Replacement for relay HF115F-024-1Z1B
I need a Replacement for relay HF115F-024-1Z1B.
Does DigiKey has any suitable?
Hello 2015milu1 and welcome to the DigiKey TechForum.
Based on what I could find, it appears this would be a 24VAC coil, 12A/250VAC, SPDT relay. If that is the case, I found the options linked HERE that may work as an alternative.
You will want to review the specifications and documentation to ensure it will work for your application.
If these do not appear to be suitable alternatives, would you be able to provide the specifications of your relay?
Coil voltage should be 24VDC
Hello 2015milu1,
Given that information, we do have the options linked HERE that have a 24VDC coil voltage.
Make sure to review the specifications and documentation to ensure if any of these will work for your application.
