZ-RL
296-2221-5-ND BQ2018SN-E1
161-LTC6811IG-1#TRPBFTR-ND,161-LTC6811IG-1#TRPBFCT-ND,161-LTC6811IG-1#TRPBFDKR-ND LTC6811IG-1#TRPBF
505-LTC6811IG-2#PBF-ND LTC6811IG-2#PBF
LTC1479CG#PBF-ND LTC1479CG#PBF
LTC6803IG-4#PBF-ND LTC6803IG-4#PBF
505-LTC6801HG#PBF-ND LTC6801HG#PBF
505-LTC6803HG-3#3ZZPBF-ND LTC6803HG-3#3ZZPBF
296-28016-2-ND,296-28016-1-ND,296-28016-6-ND BQ78PL116RGZT
LTC6801HG#TRPBFTR-ND,LTC6801HG#TRPBFCT-ND,LTC6801HG#TRPBFDKR-ND LTC6801HG#TRPBF
LTC6801HG#3ZZPBF-ND LTC6801HG#3ZZPBF
LTC6802IG-2#PBF-ND LTC6802IG-2#PBF
505-ADBT1001BSWZ-ND ADBT1001BSWZ
505-LTC2949HLXE#3ZZTRPBFTR-ND,505-LTC2949HLXE#3ZZTRPBFCT-ND,505-LTC2949HLXE#3ZZTRPBFDKR-ND LTC2949HLXE#3ZZTRPBF
296-BQ771803DPJTTR-ND,296-BQ771803DPJTCT-ND,296-BQ771803DPJTDKR-ND BQ771803DPJT
296-BQ296221DSGRTR-ND,296-BQ296221DSGRCT-ND,296-BQ296221DSGRDKR-ND BQ296221DSGR
296-50977-2-ND,296-50977-1-ND,296-50977-6-ND,2156-BQ29716DSER-ND BQ29716DSER
296-49564-2-ND,296-49564-1-ND,296-49564-6-ND BQ29718DSER
296-50978-2-ND,296-50978-1-ND,296-50978-6-ND BQ29717DSER
296-50980-2-ND,296-50980-1-ND,296-50980-6-ND BQ29729DSER
296-BQ294582DRVRTR-ND,296-BQ294582DRVRCT-ND,296-BQ294582DRVRDKR-ND,2156-BQ294582DRVR-ND BQ294582DRVR
296-BQ294532DRVRTR-ND,296-BQ294532DRVRCT-ND,296-BQ294532DRVRDKR-ND BQ294532DRVR
296-50961-2-ND,296-50961-1-ND,296-50961-6-ND,2156-BQ294624DRVR-ND BQ294624DRVR
296-BQ294682DRVRTR-ND,296-BQ294682DRVRCT-ND,296-BQ294682DRVRDKR-ND,2156-BQ294682DRVR-ND BQ294682DRVR
296-BQ294604DRVRTR-ND,296-BQ294604DRVRCT-ND,296-BQ294604DRVRDKR-ND BQ294604DRVR
296-BQ298019RUGRTR-ND,296-BQ298019RUGRCT-ND,296-BQ298019RUGRDKR-ND BQ298019RUGR
296-BQ294522DRVRTR-ND,296-BQ294522DRVRCT-ND,296-BQ294522DRVRDKR-ND BQ294522DRVR
296-BQ296115DSGRTR-ND,296-BQ296115DSGRCT-ND,296-BQ296115DSGRDKR-ND BQ296115DSGR
296-34987-2-ND,296-34987-1-ND,296-34987-6-ND,2156-BQ294703DSGR-ND BQ294703DSGR
296-BQ294534DRVRTR-ND,296-BQ294534DRVRCT-ND,296-BQ294534DRVRDKR-ND BQ294534DRVR
1662-S-8240AED-I6T1UTR-ND,1662-S-8240AED-I6T1UCT-ND,1662-S-8240AED-I6T1UDKR-ND S-8240AED-I6T1U
1662-S-8240ACF-I6T1UTR-ND,1662-S-8240ACF-I6T1UCT-ND,1662-S-8240ACF-I6T1UDKR-ND S-8240ACF-I6T1U
1662-S-8240ADW-I6T1UTR-ND,1662-S-8240ADW-I6T1UCT-ND,1662-S-8240ADW-I6T1UDKR-ND S-8240ADW-I6T1U
1662-S-8240ABJ-I6T1UTR-ND,1662-S-8240ABJ-I6T1UCT-ND,1662-S-8240ABJ-I6T1UDKR-ND S-8240ABJ-I6T1U
1662-S-8240ADC-I6T1UTR-ND,1662-S-8240ADC-I6T1UCT-ND,1662-S-8240ADC-I6T1UDKR-ND S-8240ADC-I6T1U
1662-S-8240ADJ-I6T1UTR-ND,1662-S-8240ADJ-I6T1UCT-ND,1662-S-8240ADJ-I6T1UDKR-ND S-8240ADJ-I6T1U
1662-S-8206AAB-I6T1UTR-ND,1662-S-8206AAB-I6T1UCT-ND,1662-S-8206AAB-I6T1UDKR-ND S-8206AAB-I6T1U
1662-S-8240ACV-I6T1UTR-ND,1662-S-8240ACV-I6T1UCT-ND,1662-S-8240ACV-I6T1UDKR-ND S-8240ACV-I6T1U
296-BQ296233DSGRTR-ND,296-BQ296233DSGRCT-ND,296-BQ296233DSGRDKR-ND BQ296233DSGR
296-23340-2-ND,296-23340-1-ND,296-23340-6-ND BQ24314ADSGR
296-BQ24311DSGRTR-ND,296-BQ24311DSGRCT-ND,296-BQ24311DSGRDKR-ND BQ24311DSGR
296-BQ296234DSGRTR-ND,296-BQ296234DSGRCT-ND,296-BQ296234DSGRDKR-ND BQ296234DSGR
296-BQ296229DSGRTR-ND,296-BQ296229DSGRCT-ND,296-BQ296229DSGRDKR-ND BQ296229DSGR
296-BQ296215DSGRTR-ND,296-BQ296215DSGRCT-ND,296-BQ296215DSGRDKR-ND BQ296215DSGR
296-BQ296230DSGRTR-ND,296-BQ296230DSGRCT-ND,296-BQ296230DSGRDKR-ND BQ296230DSGR
296-45459-2-ND,296-45459-1-ND,296-45459-6-ND BQ296217DSGR
296-BQ296222DSGRTR-ND,296-BQ296222DSGRCT-ND,296-BQ296222DSGRDKR-ND BQ296222DSGR
296-BQ296226DSGRTR-ND,296-BQ296226DSGRCT-ND,296-BQ296226DSGRDKR-ND BQ296226DSGR
1662-S-8239AAH-M6T1UTR-ND,1662-S-8239AAH-M6T1UCT-ND,1662-S-8239AAH-M6T1UDKR-ND S-8239AAH-M6T1U
296-BQ24305DSGRTR-ND,296-BQ24305DSGRCT-ND,296-BQ24305DSGRDKR-ND,2156-BQ24305DSGR-ND BQ24305DSGR
296-BQ24380DSGTTR-ND,296-BQ24380DSGTCT-ND,296-BQ24380DSGTDKR-ND,2156-BQ24380DSGT-ND BQ24380DSGT
296-BQ24382DSGTTR-ND,296-BQ24382DSGTCT-ND,296-BQ24382DSGTDKR-ND,2156-BQ24382DSGT-ND BQ24382DSGT
296-BQ296212DSGTTR-ND,296-BQ296212DSGTCT-ND,296-BQ296212DSGTDKR-ND,2156-BQ296212DSGT-ND BQ296212DSGT
296-45085-2-ND,296-45085-1-ND,296-45085-6-ND,2156-BQ296213DSGT-ND BQ296213DSGT
296-45082-2-ND,296-45082-1-ND,296-45082-6-ND,2156-BQ296202DSGT-ND BQ296202DSGT
296-49557-2-ND,296-49557-1-ND,296-49557-6-ND BQ24314CDSGR
4823-NPM1100-CAAB-RTR-ND,4823-NPM1100-CAAB-RCT-ND,4823-NPM1100-CAAB-RDKR-ND NPM1100-CAAB-R
296-BQ29704DSETTR-ND,296-BQ29704DSETCT-ND,296-BQ29704DSETDKR-ND,2156-BQ29704DSET-ND BQ29704DSET
296-37960-2-ND,296-37960-1-ND,296-37960-6-ND,2156-BQ29703DSET-ND BQ29703DSET
296-44127-2-ND,296-44127-1-ND,296-44127-6-ND,2156-BQ29716DSET-ND BQ29716DSET
296-BQ29717DSETTR-ND,296-BQ29717DSETCT-ND,296-BQ29717DSETDKR-ND,2156-BQ29717DSET-ND BQ29717DSET
296-BQ29733DSETTR-ND,296-BQ29733DSETCT-ND,296-BQ29733DSETDKR-ND BQ29733DSET
296-BQ29705DSETTR-ND,296-BQ29705DSETCT-ND,296-BQ29705DSETDKR-ND,2156-BQ29705DSET-ND BQ29705DSET
296-44131-2-ND,296-44131-1-ND,296-44131-6-ND BQ29729DSET
296-BQ29728DSETTR-ND,296-BQ29728DSETCT-ND,296-BQ29728DSETDKR-ND BQ29728DSET
296-44129-2-ND,296-44129-1-ND,296-44129-6-ND BQ29718DSET
296-BQ29737DSETTR-ND,296-BQ29737DSETCT-ND,296-BQ29737DSETDKR-ND BQ29737DSET
296-BQ29706DSETTR-ND,296-BQ29706DSETCT-ND,296-BQ29706DSETDKR-ND BQ29706DSET
296-BQ24316DSGTTR-ND,296-BQ24316DSGTCT-ND,296-BQ24316DSGTDKR-ND BQ24316DSGT
296-24975-2-ND,296-24975-1-ND,296-24975-6-ND BQ24312DSGT
296-BQ24314DSGTTR-ND,296-BQ24314DSGTCT-ND,296-BQ24314DSGTDKR-ND BQ24314DSGT
296-36565-2-ND,296-36565-1-ND,296-36565-6-ND,2156-BQ294604DRVT-ND BQ294604DRVT
296-46922-2-ND,296-46922-1-ND,296-46922-6-ND,2156-BQ294624DRVT-ND BQ294624DRVT
