Replacement for Toneluck Switch MQS-1S SPST Normally Closed Microswitch
Below is an alternative for Toneluck Switch MQS-1S SPST Normally Closed Microswitch Solder Terminals (without lever). Please verify with the datasheet prior to ordering to see if the alternative offered will work for you and your application.
Manufacturer: Omron Electronics Inc-EMC Div
Manufacturer part # SS-5-F-2
DigiKey part # Z4569-ND
