DigiKey has the ability to special order cables from I-PEX if we don’t currently stock them. Manufacturer minimum order quantity and lead-time may apply, and the quote process can take anywhere from 3-10 business days to complete. To request a special-order product from any of our vendors, simply fill out our Special Order Product Request Form.
Click here for all Coaxial Cables
Click here for all Coaxial Products
Example Part Numbers
| Part Number Description | Part Number |
| MHF I PLUG O.D. 0.81 mm / AWG 36 (Au plating) | 20278-112R-08 |
| MHF I PLUG O.D. 1.13 mm / AWG 32 (Au plating) | 20278-112R-13 |
| MHF I PLUG O.D. 1.80 mm / AWG 30 (Au plating) | 20278-112R-18 |
| MHF I PLUG O.D. 1.32 mm / AWG 32 (Au plating) | 20278-112R-32 |
| MHF I PLUG O.D. 1.37 mm / AWG 30 (Au plating) | 20351-112R-37 |
| MHF I PLUG O.D. 2.00 mm / AWG 26 (Ni top plating) | 20767-001R-20 |
| MHF I RECEPTACLE (3 pads) | 20279-001E-03 |
| MHF I PLUG (Au plating) | 20278-101R-08 |
| MHF I PLUG (Au plating) | 20308-112R-13 |
| MHF I PLUG (Au plating) | 20308-212R-37 |
| MHF I PLUG (Au plating) | 20351-111R-37 |
| MHF I PLUG (Au plating) | 20351-312R-37 |
| MHF I PLUG (SMOOTH INSERT TYPE/Au plating) | 20631-112R-08 |
| MHF I PLUG (SMOOTH INSERT TYPE/Au plating) | 20631-112R-13 |
| MHF I PLUG (SMOOTH INSERT TYPE/Au plating) | 20631-112R-32 |
| MHF I PLUG (SMOOTH INSERT TYPE/Au plating) | 20631-112R-37 |
| MHF I PLUG (SMOOTH INSERT TYPE/Ni top plating) | 20670-001R-08 |
| MHF I PLUG (SMOOTH INSERT TYPE/Ni top plating) | 20670-001R-13 |
| MHF I PLUG (SMOOTH INSERT TYPE/Ni top plating) | 20670-001R-18 |
| MHF I PLUG (SMOOTH INSERT TYPE/Ni top plating) | 20670-001R-32 |
| MHF I PLUG (SMOOTH INSERT TYPE/Ni top plating) | 20670-001R-37 |
| MHF I PLUG (Ni top plating) O.D. 1.13 mm / AWG 32 | 20278-212R-13 |
| MHF I PLUG (Ni top plating) O.D. 1.37 mm / AWG 30 | 20351-212R-37 |
| MHF I PLUG | 20797-112R-13 |
| MHF I PLUG | 20797-112R-32 |
| MHF I PLUG | 20797-112R-37 |
| MHF I RECEPTACLE (2.5K pcs/reel, Paper reel) | 20279-001E-01 |
| MHF I RECEPTACLE (10K pcs/reel, Plastic reel) | 20279-001E-05 |
| MHF I RECEPTACLE (4 pads type) | 20441-001E-01 |
| MHF I RECEPTACLE (for MHF I PLUG 20797) | 20803-001E |
See also
Amphenol Coaxial Cable & Connector Guide
Low Loss Coaxial Cable characteristics
Currently stocked I-PEX cable numbers
5378-8-23-0116-ND
5378-8-23-0111-ND
5378-8-23-0115-ND
5378-8-23-0119-ND
5378-8-23-0118-ND
5378-8-23-0112-ND
5378-8-23-0113-ND
5378-8-21-0047-ND
5378-8-21-0049-ND
5378-8-21-0043-ND
5378-8-21-0044-ND
5378-8-23-0114-ND
5378-8-23-0120-ND
5378-8-23-0121-ND
5378-8-22-0127-ND
5378-8-23-0117-ND
5378-8-21-0046-ND
5378-8-23-0110-ND
8-23-0116
8-23-0111
8-23-0115
8-23-0119
8-23-0118
8-23-0112
8-23-0113
8-21-0047
8-21-0049
8-21-0043
8-21-0044
8-23-0114
8-23-0120
8-23-0121
8-22-0127
8-23-0117
8-21-0046
8-23-0110
