At the end of Toshiba part numbers, if there is an (LF1, LF2, LF4, etc.) suffix, this suffix is referring to the lead form style. Please verify the manufacturer drawings for the package case dimensions.
Standard (0.300",7.62mm)
Examples with “Lead Form”
Example (LF1) on 6 pin surface mount
Example (LF2) on 6 pin through hole dip
Example (LF4) on 6 pin surface mount
Example (LF5) on 6 pin surface mount
Example (LF6) on 4 pin surface mount
Example (LF7) on 4 pin surface mount
Toshiba numbers
TLP751(D4-LF1,F), TLP624LF1F, TLP551(Y-LF1,F), TLP627M(LF1,E, TLP759(D4-LF1,J,F), TLP627M(LF1,E(OX4, TLP759(LF1,J,F), TLP531(GR-LF1,F), TLP371(LF1,F), TLP627-4(LF1,F), TLP631(GB-LF1,F), TLP570(LF1,F), TLP550(Y-LF1,F), TLP512(NEMIC-LF1,F, TLP532(BL-TLF1,F), TLP331(BV-LF1,F), TLP550-LF1,F), TLP731(GB-LF1,F), TLP750(D4-LF1,F), TLP531(BL-LF1,F), TLP550(LF1,F), TLP624-4(LF1,F), TLP552(LF1,F), TLP631(BL-LF1,F), TLP571(LF1,F), TLP624-2(LF1,F), TLP631(LF1,F), TLP731(D4-GR-LF1,F, TLP750(D4-O-LF1,F), TLP731(D4-GB-LF1,F, TLP732(GB-LF1,F), 4N35(SHORT-LF1,F), TLP732(D4-GB-LF1,F, TLP732(GR-LF1,F), TLP372(LF1,F), TLP531(LF1,F), TLP512(LF1,F), TLP513(LF1,F), TLP632(GB-LF1,F), TLP627-2(LF1,F), TLP352(LF1,F), TLP250LF1F, TLP523-2(LF1,F), TLP250(D4SND-LF1,F, TLP523-4(LF1,F), TLP351(LF1,Z,F), TLP352(LF1,S), TLP350(LF1,Z,F), TLP250(D4-LF1), TLP250(D4INV-LF1,F, TLP350(D4-LF1,Z,F), TLP250(D4-LF1,F), TLP523(LF1,F), TLP250(MBSKO-LF1,F, TLP3545(LF1,F), TLP222A-2(LF1,F), TLP240GA(LF1,F, TLP240J(LF1,F, TLP3554(LF1,F), TLP241A(D4,LF1,F, TLP240G(LF1,F, TLP241A(LF1,F, TLP240D(LF1,F, TLP240A(LF1,F, TLP3544(LF1,F),
TLP2601(LF1,F), TLP250H(D4-LF1,F), TLP250H(LF1,F), TLP2630(LF1,F), TLP2631(LF1,F), TLP2200(LF1,F), TLP3083(TP1,F, TLP3073(LF1,F, TLP3062A(LF1,F, TLP785(GR-LF6,F, TLP781(GRL-LF6,F), TLP781(D4-YH-LF6,F, TLP781(D4-GB-LF6,F, TLP785(LF6,F, TLP785(GRH-LF6,F, TLP781(D4-Y-LF6,F), TLP781(D4-BL-LF6,F, TLP785(D4-LF6,F, TLP781(D4GRL-LF6,F, TLP785(Y-LF6,F, TLP781(D4-GR-LF6,F, TLP781(Y-LF6,F), TLP781(D4GRH-LF6,F, TLP781(LF6,F), TLP781(D4BLL-LF6,F, TLP781(D4-LF6,F), TLP781(GB-LF6,F), TLP785(GB-LF6,F, TLP781(BL-LF6,F), TLP785(BL-LF6,F, TLP785(YH-LF6,F, TLP781(YH-LF6,F), TLP781(GRH-LF6,F), TLP781(BLL-LF6,F), TLP785(BLL-LF6,F, TLP781(GRH-LF6,F), TLP781(BLL-LF6,F), TLP785(BLL-LF6,F, TLP785F(LF7,F, TLP781F(D4GR-LF7,F, TLP781F(D4-LF7,F), TLP781F(BL-LF7,F), TLP781F(D4-Y-LF7,F, TLP781F(GRL-LF7,F), TLP785F(GB-LF7,F, TLP781F(GRH-LF7,F), TLP781F(BLL-LF7,F), TLP781F(YH-LF7,F), TLP785F(D4-LF7,F, TLP785F(Y-LF7,F, TLP781F(D4YH-LF7,F, TLP781F(Y-LF7,F), TLP785F(YH-LF7,F, TLP785F(D4BLF7,F, TLP781F(D4BL-LF7,F, TLP781F(D4GB-LF7,F, TLP781F(GR-LF7,F), TLP785F(GR-LF7,F, TLP781F(GB-LF7,F), TLP781F(LF7,F), TLP785F(BL-LF7,F, TLP781F(LF7,F), TLP785F(BL-LF7,F, TLP734(D4GRLF5,M,F, 4N26(SHORT-LF5,F), 4N35(SHORT-LF5,F), TLP531(Y-LF5,F), TLP631(LF5,F), TLP732(D4GRH-LF5,F, TLP550(LF5,F), TLP624-2(LF5,F), TLP331(LF5,F)
