When you purchase your F3SG-RE series light curtain from Omron Automation and Safety, according to the datasheet (as seen below) standard brackets and one cable will be included with your purchase.
Brackets:
If you are interested in the other mounting brackets mentioned in the table above or need extra standard brackets please use the following links.
F39-LGF Standard
F39-LGA Standard Adjustable
F39-LGTB Top/Bottom Adjustable
F39-LGTB-1 Top/Bottom Adjustable (For user-made
mounting part)
Cables:
F39-GCNY1 (Y joint)
Circular Cable Assemblies (connector to bare wires)
Circular Cable Assemblies (connector to connector)
Spatter Protection Covers:
Please use the chart below to determine which cover you need and the link to access the covers we have available. If you need a cover we do not currently carry please contact quotes@digikey.com to see if we can order it for you.
Accessories:
For the laser pointer for help with coarse beam adjustment:
F39-PTG
