Resistor Color Code
We do have a resistor calculator on our site, which you can access here: https://www.digikey.com/en/resources/conversion-calculators/conversion-calculator-resistor-color-code. Based on that color code, it would be 20.8 Ohm with a 0.25% tolerance. I can’t determine the wattage for that part from the photo, and could you please confirm if the first band is indeed red and not brown?
