Amplifier for Piezo Speaker
------Question for SPK-I-81345 Please Put your question below------
Hello! I’m wanting to use the SPK-I-81345 speaker to transmit bat echolocation calls around the 20-30 kHz range, but I’m not sure what kind of amplifier to use. I’ve been searching around but can’t seem to find a concrete answer. What amplifier works for transmitting ultrasonic frequencies?
Hello @pzander753
Welcome to the TechForum
You may want to look into using an audio transformer and the link below is audio transformers that would cover that 20kHz- to 30kHz range. There maybe someone else on the TechForum that might have a better suggestion of a transformer to use for your application.
Audio Transformers | Electronic Components Distributor DigiKey
Greetings,
The electrical specs tell a person a fair bit:
Most piezo motor mechanisms behave like capacitors, and this is affirmed by the impedance figure shown. Maximum peak-peak voltage one can apply before things are at risk of breaking is about 30V (which isn’t that high) and one’s probably not going to need anything near that to start bumping up against that 5mA maximum current figure. (I get about 200mV @ 30 kHz).
Those scale figures are within range of a lot of op amps, but loads that are more or less straight-up capacitances like that can cause issues with amplifier stability. There are parts like the AD817 however that are designed to cope with such things and other tricks can be employed also, with chapter 6 of ADI’s op amp applications handbook discussing the topic starting around page 83.
If you’re looking for something that’s more of a plug & play option, I’m not exactly sure where one might look; headphone amplifiers for bats aren’t exactly a mass-market item…
