What is the mating connector MPN of 2EDGRC-5.0-02P-14-100L(H)?
------Question for 2EDGRC-5.0-02P-14-100L(H) Please Put your question below------
Planning to use this part for my PCB, but what is the matching connector that fits in it? I saw
2EDGK-5.08-02P-14-1000L(H), is this 100% fitting the 2EDGRC-5.0-02P-14-100L(H)?
The correct mating part for 2EDGRC-5.0-02P-14-100L(H) is going to be Degson # 2EDGK-5.0-02P-14-1000L(H) (link: 2388-2EDGK-5.0-02P-14-1000L(H)-ND).
The connector you mentioned from the 2EDGK-5.08 series has a pitch that is slightly larger than your header, so that one wouldn’t have fit. Hope this helps!
Thanks, I needed the 2EDGK-5.08-02P-14-1000L(H), that is with the 5.08 pitch to have the 10A rating equivalent. What will the mating connector for this PCB header? Will it be 2EDGKA-5.08-02P-14-1000L(H)?
