I’m looking for a temperature sensor (IC) with a programable alarm threshold and a digital output (HIGH/LOW signal) when the threshold is met.
Preferably working on 3 V DC, low power consumption, and a small form factor.
Hello @oleelo, I have found part number Texas Instruments TMP107BQDRQ1 for you. It has 2 digital alert outputs, programmable threshold, and operates from 1.7-5.5v.
It seems to be a good fit to your description if 8soic is small enough. It looks like the max current it draws is 400uA, so next to no power consumption.
Hello @John_13205, thanks, this looks perfect!
