VCC BS series panel indicator cross reference
The Series BS from Visual Communications Company (VCC) has gone obsolete. The replacement for this series is the CS series.
Here are the datasheet for the CS series
http://static.vcclite.com/files/CS_Datasheet.pdf
The main difference in the two series’ is the finish on the parts. Otherwise these parts are very similar.
Example:
BS1-2702-0000-I-6 would be replaced by CS1-2702-0000-I
