When looking at Samsung’s CL series General Multilayer Ceramic Capacitors (MLCCs), the meanings of most suffixes in the part numbers can be found below, such as CL10B104KB8NNNC.
Sometimes, you may see the part number with a “G” last suffix digit, like CL21B106KQQNNNG. The datasheet does not calls out this detail information.
- The meaning of “G” suffix is the same as “E” suffix, except it is a 3K reel instead of 2K.
