Susumu RR0306P-332-D-C Suffix C meaning
If you are looking for the part number RR0306P-332-D from Susumu, you may find it with a -C suffix after the part number here on DigiKey
The “C” calls out an internal code for Susumu which is not indicated on the datasheet. The manufacturer is working on getting the part number fixed as the -C should not be reflected in the part number for ordering purposes.
