Interested in 200-6319-9UN-1900, a 3M Pin grid array socket. There is an associated “contact” pin, 300-6300-CNA-0002B. I am unsure if the socket comes with the pins already, or if I need to order them as well.
Thanks
Thanks
Greetings,
It appears that the frame and contacts (blanking plugs also) for this assembly are sold separately, so as to allow configuration of the desired pin arrangement.
Thanks. I figured that was the most likely case.
