What is the difference between the ST-5S and the ST-5S-BT2 Smart Tweezers from Ideal-tek?
The Ideal-Tek ST-5S Smart Tweezers are ESD-safe tweezers with integrated magnification and illumination. They provide a clearer view of small components during handling, improving precision and reducing the risk of damage.
MFR PART # ST-5S
DIGIKEY PART # ST-5S-1001-ND
MANUFACTURER Ideal-tek S.A.
DESCRIPTION Auto/Manual True RMS Tweezer Digital (DMM) Multimeter 4.0 Digit OLED Display Capacitance, Inductance, Resistance Diode Test Function Features
DATASHEET Click Here
The ST-5S-BT2 does all of the same but also includes Bluetooth connectivity and image capture capabilities. The captrued images can be transferred wirelessly to a computer or mobile device for analysis or documentation. Essentially, they combine the precision of tweezers with the capabilities of a digital microscope.
MFR PART # ST-5S-BT2
DIGIKEY PART # ST-5S-BT2-1002-ND
DESCRIPTION Auto/Manual True RMS Tweezer Digital (DMM) Multimeter 4.0 Digit OLED Display Capacitance, Inductance, Resistance Continuity, Diode Test, Bluetooth Function Features
Software
It should be noted that the ST-5S-BT2 will only work with iOS and Android mobile devices.
The tips
These will work with both devices.
MFR PART # ST5-IT-T
DIGIKEY PART # ST5-IT-T-1175-ND
DESCRIPTION SMART TWEEZER STRAIGHT TIPS
MFR PART # ST5-IT-TSHP
DIGIKEY PART # ST5-IT-TSHP-1177-ND
DESCRIPTION SMART TWEEZER HP STRAIGHT TIPS
MFR PART # ST5-IT-TB
DIGIKEY PART # ST5-IT-TB-1176-ND
DESCRIPTION SMART TWEEZERS STANDARD BENT TIP
