UPA-130 Series Replacements
These cross-reference posts are for informational purposes only, please review the manufacturer data sheet and specifications for any replacement parts before using them in your application.
Hello All,
UPA-130 (DigiKey Number 4821-UPA-130-ND), from ATC-Diversified Electronics, seems to have been discontinued recently, with no recommended replacement. A search for similar parts in our system turned up part number 4821-UPA-100-ND, which is from the same manufacturer as a replacement option. Please note however, while the performance appears to be the same, the UPA-100 is larger in size, requiring the panel cutout to be about 0.5 inches wider in diameter for installation.
Hope this helps!
