Hello Digi-Key,
I’m looking for this item in your store:
DALE RH50 50 W 68ohm 1%…
I found this one (541-RHA05068R00FE02-ND) , but wasnt 100% sure of the compatibility.
Thanks,
Vince
Hello Digi-Key,
Thanks,
Vince
The original part should be RH05068R00FC02. 541-RHA05068R00FE02-ND Would be form, fit, and function. There the same resistance, wattage, tolerance, and physical size. The RHA series is “Automotive Grade”. Below are snips from both datasheets for the dimensions.
