------Question for PT10LV10-103A2020-S Please Put your question below------
Hi everyone,
I am designing a portable device and I need to confirm the exact configuration for a Piher 10mm potentiometer to ensure it matches my PCB footprint and ergonomic requirements.
Product focus:
Base Part Number: PTC10 series (Cermet).
Required Configuration: 10k Ohms, Linear (A), Horizontal mount, Y-version (Adjustable from terminal side).
Critical Option: I strictly need the integrated ON/OFF switch (Suffix -S).
My questions for the Tech Team:
Pin Count: Can you confirm that the version with the “-S” switch option has a total of 5 pins (3 for the resistor + 2 for the switch)?
Thumbwheel compatibility: Is this specific assembly compatible with the thumbwheel accessory JPEPL5034NE? I need the wheel to be as flush as possible to the PCB (Y-version).
Availability: If the “-S” version is not currently in stock, what is the exact full manufacturer part number I should look for to ensure I get the 5-pin switch version?
Attached is a reference of the style of thumbwheel interface I am aiming for.
Thanks for your help!
