Snap on coax connector to suit a smd female U.FL/IPEX
The - smd female U.FL/IPEX - seems to be commonly found on pcb WIFI devices but there seems to be a number of different identifying names for a matching plug.
These are the ones that I think will snap on: U.FL/UMCC and IPEX/MHF1.
Can someone from Digikey Tech please confirm?
Ideally if someone can supply a Digikey link to a cable assembly product approx 100mm coax(50ohm) with suitable plugs on either end, that would be great. Thanks.
Hello @gjgsmithvr,
Welcome to the Techforum Community!
You are correct, the U.FL, UMCC, IPEX, MHF1 are all compatible. Click here for 100mm cable options
Thanks!
Thank you Jeff for your prompt reply, much appreciated.
