Question:
What are surge countermeasures in coil relays?
Answer:
The back electromotive force generated by the coil, when it’s turned off, may cause damage to the semiconductor or device malfunction. As a countermeasure, add a surge-absorbing circuit to both ends of the coil.
If a surge-absorbing circuit is added, the relay release time will be longer. Check the circuit before use.
Explanation:
Surge countermeasure
- Driving DC coil relay: Diodes are typically attached to the relay coil.
- Driving AC coil relay: Varistors/CR elements are typically attached to the relay coil.
Examples of Surge Suppressors
For more information, see Safety Precautions for All Relays:2-2-5 Preventing Surges When the Coil Is Turned OFF.
Please visit the link below to see this product line on the Digi-Key website
Relays | Digi-Key Electronics
https://components.omron.com/us-en/faq/relays/FAQE10041
