Hi ,
I saw that the substitute of STR y6766 is TOP257ny, i have a question regarding the pinout, the only diference is that TOP257 is in mirror ?
Regards
Hi ,
Regards
they are similar not a direct cross , you will have electrical changes and the pin out changes , I do not see any direct cross for the part.
STR y6766 have the drain at pin 1 and TOP 257 at pin 6. So it is not a 100% substitute ( you don’t remove str y6766 and solder back top 257)
