SEARCHING FOR THIS DIODE D1455 8142. NO OTHER MARKINGS VISIBLE. THIS IS PART OF A 120V AC TO 24 VOLT DC BATTERY CHARGER MOUNTED ON A GROVE SM3200 ELECTRIC / HYDRAULIC MANLIFT. DISCRIPTION: 1/4" THREADED STUD ON ONE SIDE. STUD IS MOUNTED THROUGH A ALUMINUM PLATE. THE CHARGER HAS TWO OF THESE MOUNTED ON A COMMON ALUMINUM PLATE.
Thank you for contacting the technical forum. I am not able to find any data on that part. We carry the stud diodes. This would be the link: https://www.digikey.com/short/m1c58mqt
Unfortunately I am unable to find a data sheet on what you have.
