We are looking for either a right-angled M12 Y-code connector, or for a number of harnesses to be assembled with M12 Y-code angled female connectors at each end (around 3m in length). Can you offer such a service, or put us in touch with someone that can?
Welcome to the TechForum.
I was able to locate a good link of circular connectors coded Y and available on the link below.
Active options
Thank you
Ryan
We also have pre-made cables with M12 “Y” orientation connectors on both ends that may work for your application located here:
Circular Cable Assemblies | Electronic Components Distributor DigiKey
You can use the filters to further narrow down which connector you’d like on each end to suit your application.
