The bare metal debian image is flashed through micro usb. I believe the uboot flashing is a separate process. I really haven’t studied this much. I am wandering what’s the easiest way to flash into eMMC ( I assume it is in the eMMC).
Hi @dzhou , that procedure exports the eMMC as an emulated “usb flash” drive. If you run lsblk you should see a new device. Then just write the two u-boot binaries like normal.
u-boot is flashed without any problems. Thank you very much.
I am also wandering that debian image (e.g. bone-debian-10.4-iot…img.xz) shall be able to flash into eMMC using dd instead of using Etcher program. if so, could you provide with dd command settings, such as count, seek, bs, etc. I think Etcher may be slower then dd, and it seems to be mandatory for verifying the flashing step. I am not sure verifying the flashing is necessary.
The u-boot is flashed into eMMC. I am not sure where is the u-boot environment data stored in the eMMC? NXP IMX SOMs has environment a separate partition (using UBI format for flash partitions). I still don’t have full picture of environment/u-boot under ti-BBB platform. I hope you can give me a quick guide (or good links of resources) to shed some light on this subject.
Thank you. Somehow, I think I remember the eMMC and microSD device number is in reverse order ( eMMC dev as 1, micro SD dev as 0) on BBB. I thought it is a little odd default to that way, so I had it remembered.
$ sudo mount -t ext3 -o loop,offset=0 u-boot.img /mnt/tmp
mount: /mnt/tmp: wrong fs type, bad option, bad superblock on /dev/loop0, missing codepage or helper program, or other error.
I was wandering what is the file system for the generated u-boot.img or is it possible that u-boot.img can be mounted and edited.
In the case of this project, the *.img in u-boot.img does not reference a archive “image”. In the scope of the U-Boot Project, u-boot.img is simply “A U-Boot image with a mkimage header prepended.” commonly generated from u-boot.bin, which is known as “The raw U-Boot image”.
You can use the mkimage tool to read the header off of u-boot.img:
Hi @dzhou, So BalenaEtcher needs to see a raw usb flash drive. So first you’ll need to get u-boot up and running on the device. Then have the device export the storage medium over usb to the PC running BalenaEtcher.
I guess it may be not easy thing to do. The raw usb flash drive is instantiated ( as rootfs). The device /dev/[sdb] is for u-boot and /dev/[sdb1] is rootfs partition, I believe. But
the BalenaEtcher only selects rootfs (currently). There is no option for
/dev/sdb ?
How to import image files [MLO and u-boot.img] into BalenaEtcher?
Or is there a way to combine and convert image format for Etcher?
