Hi I am installing image for beaglebone black and I installed following link
When I booted up, mine was debian@arm I didn’t install the beaglebone image to be able to use the kernel’s gcc.
Can anyone help me, connect usb0 or find the toolchain for img@beaglebone so I can write kernel module.
debian@arm:~$ ifconfig
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.0.104 netmask 255.255.255.0 broadcast 192.168.0.255
inet6 fe80::6a3:16ff:feac:24d7 prefixlen 64 scopeid 0x20<link>
ether 04:a3:16:ac:24:d7 txqueuelen 1000 (Ethernet)
RX packets 3295 bytes 218003 (212.8 KiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 656 bytes 50834 (49.6 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 12 bytes 1658 (1.6 KiB)
TX packets 12 bytes 1658 (1.6 KiB)
debian@arm:~$ ls /dev/usb0
ls: cannot access '/dev/usb0': No such file or directory
debian@arm:~$
My gcc is
asus@asusgame:~/bbb/kernelbuildscripts/dl/gcc-8.5.0-nolibc/arm-linux-gnueabi/bin$
Hi @buihien29112002 ,
This is completely expected… USB0 configuration is not a hard set feature, it’s something you as the end users must enable in user-space.
Our Current Production line images: Topics tagged latest-images (Debian 11.x Bullseye)
Use systemd and systemd-network to make this very seamless.
You’ll need our bb-usb-gadgets project: https://github.com/rcn-ee/repos/tree/master/bb-usb-gadgets/suite/bullseye/debian
First make sure systemd-network is enabled and utilized, then install:
sudo apt update
sudo apt install bb-usb-gadgets
USB0/USB1 ip configuration is setup in: (default is used by beagleboard.org)
/etc/systemd/network/usb0.network
/etc/systemd/network/usb1.network
Default libcomposite configuration: (default is used by beagleboard.org)
https://github.com/rcn-ee/repos/blob/master/bb-usb-gadgets/suite/bullseye/debian/bb-start-acm-ncm-rndis-old-gadget
and enable it:
sudo systemctl enable --now bb-usb-gadgets.service
and now reboot and bb-usb-gadget should load fine
sudo systemctl status bb-usb-gadget
For your other question. You’ve already built the kernel with a cross compiler, just add your external module into that build.
Regards,
Hello Robert
I cannot Install BB-USB-GADGETS
I downloaded the BB-USB-GADGETS source code but could not install it
Regards,
What base image are you running?
/etc/rcn-ee.conf
Regards,
Hello Robert,
I’ve tried to install, and it worked well when my “bbb” had a network connection. However, this time I’ve encountered an issue with the LAN port of my “bbb,” which is damaged and doesn’t receive any network connection when plugged in. As a result, my “bbb” doesn’t have network access, and I’m unable to install “usb0” and “usb1” using the ‘sudo install’ command. Is there an alternative way to install ‘bb-usb-gadgets’ and configure the network?
Sincerely,
RealaxER
In this case, just grab one of the iot images, as this has usb0/usb1 pre-configured… Topics tagged latest-images
Regards,
Yeah, I need to build the image again to have the toolchain, kernel, and u-boot for writing drivers and making custom modifications as per my requirements.
You’re welcome for the response!
