I have purchased and item, RKWT 4-633/2M, but I need this cable or something similar but in a thicker gauge.
Hello Tyler, welcome to the TechForum community! The cable assembly that you mentioned has a 22awg cable. The similar cable assemblies that we have are also 22awg. I did not find anything we carry that is made with a larger gauge cable. The datasheet for the RKWT 4-633/2M cable assembly you purchased does list a couple of 18awg options. We should be able to order these for you as a non-catalog order. The order would be subject to the manufacturer’s minimum order quantity and lead time, which we wouldn’t know until we request a quotation from them. I did check on M12 4 position connectors, most of which use cable diameter of 4.00mm-5.1mm which is about the same as 22awg. If you’d like me to request a non-catalog quotation on one of the 18awg cable assemblies in the datasheet, let me know.
