Replacement for NI PCI6025E
We have about a dozen machines that use NI PCI6025E IO cards.
These cards are way past obsolete and we are looking for a current equivalent that would connect to a PC using USB.
Thank you for any help you can provide.
Jeffrey DeWitt
Collins Aerospace
Welcome to the DigiKey TechForum jeffrey.dewitt2
We do not carry the NI PCI6025E cards, but I see on the NI website they have 16 analog inputs, 2 Analog outputs, and 32 Digital I/Os. We do not have anything that would be an equivalent to these boards, with a USB interface.
Details of the use case would influence device selection. There are devices such as the 781440-01 (AKA USB6351) available that would appear to be an upgrade on many fronts for a single module.
It should be noted that a USB interface presents difficulties for multi-device synchronization however, and that if this was a needed feature of the prior art, one may wish to consider other options.
Hello David,
Thank you for checking.
In my research the NI USB-6992 was suggested. You have them listed but none in stock and with an estimated ship date in September.
Regards,
Jeff DeWitt
