Hi Robert,
How to regain the storage from deleted files. I tried a few commands, it seems not working:
Suppose it still has 200M available.
Thank you,
David
Hi Robert,
Thank you,
David
Hi @dzhou, that’s for root… By Default in Debian (and most other distro’s) there is a small amount of space that set aside for the root user to do emergency maintenance when you run out of usable space…
Sounds like your using the eMMC, which base image are you starting with? (console/iot/lxqt?)
Quickly purge some data with:
sudo apt clean
This will clean up the apt cache…
Then using ‘dpkg --list’ find packages you don’t need.
Regards,
