If you are looking for soldering information for Speaker AS02708CO-R from PUI Audio, Inc., kindly note the following:
The manufacturer clarified that:
The recommended soldering temperature and time are typically 350°C for 2–3 seconds, which are within acceptable limits.
However, please ensure that
- Soldering should only be done on the open terminal rings, which are designed for lead wire connections.
- Avoid soldering near the fiberboard joint , as heat can cause contact flow issues and damage the product. Only use the terminal rings to connect lead wires. The other solder joint is for the coil wire connection and should not be soldered to or allow their soldering (time/temp) to apply enough heat that will melt this joint.
Applicable Part Numbers
| 668-1526-ND | AS01508MR-6-R |
| 668-1398-ND | AS03608MR-5-R |
| 668-1397-ND | AS02808MR-2-R |
| 668-1112-ND | AS02708CO-WR-R |
| 668-1231-ND | AS02808MR-R |
| 668-1239-ND | AS05008MS-R |
| 668-1238-ND | AS05008MR-4-R |
| 668-1362-ND | AS04008CO-WR-R |
| 668-1371-ND | AS07108PO-R |
| 668-1364-ND | AS04008PS-4W-R |
| 668-1125-ND | AS07108PO-WR-R |
| 668-1234-ND | AS04004PO-2-R |
| 668-1236-ND | AS04008PO-2-R |
| 668-1360-ND | AS04008CO-2-R |
| 668-1116-ND | AS04008PS-4W-WR-R |
| 668-1361-ND | AS04008CO-2-WR-R |
| 668-1359-ND | AS04004PR-R |
| 668-1655-ND | AS03204MS-3-R |
| 668-AS03104MR-F-WP-R-ND | AS03104MR-F-WP-R |
| 668-1542-ND | AS03208MS-3-R |
| 668-AS02832MR-2-R-ND | AS02832MR-2-R |
| 668-1613-ND | AS01508MS-SP11-WP-R |
| 668-AS01008MR-3-LW100-R-ND | AS01008MR-3-LW100-R |
| 668-1229-ND | AS02008MR-R |
| 668-AS01508MO-SP11-LW25-R-ND | AS01508MO-SP11-LW25-R |
| 668-AS01508MR-6-LW100-R-ND | AS01508MR-6-LW100-R |
| AS05045MR-R-ND | AS05045MR-R |
| 668-1228-ND | AS01808MR-R |
| 668-1411-ND | AS02008MR-5-R |
| 668-1115-ND | AS04008PR-WR-R |
| 668-AS02204MR-2-ND | AS02204MR-2 |
| 668-1230-ND | AS02708CO-R |
| 668-1442-ND | AS05008MS-LW152-R |
| 668-1435-ND | AS01808MR-LW152-R |
| 668-AS05004MR-4-LWC45-ND | AS05004MR-4-LWC45 |
| 668-1447-ND | AS07108PO-LW152-WR-R |
| 668-1420-ND | AS07004PO-R |
| 668-1235-ND | AS04008CO-R |
| 668-1444-ND | AS07104PO-LW152-R |
| 668-AS05208PR-4-R-ND | AS05208PR-4-R |
| 668-1438-ND | AS04004PO-2-LW152-R |
| 668-1357-ND | AS04004PO-2-WR-R |
| 668-AS01208MS-SP12-WP-LW100-R-ND | AS01208MS-SP12-WP-LW100-R |
| 668-AS04004MO-SP40-ND | AS04004MO-SP40 |
| 668-AS02504AR-ND | AS02504AR |
| 668-AS07008MO-R-ND | AS07008MO-R |
| 668-1268-ND | AS06608PS-2-R |
| 668-1269-ND | AS06608PS-R |
| 668-AS03204AS-HT-WP-ND | AS03204AS-HT-WP |
| 668-AS03604AR-ND | AS03604AR |
| 668-AR04032MR-5-R-ND | AR04032MR-5-R |
| 668-AS04504PR-F-WP-R-ND | AS04504PR-F-WP-R |
| 668-AS04008MR-21-R-ND | AS04008MR-21-R |
| 668-AS01508MO-SC11-R-ND | AS01508MO-SC11-R |
| 668-AS03604MR-2-R-ND | AS03604MR-2-R |
| 668-1614-ND | AS01508MS-SC11-WP-R |
| 668-AS03608MR-LW100-R-ND | AS03608MR-LW100-R |
| 668-AS05004MR-3-R-ND | AS05004MR-3-R |
| 668-AS02016MR-2-R-ND | AS02016MR-2-R |
| 668-AS04004CO-2-R-ND | AS04004CO-2-R |
| 668-1226-ND | AS01308MR-2-R |
| 668-1611-ND | AS01506MS-SP15-WP-R |
| 668-1603-ND | AS01606MS-SP16-WP-R |
| 668-1232-ND | AS03008MR-R |
| 668-1653-ND | AS01308MR-5-R |
| 668-1419-ND | AS03808PR-R |
| 668-1233-ND | AS03608MR-4-R |
| 668-1616-ND | AS01508MS-SC15-WP-R |
| 668-1412-ND | AS03608MR-SC-R |
| AS04008MR-11-R-ND | AS04008MR-11-R |
| 668-AS04016MR-R-ND | AS04016MR-R |
| 668-1437-ND | AS02808MR-LW152-R |
| 668-1428-ND | AS03508CO-7-R |
| 668-1370-ND | AS06608MR-R |
| 668-1441-ND | AS04008PO-2-LW152-WR-R |
| 668-1410-ND | AS02008MO-R |
| 668-1445-ND | AS07104PO-LW152-WR-R |
| 668-AS01208MS-SP12-WP-R-ND | AS01208MS-SP12-WP-R |
| 668-ASE05008MS-LWC60-ND | ASE05008MS-LWC60 |
| 668-AS01208MS-SC12-WP-R-ND | AS01208MS-SC12-WP-R |
| 668-1358-ND | AS04004PO-R |
| 668-AS05004PS-2-F-WP-R-ND | AS05004PS-2-F-WP-R |
| 668-AS04004MR-F-WP-R-ND | AS04004MR-F-WP-R |
| 668-AS09008PO-11-WR-R-ND | AS09008PO-11-WR-R |
| 668-AS04304PR-F-WP-R-ND | AS04304PR-F-WP-R |
| 668-1617-ND | AS01808MS-SP18-WP-R |
| 668-1610-ND | AS01506MS-SC11-WP-R |
| 668-1117-ND | AS05004PR-2-WR-R |
| 668-1446-ND | AS07108PO-LW152-R |
| 668-AS04016MR-4-LW34-ND | AS04016MR-4-LW34 |
| 668-AS02008MR-7-ND | AS02008MR-7 |
| 668-AS01508MS-SC11-WP-2-R-ND | AS01508MS-SC11-WP-2-R |
| 668-AS02208MO-ND | AS02208MO |
| 668-AS02408MO-LW50-R-ND | AS02408MO-LW50-R |
| 668-AS01508MS-SC15-WP-2-R-ND | AS01508MS-SC15-WP-2-R |
| 668-AS02008MR-HT-WP-ND | AS02008MR-HT-WP |
| 668-AS02404PO-ND | AS02404PO |
| 668-AS02808MR-3-LW80-R-ND | AS02808MR-3-LW80-R |
| 668-AS02504MO-SP9-ND | AS02504MO-SP9 |
| 668-AS02308MR-T-ND | AS02308MR-T |
| 668-AS04016CO-WR-R-ND | AS04016CO-WR-R |
| 668-AS02204CR-ND | AS02204CR |
| 668-AS04008MR-F-2-ND | AS04008MR-F-2 |
| 668-AS04008MR-11-WP-LW54-R-ND | AS04008MR-11-WP-LW54-R |
| 668-AS03404MO-SP34-ND | AS03404MO-SP34 |
| 668-AS03208AS-HT-ND | AS03208AS-HT |
| 668-AS05208PS-ND | AS05208PS |
| 668-AS03804MO-SP13-ND | AS03804MO-SP13 |
| 668-AS04008PR-6-ND | AS04008PR-6 |
| 668-AS03504AR-T-ND | AS03504AR-T |
| 668-AS04008PO-4-R-ND | AS04008PO-4-R |
| 668-AS04204PR-ND | AS04204PR |
| 668-AS04504AS-ND | AS04504AS |
| 668-AS04204PR-2-ND | AS04204PR-2 |
| 668-AS04004MS-ND | AS04004MS |
| 668-AS04604PR-ND | AS04604PR |
| 668-AS05808PO-WP-ND | AS05808PO-WP |
| 668-AS04804PS-ND | AS04804PS |
| 668-AS05304PS-ND | AS05304PS |
| 668-AS01506MS-SC15-WP-2-R-ND | AS01506MS-SC15-WP-2-R |
| 668-AS05508MO-ND | AS05508MO |
| 668-AS020100MR-R-ND | AS020100MR-R |
| 668-AS05016PR-4-R-ND | AS05016PR-4-R |
| 668-AS01516MR-2-R-ND | AS01516MR-2-R |
| 668-1608-ND | AS01608MS-SC16-WP-R |
| 668-1606-ND | AS01608MS-SC9-WP-R |
| 668-AS04008CO-2-LW100-R-ND | AS04008CO-2-LW100-R |
| 668-1612-ND | AS01506MS-SC15-WP-R |
| 668-1535-ND | AS01008MR-2-R |
| 668-1436-ND | AS02008MR-LW152-R |
| 668-1237-ND | AS04508MR-3-R |
| 668-1368-ND | AS05008PR-A-R |
| 668-1299-ND | AS05708MR-R |
| 668-1367-ND | AS05008PR-6-R |
| 668-AS06004CO-C-R-ND | AS06004CO-C-R |
| 668-1119-ND | AS05008PR-WR-R |
| 668-AS02508CO-4-R-ND | AS02508CO-4-R |
| 668-1439-ND | AS04004PO-2-LW152-WR-R |
| 668-AS09008PO-11-R-ND | AS09008PO-11-R |
| 668-1667-ND | AS08304CR-R |
| 668-1668-ND | AS08308CR-R |
| 668-AS05404PS-ND | AS05404PS |
| 668-1565-ND | AS06004PS-R |
| 668-1567-ND | AS09208AR-R |
| 668-AS01504MR-R-ND | AS01504MR-R |
| 668-AS01550MR-2-R-ND | AS01550MR-2-R |
| 668-AS01525MR-R-ND | AS01525MR-R |
| 668-AS02850MR-R-ND | AS02850MR-R |
| 668-1609-ND | AS01506MS-SP11-WP-R |
| 668-1618-ND | AS01808MS-SC18-WP-R |
| AS01506MS-SC15-WP-3-R-ND | AS01506MS-SC15-WP-3-R |
| 668-1363-ND | AS04008PR-R |
| 668-1501-ND | AS05004PR-2-R |
| 668-1369-ND | AS05008PR-R |
| 668-1440-ND | AS04008PO-2-LW152-R |
| 668-AS05008MR-15-ND | AS05008MR-15 |
| 668-1114-ND | AS04008PO-2-WR-R |
| 668-1666-ND | AS06606SR-R |
| 668-AS11508AR-R-ND | AS11508AR-R |
| 668-AS04008MS-3-ND | AS04008MS-3 |
| 668-1216-ND | AS07104PO-R |
| 668-1124-ND | AS07104PO-WR-R |
| 668-1121-ND | AS06608PS-WR-R |
| 668-1113-ND | AS04004PO-WR-R |
| 668-AS01506MS-WP-LW100-R-ND | AS01506MS-WP-LW100-R |
| 668-AS01606MS-SC16-WP-2-R-ND | AS01606MS-SC16-WP-2-R |
| 668-AS015100MR-R-ND | AS015100MR-R |
| 668-AS01532MR-R-ND | AS01532MR-R |
| 668-1605-ND | AS01608MS-SP9-WP-R |
| 668-1604-ND | AS01606MS-SC16-WP-R |
| 668-AS04016CO-R-ND | AS04016CO-R |
| 668-1366-ND | AS05008PR-2-R |
| 668-1356-ND | AS03508CO-2-R |
| 668-1240-ND | AS07108PO-3-R |
| 668-1122-ND | AS07004PO-WR-R |
| 668-1566-ND | AS06008PS-R |
| 668-AS01316MR-R-ND | AS01316MR-R |
| 668-AS01304MR-R-ND | AS01304MR-R |
| 668-AS02008MR-HT-R-ND | AS02008MR-HT-R |
| 668-1607-ND | AS01608MS-SP16-WP-R |
| 668-AS01708MR-2-LW100-R-ND | AS01708MR-2-LW100-R |
| 668-AS03504CO-2-R-ND | AS03504CO-2-R |
| 668-AS03608MR-4-HT-R-ND | AS03608MR-4-HT-R |
| 668-AS02708CO-LW100-R-ND | AS02708CO-LW100-R |
| 668-AS04516MR-2-LW105-R-ND | AS04516MR-2-LW105-R |
| 668-1353-ND | AS01308MR-R |
| 668-1365-ND | AS05008MR-R |
| 668-AS04032PR-R-ND | AS04032PR-R |
| 668-1527-ND | AS01708MR-SC-2-R |
| 668-AS04004PR-WR-R-ND | AS04004PR-WR-R |
| 668-AS07008PO-4-R-ND | AS07008PO-4-R |
| AS5008M-32-ND | AS5008M-32 |
| AS02008MR-LWC63-R-ND | AS02008MR-LWC63-R |
| 668-1126-ND | AS07708PS-2-WR-R |
| 668-1211-ND | AS07008PO-2-WR-R |
| AS04004PO-2-LWC102-2-R-ND | AS04004PO-2-LWC102-2-R |
| 668-1443-ND | AS06608MR-LW152-R |
| 668-1120-ND | AS05708PR-2-WR-R |
| 668-1123-ND | AS07008PS-WR-R |
| 668-1127-ND | AS07708PS-3-WR-R |
| 668-1128-ND | AS09008PO-2-WR-R |
| 668-1129-ND | AS09008PO-WR-R |
| 668-1130-ND | AS10004PS-WR-R |
| AS03604MR-R-ND | AS03604MR-R |
| 668-1191-ND | AS07008PO-2-R |
| AS01508MR-3-R-ND | AS01508MR-3-R |
| 668-1227-ND | AS01508MR-R |
| 668-1298-ND | AS01708MR-SC-R |
| 668-1354-ND | AS02508CO-2-R |
| 668-1355-ND | AS02508CO-2-WR-R |
| AS02708CO-2-R-ND | AS02708CO-2-R |
| AS02804MR-R-ND | AS02804MR-R |
| AS03508CO-5-R-ND | AS03508CO-5-R |
| AS03608MR-3-R-ND | AS03608MR-3-R |
| AS04008MS-R-ND | AS04008MS-R |
| AS04008PO-R-ND | AS04008PO-R |
| AS04008PO-WR-R-ND | AS04008PO-WR-R |
| AS04008PS-2-R-ND | AS04008PS-2-R |
| AS05004PS-R-ND | AS05004PS-R |
| AS05008PS-R-ND | AS05008PS-R |
| AS05708PR-2-R-ND | AS05708PR-2-R |
| AS05708PR-4-R-ND | AS05708PR-4-R |
| AS06508MS-R-ND | AS06508MS-R |
| AS07108PO-2-R-ND | AS07108PO-2-R |
| AS07108PO-2-WR-R-ND | AS07108PO-2-WR-R |
| AS07108PO-4-R-ND | AS07108PO-4-R |
| 668-1300-ND | AS07708PS-2-R |
| AS07708PS-3-R-ND | AS07708PS-3-R |
| 668-1301-ND | AS09008PO-2-R |
| AS09008PO-R-ND | AS09008PO-R |
| AS10308PS-R-ND | AS10308PS-R |
| AS05008MR-3-ND | AS05008MR-3 |
| AS06608PS-ND | AS06608PS |
| AS13708PR-ND | AS13708PR |
| AS1708-SC-ND | AS1708-SC |
| AS2808-72-ND | AS2808-72 |
| AS4508M-ND | AS4508M |
| AS10308PS-ND | AS10308PS |
| AS03008MR-ND | AS03008MR |
| AS04008PO-2-ND | AS04008PO-2 |
| AS07104PO-WR-ND | AS07104PO-WR |
| AS07108PO-ND | AS07108PO |
| AS704008-32-ND | AS704008-32 |
| AS04008PS-4W-WR-ND | AS04008PS-4W-WR |
| AS05008PR-3-WR-ND | AS05008PR-3-WR |
| AS05008PR-ND | AS05008PR |
| AS06608PS-WR-ND | AS06608PS-WR |
| AS04008PO-2-WR-ND | AS04008PO-2-WR |
| AS07008PO-ND | AS07008PO |
| AS04008PR-WR-ND | AS04008PR-WR |
