When looking for RB521CS-30 schottky barrier diode from ROHM, you may find an “A” suffix at the end of the part number, i.e. RB521CS-302RA.
- This “A” suffix calls out 100mA series.
Please note that RB521CS-302RA is inactive. You may consider using RB521CM-30T2R, instead. Here is the data sheet for part RB521CM-30T2R which gives quick reference to the part specifications.
| PART NUMBER | RB521CS-302RA | RB521CM-30T2R |
| STATUS | Inactive | Active |
| DIODE TYPE | Schottky | Schottky |
| CURRENT - AVERAGE RECTIFIED (IO) | 100mA | 100mA |
| SPEED | Fast Recovery =< 500ns, > 200mA (Io) | Fast Recovery =< 500ns, > 200mA (Io) |
| CAPACITANCE @ VR, F | - | - |
| MOUNTING TYPE | Surface Mount | Surface Mount |
| PACKAGE / CASE | SOD-923 | SOD-923 |
| SUPPLIER DEVICE PACKAGE | VMN2 | VMN2M |
| OPERATING TEMPERATURE - JUNCTION | 150°C (Max) | 150°C (Max) |
| VOLTAGE - DC REVERSE (VR) (MAX) | 30 V | 30 V |
| VOLTAGE - FORWARD (VF) (MAX) @ IF | 350 mV @ 10 mA | 350 mV @ 10 mA |
| CURRENT - REVERSE LEAKAGE @ VR | 10 µA @ 10 V | 10 µA @ 10 V |
