UL certification/label/traceability
Looking for UL certifications for this fuse and battery:
5HT 5-R
CR2032
UL cert number is listed in the data-sheet for the 5HT 5-R
490-18646-ND
This also lists the UL file number in the datasheet.
@hperisic
As for the documentation from UL you will need to use the file numbers and contact UL directly for a copy.
thank you, Nathan
