Roland SonicCell sound module replacement display screen and rotary encoder with push button
Looking for a display screen 128 x 64 (5 cm diag) 26 pin connector and a push button rotary encoder for a Roland SonicCell sond mudule
Roland’spart number for the module is 04567056
I was able to locate some display alternates on this link and will look more for the Rotary encoder for this SonicCell module.
Technical assistance was provided for DISPLAY
Similar displays
LCD, OLED, Graphic | Optoelectronics | DigiKey
Thank you
Ryan
Which ones have the 26 pin connector ribbon
Hi,
I could not filter by pin terminations, but these started with the size and active status.
Hopefully I can locate a good option for an encoder and I will look for less and better options for the display.
Thank you
Ryan
Thank you
The generic code of the display is REL3064W if that helps
