------Question for 61302011821 Please Put your question below------
How many units are in one tray of the WR-PHD 2.54 MM SOCKET HEADER 20 (732-61302011821-ND)?
Thank you!
https://www.digikey.dk/da/products/detail/würth-elektronik/61302011821/16608603
Hello and welcome them to our community!
The standard Packaging Unit is 160 units in one tray of the WR-PHD 2.54 MM SOCKET HEADER 20 (732-61302011821-ND) as original manufacturer’s Packaging from Würth Elektronik.
You can buy it as single piece as well.
Thank you, and thank you for the answer!
Just to be sure, when i buy 1 tray i will get 160 units for 0,85 US$?
When you but 1, you will receive 1. To receive 160, you will need to order 160pcs.
How come it says “tray” and not “unit”? And when buying a “tray” i get 160 units? Or how should the page be understood when it says “tray” and 1 cost 0.85$?
The “Tray” note is regards to the manufacture packaging. When the part is ordered in quantities less than a full tray, the parts will be taken out of the manufactures standard packaging. The quantities in the price break are per piece.
1 piece cost $0.85 per piece. 25 pieces cost $0.76 per piece.
Thank you. I just had a difficult time understanding how this one could be more expensive than a potentiometer.
