Hi, I have a particular special use relay that would like to know if its available as an of the shelf item. I’m looking for a regular 12v automotive relay (20+amps) with the addition of 2 diodes on the input side of coil so that I can have 2 separate trigger wires without them back feeding into each other. The attached drawing might explain the wiring schematic better. Do you have such a relay?
