What is the replacement for ATMHK218 24C02N SU27D
Hello @Buzzme and welcome to the forum. So far, I’m not seeing any confirmation on that part number, do you happen to have any more information on it, perhaps a data sheet, specifications, or alias part number?
As of yet, I’m unable to identify a replacement due to the lack of information, but if we could identify this part we would have a better chance of finding the replacement.
Thank you!
The similar MPN: AT24C02N-10SC was in the past produced from Atmel and after the acquisition in 2016 by Microchip Technology this IC EEPROM 2kbit I²C 400kHz in 8SOIC was Obsoleted in the meantime. The fully backward compatible actual version AT24HC02C-SSHM-B should be the closest replacement with wide voltage supply range and capable bus clock speed up to 1MHz.
Thanks so much for all your help ![]()
