SPH0641LU4H-1 higher frequency
------Question for SPH0641LU4H-1 Please Put your question below------
Hi,
Am non technical, so, need ur support. looking for the same type of microphone analog/digital with higher range of wave frequency.
This module is up to 80 khz.
am looking for 2-3 other modules that support frequency of up to
120 khz,
180 khz, even
220 khz, all should support ultrasonic applications.
No bar on any good brand.
Thanks,
nasser nabulsi
@nnabulsi66 Welcome to the DigiKey TechForum
MEMS microphones typically cap around 100 kHz. Not much for beyond the 100khz. I found out some for your reference.
Microphone
Hope this help.
Much appreciated
Dear Kevin,
What am trying to achieve here is to record mammals vocalization/colocation sound that is beyond 100 khz. Can u suggest any transducers/transceiver, Microphone, to do so, they should be IP57 + for outdoor usage. am working on a protype of STM PcB MCu with AI ML algorithm .
tks,
I found out a CUSA series ip-rated-ultrasonic sensors from Same Sky.
Alternatively, you can explore other options Here.
Hope this helps!
