Take notice when ordering the AOYUE 486 Fume Extractor
One product. Four variations.
Be sure you are ordering the one for your needs.
Aoyue 486 Fume Extractor and Smoke Absorber Fan
Product Index ⟩ Soldering, Desoldering, Rework Products ⟩ Fume, Smoke Extraction ⟩
The 486 Fume Extractor comes in two variations.
The AO486 will be the same as the AO486+, however, AO486+ comes with illumination as well as an exhaust hose. Both of these run on 110V power only.
MFR PART # AO486
DIGIKEY PART # 2260-AO486-ND
MANUFACTURER SRA Soldering Products
DESCRIPTION 110VAC Bench Top Soldering/Desoldering Fume Smoke Extraction Unit
DATASHEET Click Here
MFR PART # AO486+
DIGIKEY PART # 2260-AO486±ND
There are still two more options.
These two are similar to the products in everyway except that they are designed to run on 220V power.
MFR PART # AO486-220V
DIGIKEY PART # 2260-AO486-220V-ND
DESCRIPTION 220V Bench Top Soldering/Desoldering Fume Smoke Extraction Unit
MFR PART # AO486+220V
DIGIKEY PART # 2260-AO486+220V-ND
Click the link below to find more products like these on DigiKey.com
Fume, Smoke Extraction | Electronic Components Distributor DigiKey
