------Question for 02160025-000 Please Put your question below------
Hello, We are looking for the PN in the subject. would you please advise ?
Hello @laxtoolgse,
Thank you for your post.
I’m sorry, but I am not seeing an exact match based on the ratings.
Our closest options would have a few differences such as the output.
The original listed a “Digital Readout” whereas our closest options are “Analog” or “Analog Voltage”.
If you would still like to take a look at those options, here is the link - Angle, Linear Position Measuring | Sensors, Transducers | DigiKey
Here are some other items which appear to be intended for the same sort of purposes.
These would all require interface to an external device to read the signals and display.
Hello @laxtoolgse,
The 02160025-000 is the 0 to 90 degree AngleStar Protractor System, a clinometer with its own LCD readout. The SmartTool PRO360 covers the same span and 0.1 degree resolution with the display built in, and it’s still made and in stock today. It’s handheld though, so you lose the remote sensor.
