UL Specifications: Understanding How Standardization Generally Works
We have seen some increase of asking for “UL Specifications” or “Conditions of Acceptability” without much context. This post aims to provide some amount of insight on how standardization generally works and what we can generally answer. Please understand that DigiKey is not directly related to Underwriters Laboratory in any way and are not subject matter experts on any of the various standards.
Personal Background and Standardization Location
I have spent some time working directly with UL 508A, a standard that centralizes around the construction of industrial control panels. I took some time to go over some of the document to recall certain aspects and take notes. Again, we would prefer that you go find the applicable standards. You can find details on this site: https://shopulstandards.com/ . The documents are typically available as online digital copies if you sign up for an account. You can only download these standards if you pay for them directly.
Key Lessons
  • Determine what the applicable standard is before searching for requirements.
  • Understand the scope of the standard and whether it applies to the product being designed.
  • Pay close attention to referenced standards, documents, appendices, supplemental information, and exceptions.
  • Certification information is often spread across multiple resources rather than contained in a single document.
  • Standards may reference additional documents, component certifications, category control numbers (CCNs), appendices, or other resources that are relevant to the evaluation process.
  • UL Product IQ can be extremely useful for researching certified components, but it requires independent investigation by the user.
  • Manufacturer documentation and UL Product IQ should be reviewed side by side because they provide different pieces of information.
  • Conditions of Acceptability and certification categories should be evaluated within the context of the applicable standard.
  • A component’s datasheet may provide ratings and technical specifications, but may not answer the compliance question being asked.
  • Compliance research frequently involves tracing references between standards, certifications, and manufacturer documentation.
  • Most product certificates are found on UL Product IQ or have the exact same information found in most UL Certificates.
  • Conditions of Acceptability are often found under CCNs (Category Control Numbers) within UL Product IQ. The level of detail varies significantly between categories. Some provide application-specific information, while others contain more general guidance. Determining whether additional specifications apply typically requires reviewing the relevant standard, certification information, and manufacturer documentation such as datasheets.
Conclusion
Distributors may have access to some of the documentation, but are not responsible for the interpretation of standards. There aren’t generic “UL Specifications” because it highly depends on the standard being asked about. Conditions of Acceptability may not always contain useful information immediately. The more information you can provide regarding the applicable standard and application requirements, the more effectively we can assist with part selection and research. I will cover one practical approach utilizing 508A as a reference for part selection to show how that flow might work in a future post.
