Help finding a through-hole 24 V DC 10 A relay replacement
Hi everyone,
I am trying to find a replacement for a relay I have been using in a project. The original part is a Songle SRD-24VDC-SL-C relay. It is a 24 V DC, through-hole, 5-pin relay rated for 10 A.
I have tried using the filters on DigiKey, but I keep finding relays rated for 2 A and not the 10 A ones I need. I am fairly new to replacing electrical components, so I might not be looking at the right part categories.
Does anyone know if DigiKey stocks a suitable replacement that is a through-hole, 24 V DC coil, 5 pins, and rated for 10 A or higher?
I have included a picture of the relay I am trying to replace
@PauseAndPlay
I found the 3385-AZ943-1CH-24DE-ND as an option based on the given specification you gave and show in the image.
AZ943-1CH-24DE American Zettler | Relays | DigiKey
