Sanyo Denki Fan Suffixes
Sanyo Denki Fan Suffixes:
https://www.sanyodenki.com/archive/document/product/cooling/Numbering_system_E.pdf
As an example, “1” Suffix on Sanyo Denki fan 9GA0612P1J031 is calling out “Plastic Ribless Frame”.
Products below with and without the 1 suffix:
Click here for 9GA0612P1J03 | 9GA0612P1J031
Hi @Ryan_2724 Ryan_2724
I found other one. “3” suffix.
109P0412H301
109P0412H3013
MFG answer below
"Both 109P0412H3013 and 109P0412H301 are valid part numbers and have the same performance. The difference is placement of the outlet side struts and if you notice the lead wires exist from two different angles between both versions. I attached drawings of both fans for your reference. "
109P0412H301
109P0412H3013
