Replacement relay that is discontinued
I am looking for a replacement relay used in vintage audio equipment.
The existing relay is an Omron, Type MY4, -0-US-AD4, 24 volt DC.
The existing relay has what I call narrow pins and they go through the holes in a PCB to be soldered. All I have been able to find are relays with the flat terminal type and they will not work. Can’t find anything, anywhere. Thank You
Welcome to the forum.
Here’s the PCB mount version of the MY4 24V (the “-02” in the part number specifies PCB terminals)
