Product information
Does this product come with an XD-OEM controller?
5638-XLA-5-65-1250-ND
Thanks.
From looking at the manufacturer of the model, I believe it does.
Hello Markl and welcome to our community
Thank you for contacting Digikey Technical Support and using our Forum.
The 1250 suffix means the part is closed loop. As per Datasheet closed loop does not come with controller.
Hi Markl,
Looking at this product page from the MFG, it states the following:
Note: The XLA will be available with an integrated closed-loop controller from January 2025.
Since this is a Marketplace supplier the product will be shipped directly from the MFG so based on their site, you should receive a controller.
Hi markl,
The datasheet, dated 04/06/2024 states that the XLA-5-65-1250 does not have an integrated controller and it does not state whether the XD-OEM controller comes with it.
The statement here on their website would seem, at first glance, to indicate that from 2025 and on it will have an integrated controller. However, after further inspection, I believe that this statement means that there is now an option to order one with an integrated controller, but that those parts have a “-INTG” suffix in their respective part numbers, as seen in this document.
From page 1 of the document “XLA-5 integrated controller”:
This then, doesn’t answer the question of whether the XD-OEM controller comes with the XLA-5-65-1250. We will need to find out and get back to you with that information.
Hi markl,
We received information back from the manufacturer stating that the XLA-5-65-1250 comes as a kit which includes the XD-OEM controller.
The same will be true for all of the XLA-x series of products that we list.
