Looking for the difference between the TC2030-MCP and TC2030-MCP-NL PLUG-OF-NAILS™ cables from Tag-Connect LLC? Here’s what the “NL” suffix means:
Tag-Connectors come in two types: “With Legs” (also known as “legged”) and “No Legs.” In part numbers, the “-NL” suffix specifies the “No Legs” version.
The Legged solution is ideal for development environments where a secure connection over an extended period of time is required. This option is self-securing to the PCB.
The No Legged option is perfect for production programming where you are performing a one-off short duration operation and where minimizing physical board space is a significant consideration. For longer operations, such as debugging, a clip or fixture can be used to secure the connection instead of holding it by hand.
Applicable Part Numbers
| DigiKey Part Number | Menufacturer Part Number |
| TC2030-MCP-NLTC-ND | TC2030-MCP-NL |
| TC2030-MCP-NL-10-ND | TC2030-MCP-NL-10 |
| TC2030-MCP-10-ND | TC2030-MCP-10 |
| TC2030-MCPTC-ND | TC2030-MCP |
| 1048-SPY-BI-TAGWITHR1-ND,SPY-BI-TAG-ND | SPY-BI-TAG |
| TC2030-DEMO-BAREBOARD-ND | TC2030-DEMO-BAREBOARD |
| TC2030-CLIP-ND | TC2030-CLIP |
| TC2030-HEADER-6-ND | TC2030-HEADER-6 |
| TC2030-DEMO-ND | TC2030-DEMO |
